Window Tinting and Privacy Glass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mdowling56, Sep 7, 2012.
  1. Sep 7, 2012 at 10:27 PM
    Mdowling56
    Mdowling56 [OP] Member
    Orange County
    Drives like caddie... But it's a truck
    So the 2012 and 2013 double cab comes equipped with what Toyota calls "privacy glass" on the 3 rear windows.
    I like what they were going for, but as someone who always throws a full tint job on my vehicles Im a little conflicted... It just needs to be a little bit darker!
    So this leaves me with two questions:
    1) would it be reasonable to throw very light film over the privacy glass to make it just a bit darker?
    2) what are the chances that my local tint guy can match after maket film for the fronts to the factory privacy glass on the rears?
    F the Sun!
  2. Sep 7, 2012 at 10:30 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    On my 08 20% matches very nicely to the rear windows. I think they are somewhere between 20-30% but not sure the exact percent, I'd say go with 20 up front and see what it does. I know I wanted to tint the rear but changed my mind after tinting the front.
  3. Sep 7, 2012 at 10:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stock front windows meter at around 70%, so putting 20% on top of that gives you something closer to 14%
    You can put film over the stock rear glass to darken is a bit more, it'll work just fine since the stock glass is actually tinted and is not a film.
    Edit... I see you're in Orange County, assuming California.
    Don't go darker than 30% on the front.
    It's still illegal, but I've never had a cop give me any shit over 30%.
    Trick is to get the front a fair amount lighter than the rear so there's an obvious difference, and so the cop can still see inside the front windows. It makes cops really nervous when they can't see what's going on inside.
    If you get pulled over at night, turn on the interior light before he gets to your door.... makes for a much more pleasant conversation.
    Larzzzz and Marc70 like this.
  4. Sep 7, 2012 at 10:37 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Wow well I was wrong...listen to rich.
  5. Sep 7, 2012 at 10:43 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i’m thinking 15%on front and maybe 30% on back. i want to see out some at night in dart places. so i don’t want back to dark.
  6. Sep 7, 2012 at 10:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    30% on top of the privacy glass will total around 5%... that's "limo" dark. You aren't going to see out of it at night.
    And honestly, 15% on the front, you're going to have issues at night if the street lighting is not good.
  7. Sep 7, 2012 at 10:47 PM
    Mdowling56
    Orange County
    I've done full front and back tint on the last 3 vehicles I've had... Can't live without it now.
    I totally subscribe to the "way darker in the back" theory. In fact, my father in law is ex LAPD and his stance is "if I can see in, fine... If I can't, you get sited"
    Think I'm going to try and go limo on the side rears and maybe 20-30% on the fronts and rear slider.
  8. Sep 7, 2012 at 10:51 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok. hmmm. may not do back at all than.
    and i have been in a car with 15 all around and could see out pretty good. car did not have privacy glass before it was tinted.
  9. Sep 7, 2012 at 11:25 PM
    Losrocket
    Losrocket Well-Known Member
    Carlos
    AZ
    I just had my '10 DB front side windows tinted with 20% and from the outside they look almost spot on to the rear windows but inside the front windows are noticeably darker. The rears look like 35% from the inside compared to the 20% on the front windows if that makes sense.
  10. May 11, 2014 at 1:04 PM
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    I just got my fronts tinted at 50%
  11. May 11, 2014 at 1:18 PM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    20% on the back three windows and 5% on the front and brow strip
  12. May 11, 2014 at 1:28 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Back windows are factory tinted at 20%. That is the actual window (not tint over window) like Rich said. If you tint your front windows 20% they will match the back perfectly.
    Had my front 2 windows not been tinted when I bought my truck I would have put 5% all the way around (excluding the windshield of course). That said.... That is illegal but for some reason not enforced here. I like the idea of being able to put up my shade in the windshield and NO ONE being able to see inside my truck.
    I have put 5% on every vehicle I've owned before this truck and yes it makes it difficult to see out the back at night while backing up. I just learned to live with it and rolled the windows down. Side windows weren't so bad but still rolled them down while backing up. Basically my windows were like a K-9 unit vehicle.
