Windshield fogging up all the time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bennett, Aug 26, 2012.
  1. Aug 26, 2012 at 10:20 AM
    bennett
    bennett [OP] Well-Known Member
    Bennett
    Georgia
    08 SR5 4X4
    5100s on all 4 corners(Fronts at .85); Eibach Coils; Toytec Diff Drop; Toytec Top Plate Spacers; Toytec AAL; 285/75R16 MTZs
    Whenever I drive in the morning or at night, I can't keep my windshield from constantly fogging up. Playing with the a/c settings and defrost doesn't seem to help at all. Turning defrost on gets rid of the fog but leaves so much condensation that I still cant see without turning my wipers on, and as soon as I switch it back to panel, it fogs up again. Where I live in central GA its about 75-80 degrees in the morning. Anybody else have this problem?
    I married my tacoma likes this.
  2. Aug 26, 2012 at 10:23 AM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Sometimes this happens to me not a lot. But I turn the air on to the windshield and have to blast cold a/c on it. Works for the few times it's happened
  3. Aug 26, 2012 at 10:24 AM
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    Here in SC on the coast it is the same way. Have to defrost with heat all the way up in the morning. During the night time I normally just keep it on low heat defrost until it goes.
  4. Aug 26, 2012 at 10:35 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I get a little bit in the bottom middle portion of my windshield in the mornings during the summer. Turning on the wipers gets rid of it. I find in the summer time, the defrost doesn't really do much since the condensation is on the outside.
    The only time I use my defrost is if I park outside during the winter and I need to defrost the windshield while the truck is warming up. Otherwise, I just run the A/C all the time...winter or summer and it keeps the windows from fogging.
  5. Aug 26, 2012 at 10:41 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    That shouldn't fog up that bad all the time. I wonder if you have a leak with water getting in somewhere. Possibly a clogged drain for the the a/c... Just throwing out guesses here. That does not seem normal.
    HillJackJDS likes this.
  6. Aug 26, 2012 at 10:41 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It might be worth checking that your fresh air/recirc door moves. You can watch it moving right above the cab air filter if you push the button with the key on. Check you cab filter while you are there.
    Otherwise, sounds fairly normal for cool, high humidity situations. A bit of heat with the defrost will keep the condensation off the outside of the glass.
  7. Aug 26, 2012 at 10:42 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Good call, check that too.
  8. Aug 26, 2012 at 10:55 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Do you use Armor All on the dash??
  9. Aug 26, 2012 at 12:15 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    On older cars, this was the heater core.
  10. Aug 26, 2012 at 12:32 PM
    huntman92
    huntman92 Hunter
    hunter
    chattanooga tn
    06 tacoma
    6 inch fabtech. budbuilt bar. trd intake and exaust. 2 jl 10's. train horn and more
    mine does same thing. I'm in chattanooga tn.
  11. Aug 26, 2012 at 12:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x3 on the AC drain.
    Or perhaps stop masturbating while driving?:D
  12. Aug 26, 2012 at 1:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Also, never use Recirc when the AC is not running.
    Recirculating the cab air will just add more of your sweat and exhalation and fog up.
  13. Aug 26, 2012 at 11:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I live in coastal SC and have the fogging issue also. Crack the rear window and the drivers window. The fresh air coming into the rear will keep it cleared.
  14. Aug 26, 2012 at 11:40 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    It's a good indication that your cabin air filter may be dirty as well. Clean it or replace it and see what happens. Worked for me.
  15. Aug 27, 2012 at 3:46 AM
    MSCOFF
    MSCOFF Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    I had a similar problem in an old Mazda 323. A mouse had made a nest in the duct work going to the windshield. Trapped the moisture, slowed airflow, ect. going to the windshield.
  16. Aug 27, 2012 at 4:06 AM
    lipster
    Northern MN
    License plate frame
    Do you use Armor All on the interior?
  17. Aug 27, 2012 at 4:20 AM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Did you get the hooker under the dash option? Sometimes she overheats and causes condensation on the windows.
  18. Sep 2, 2012 at 9:41 AM
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    I have before
    Where are the cabin air filter and recirc door located?
  19. Sep 2, 2012 at 10:27 AM
    lipster
    Northern MN
    License plate frame
    Use of Armor all can fog the windows, something they don't ever tell you.
    If you haven't used it in 6 months or so, it is likely something else.
    I use the stuff rarely, because my windows always have a film on them if I use it.
  20. Sep 2, 2012 at 10:39 AM
    yarik83
    yarik83 Well-Known Member
    Yuri
    Florida
    2016 TRD SR5 DoubleCab 4x4
    Lift kit, weight distribution hitch. Camper shell. Kayak Rack.
    Go to any scuba shop and look for defog. It is called "SPIT", Anti-fog, Seadrops etc. There are many brands. All are made SPECIFICALLY to defog scuba masks while diving and all work.
    Each bottle is small but will be more than plenty to defog all of your windows. You do not need a lot of it either...
    Goal is to apply it to glass and rub it in by swirling it. Surface will look slimey and disgusting. Let is sit and dry for about 10 minutes. Grab regular paper towels and start swirling lightly. In seconds you will see dried off swirls turn into clear film. Film will last you for about 3 months or so. Each bottle costs about 5 bucks.
    I scuba dive so I have ample supply of defog anyways.
