Windshield molding??
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyoTaco02, Mar 12, 2017.
  1. Mar 12, 2017 at 8:24 AM
    ToyoTaco02
    ToyoTaco02 [OP] Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Does anyone know if the black molding around the windshield is removable without having to remove the windshield? I was just looking at putting a new one on but didn't know if it was installed when the windshield goes in or after the fact.
  2. Mar 12, 2017 at 8:58 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Yes it is. The windshield is glued in and then the trim is installed separately.
  3. Mar 12, 2017 at 9:26 AM
    ToyoTaco02
    Scott
    Decatur,IL
    Do you know if it snaps in a groove or if it is glued in?
  4. Mar 12, 2017 at 9:59 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm also wondering the same thing. The black molding on mine is cracking and fading from sitting in the sun for 20 years. Anyone have a part number?
  5. Mar 12, 2017 at 10:35 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Yes, it can be changed separately. It seems to snap in a groove around the windshield
    part number for the black molding is :
    75531-04010 (cold climate spec)
    75531-04020 (without cold climate spec)
  6. Mar 12, 2017 at 1:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What's a cold climate spec? The truck was purchased in Fremont, CA (same place it was manufactured at NUMMI). Been here all its life.
  7. Mar 12, 2017 at 1:51 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I have the cold climate spec, it includes a channel for water around the edge of the windshield (little less sleek looking), a more powerful starter for cold weather, a thicker cover for the washer fluid bottle, and in super cold climates you can get a block heater too.
  8. Mar 12, 2017 at 5:32 PM
    onakat
    Canada
    2000 indestructaco!
    yep, exactly. Stuff specific to cold climate areas
    If the truck never left california, I highly doubt you have the cold climate spec
  9. Mar 12, 2017 at 5:49 PM
    Saylorsglass
    Saylorsglass Member
    Jeff
    1998 2.7 regular cab 4x4
    I actually install windshields for a living, if you can get the old molding out without removing the glass or breaking it let me know how. Generally when I install the windshield in a first gen Tacoma I put the molding on the glass and use tape to hold it in place until the glass is set into the urethane which holds it in. Once the glass is in place the urethane should contact the glass and molding to hold it in place once the urethane sets up. Even if you manage to get the old molding out without breaking your windshield, you'll probably never get the new one to push in the space between the glass and body of the truck and look right.
    Area51Runner, majkjems and Dalandser like this.
  10. Mar 12, 2017 at 7:29 PM
    ToyoTaco02
    Scott
    Decatur,IL
    Ok thanks for the advice!! I was wondering if the molding went in when the glass was installed.
  11. Mar 12, 2017 at 8:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Any advice for someone who's looking to get their windshield replaced? (Sorry about the thread hijack :threadjacked:)
  12. Mar 12, 2017 at 8:19 PM
    Speedytech7
    Don't buy one that's opaque :p
  13. Mar 12, 2017 at 8:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I watched this video a long time ago and remembered it now that I need a windshield (cracked all the way across on my first gen). Figured I'll leave it to a pro. I just wanted to have some good advice of what to ask anyone who's giving good deals in my area. :thumbsup:
  14. Mar 12, 2017 at 8:25 PM
    Speedytech7
    Not an endorsement by any means but Safelite is seen all around where I live and they'll come to you and do the install while you're at work or whatever. My windshield was replaced before I received the truck and it is made by Pilkington.
    Dalandser[QUOTED] likes this.
  15. Mar 12, 2017 at 8:31 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Apart from the install quality, I'd make sure they use an OEM spec windshield. Seems the two most common 'OEM' aftermarket windshields I notice are PPG and Pilkington.
  16. Mar 12, 2017 at 8:35 PM
    Speedytech7
    Anything but the actual Toyota windshield will be inferior in protection and resistance to cracking, my Pilkington has tons of little chips. But really they cost too much for it to be worth it for trucks so old.
  17. Mar 12, 2017 at 9:25 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    My oem one has 100s of little chips as well.
  18. Mar 13, 2017 at 1:07 PM
    Saylorsglass
    Saylorsglass Member
    Jeff
    Toyota actually uses windshields made by Pilkington and various other companies. Auto manufacturers don't make their own glass, they just put their logo on it. Look at a newer Camry and below the Toyota logo it actually says Pilkington
    cruiserguy likes this.
  19. Mar 13, 2017 at 1:14 PM
    Saylorsglass
    Saylorsglass Member
    Jeff
    I actually replaced my windshield last month and I used a Pilkington brand. The company I work for primarily uses Pilkington and pgw (ppg). They seem to be the best quality out there. The main thing when getting your windshield replaced is to find a company that offers a lifetime warranty, and has good reviews. The company I work for is only in Kentucky. I'm not sure what companies are are the Area that you live in, but from my experience the safelite guys are undertrained. They don't pay them well or seem to care about quality.
    Dalandser and cruiserguy like this.
  20. Mar 15, 2017 at 11:25 AM
    Saylorsglass
    Saylorsglass Member
    Jeff
    This was the factory logo on a 2013 highlander windshield I replaced this morning.
    cruiserguy and Dalandser like this.
