Windshield replacement issues(leaking) done through safelite
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dsam310, Mar 24, 2024.
  1. Mar 24, 2024 at 6:11 PM
    Dsam310
    Dsam310 [OP] Member
    Alex
    2020 Cement Tacoma Off-Road 4x4
    I’m going to cut to the chase.
    I’m looking for advice on what to do, within the past year I’ve had my windshield replaced on my 2020 Off-road 6 times under warranty through Safelite. The windshield keeps leaking usually from the passenger side but after this last replacement, from the drivers side. Was without my truck for 2 weeks due to the water damage cause by one of the leaks (their insurance paid for my upholstery to be dried out and repaired) and I’m at a point where I don’t know what to do anymore. Had the windshield replaced twice last week so it could be resealed and after this last time it is STILL leaking. Has anyone had an experience like this? Should I ask for a refund? Should I let them keep at it so they can be responsible for any damages in the future? I have no faith that they can even get the job done right anymore.
  2. Mar 24, 2024 at 6:18 PM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    Try another vendor. They fixed my truck and put a 2 inch crack in it. Told me before they started tht they might crack it. It hasn't leaked tho.
    Dsam310[OP] and Chew like this.
  3. Mar 24, 2024 at 6:28 PM
    MGMDesertTaco
    find another shop; that's ridiculous.
  4. Mar 24, 2024 at 6:28 PM
    Big Cole
    Big Cole Well-Known Member
    Did you initially file an insurance claim with your auto insurance carrier for the first replacement windshield? If so, I'd contact your insurance provider and tell them the work was not completed properly and you want the windshield replaced by another company.
    Dsam310[OP] likes this.
  5. Mar 24, 2024 at 6:35 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    sell that sum bitch, And did they use your truck for the new mad max movie wtf.If you were in the inland empire i could recommend you a friend that knows a friend
  6. Mar 24, 2024 at 9:04 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Yeah, time to find a new shop thst is simply pathetic. Everywhere will get a leaker once in awhile but that is just baaaad.
  7. Mar 24, 2024 at 9:25 PM
    Shellshock
    Iowa
    Yep. They did $5000+ in damage to my truck replacing the rear window (window wasn’t put in properly, broke all the plastics in the pieces removed in the cab, dented the room and scratched up the paint). Their insurance covered me getting it fixed somewhere else and they wanted to replace the glass again instead of having another shop do it. Body shop was like …you guys are the ones that caused this mess in the first place, we are gonna have a place we trust do it.
    I’ll never have work done there again and highly encourage others not to as well.
    I’d go in and talk to the manager. Tell them that they’ve replaced this multiple times and can’t seem to get it right so you want them to refund you or cover having someone else do it. Worse that happens is they say no.
    either way, I’d quit wasting time with them and go to an independent glass shop. I sure wouldn’t have given them 6 chances..
    Dsam310[QUOTED][OP] likes this.
  8. Mar 24, 2024 at 9:34 PM
    mikesixtysix
    mikesixtysix Well-Known Member
    North Jersey
    2018 TRD Pro
    is this oem or aftermarket glass?
  9. Mar 24, 2024 at 9:43 PM
    miniracer
    miniracer Member
    2017 AC SR 4WD
    Have you seen the truck with the windshield removed? I’ve seen threads on a 4Runner where Safelite cut through the firewall with the tool they use to cut the windshield out. Sounds like it’s pretty easy for an inexperienced glass guy to do on certain vehicles.
  10. Mar 24, 2024 at 9:46 PM
    Veet-88
    Glass brand doesn't matter when it comes to leaks it's all about the monkey doing the work.
    Shellshock likes this.
  11. Mar 24, 2024 at 10:09 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Tell that to people looking through wavy safelite glass.
    Blak Shinobi likes this.
  12. Mar 24, 2024 at 10:12 PM
    Veet-88
    We are talking about a persistent leaking issue not defects in the vinyl layer.......
    As a previous glass tech that worked for a larger franchise group then a Toyota dealership I can tell you all glass brands come with defects. Oe oem oee, doesn't matter. What does matter is proper inspection prior to install. If you leave with defective glass regardless of brand this falls onto the tech. It's on the tech to clean as inspect the new part before cutting out the old part.
    So I revert back to my previous statement it all comes down to the one doing the work.
  13. Mar 24, 2024 at 10:25 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    They told you before replacing your windshield they might crack your windshield? How does that work?
  14. Mar 24, 2024 at 10:56 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    That’s a bummer man.
    Not sure how people can be so bad at doing windshields? I had safelight come out to my work and replace mine. I helped the guy do it because my ditch lights were in the way and it would have been hard for one man to do. Helped removed the old one and put new one on…seemed super simple … hard to mess up lol.
  15. Mar 24, 2024 at 11:53 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    SIX times? And you never thought to change your actions until now?
    Chew and 23MGM like this.
  16. Mar 25, 2024 at 12:29 AM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Take it to a body shop. It's likely the surface is rusty around the channel where the seal sits and not the glass. Let the shop take it down, respray it and call in their glass guy. It might be costly, and you will lose your windshield and you'll be without your truck for a few days, but it'll be done right, and you won't have to keep throwing windshields on a damaged surface and be stressed out over leaks.
    Canadian Caber likes this.
  17. Mar 25, 2024 at 12:41 AM
    MGMDesertTaco
    We need to start a thread for reputable glass installers by state. :popcorn:
  18. Mar 25, 2024 at 12:44 AM
    23MGM
    2023 TRD Off Road
    So, I currently have a crack and I was actually planning on going to Safelite tomorrow to inquire about them replacing it. So, does anyone have any recommendations reputable places in the Portland, Oregon area?
  19. Mar 25, 2024 at 11:29 AM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Sadly safelite has bought up pretty much all the small glass companies in my area or pushed them out of business.
  20. Mar 25, 2024 at 11:34 AM
    mikesixtysix
    North Jersey
    2018 TRD Pro
    Maybe I saw it here, but someone said if you go to Safelite, always ask the person at the front desk for an experienced installer, and that you don't mind waiting... which is what I did, the guy said sure, no problem. And while I did wait an extra hour, I had zero issues, and went with the OEM glass, which Geico covered anyway.