    Mine are just factory tinted now with the exception of the front's at 35%. My personal rule of thumb is if I get pulled over (can't remember the last time that happened) I roll my front and rear windows down and keep my hands on the wheel as they approach so the officer can see inside the vehicle while walking up to it. I can't imagine what it must feel like walking up on a vehicle and not knowing what is going on inside.
    I in no way advocate tinting darker than the law and laws vary widely from state to state. Basically here I think you could spray paint your windows and they wouldn't care. Hell.... some people here are actually tinting their windshields. :rolleyes:
  13. May 11, 2014 at 4:08 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    I have the same...
  14. May 11, 2014 at 5:55 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    what is your over-all goal?
    total black-out would be double 5% rear doors and back glass, single 5% on front doors to allow you to see
    just matching OEM, a 'smoke' pure black high grade 20% should do good like other member said
    but
    with 20% or so on all the windows i found on the tacoma the pass-through light makes putting 20% on the front doors almost see through! like no tint being there at all because of the back light from the other windows.
    if you want privacy and to stay 'close' to legal, we need to eliminate the back lighting.
    so if you want shade and privacy, i recommend, double 5% on rear doors, single 5% on back glass so you can still see fine, the longest windsield strip allowed legally, again 5% and put around 23% to 30% or even maybe 35% on front windows.
    you kill the back lighting, and still can see out the back, and a LEO can still see your shadow behind the front windows and most likely will never mess with you. :)
    tacomas are easy, they are close to smoke black, my RX was a chore, it comes with silver mirror, i think 40& or 50% on back, none on front, to match we did 5% black on rear doors and hatch, on the OEM glass, then i think 20% platinum on the front doors and 2nd layer 20% smoke black to get it to match. :) check out the middle RX, thats what not matching looks like :)
    side note, you post made me go looking for a picture of mine with the oem glass, i realized the only picture i had of her when she was brand new and stock was taken on a poloroid camera by the insurance agent about 30mins after i bought it :( never took a good pic before we started tearing her down like 30mins after that picture :(
    cheers,
    disco
  15. May 11, 2014 at 9:31 PM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    I put 20 on top of the privacy glass, looks great, still not ultra dark imo
  16. May 11, 2014 at 9:48 PM
    deesz
    deesz Member
    darren
    sacramento
    13 4x4 trd
    under construction
    I put 50% on the back half which puts me at about 15%,35% on the front two and 50% on the windshield. I love it and will always put 50 on the windshield. However does get dark at night.
  17. May 11, 2014 at 10:14 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    1) Yes
    2) Yes
    I like a 5% all the way around on my vehicles. (I know this is not legal, I have never been pulled over for it in 15 years) My tint guy ran a 15% on the back windows along with privacy glass and then ran 5% on the front two side windows and it looks great.
    Your local tint guy will be able to tell you what different percentages to put on the windows in order to get them all to match closely enough that you won't be able to tell they started off different shades (Privacy backs vs clear fronts). If he can't tell you that, then find another guy.
  18. May 13, 2014 at 10:58 PM
    discoy2k
    DISCO
    NOLA
    man i only knew one other person who tinted the windshield, lol. my cousin did it on a CTS and i borrowed it one night and was driving, kept rubbing my eyes thinking what the hell? so i called him and said man i dont think your headlights are working? he laughed and told me the windshield was tinted, LOL! not sure what percent he had, but it was HARD to see, considering double 5% on the other windows and knowing how much of an idiot he is, he prob put like 20% or even darker on the windshield, heh! but i like your idea of light tint on front, may try that :)
    if you kill some of the incoming light, even just a tad, then you can have less tint on the other windows... nice idea bro
    cheers,
    disco
  19. May 13, 2014 at 11:22 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    20% on the front measures darker than the back on the 2014 you can see the difference when you look at a light background through both windows at the same time. Looks off to me when the front is darker.
    BTW the meter reads 77% for the fronts on the 14. Always check the data sheet, there are 20 out there that are actually 28% light transmission. A real 30 in the front turns out to be 23% (0.77x0.3) vs 20% in the back, which looks good. Matching the actual color is another question...
  20. May 13, 2014 at 11:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Isn't " double 5% " kinda like 10% ?
    pat's taco likes this.
