Window off track
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rubs01Taco, Mar 16, 2016.
  1. Mar 16, 2016 at 10:43 PM
    Rubs01Taco
    Rubs01Taco [OP] Well-Known Member
    Ruben
    Fullerton, CA
    01 PreRunner SR5
    Flow master,
    everytime I roll down my driver side window I have to push it down. It seems Ik it's of the track. Has anybody had this problem if so what did u do to fix it.
  2. Mar 16, 2016 at 10:46 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is it power or manual?
  3. Mar 16, 2016 at 10:50 PM
    Rubs01Taco
    Ruben
    Fullerton, CA
    01 PreRunner SR5
    Flow master,
  4. Mar 16, 2016 at 11:47 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Is the window super loose? Can you lift it by hand a bit? Its possible the rollers broke and it's coming off track, but if it did that it would probably be all fucked up and rotating too. Or is it just not going down all the way Because the motor is petering out? Like, is it getting stuck? Or just stopping?
    If it's getting stuck, and hard to push or pull, then it's probably off on the SIDE tracks. If it's just stopping, it's probly the motor. If it's loose and will pull up or down by hand, it's probably the regulator which has the rollers and horizontal scissor tracks.. Either way, you can get a whole new motor/regulator assembly on eBay for like $40. Easiest way to tell for sure is to take your door panel off and have a look as you roll it up or down. Take panel off and reattach the switch temporarily to roll it and have a look.
    DustStorm4x4 likes this.
  5. Mar 17, 2016 at 12:17 AM
    Rubs01Taco
    Ruben
    Fullerton, CA
    01 PreRunner SR5
    Flow master,
    Thanks for the info.
    I can tell it's not the motor because when I power it Up and down it does not struggle, but it seems whatever holds the window in place is not doing its job. I wondering if there's a pic. Or schematic of the track holding the window in place. Also window is not loose.
  6. Mar 17, 2016 at 2:46 AM
    NightProwler
    Harlan
    Maricopa, Az
    Not sure about a schematic, but here's a pic of the vertical side track, from a write-up I never got around to posting, heh. Hope this helps. If you want I can put together the write-up and post it up. Might help you get it fixed. Not too hard to do if it is just off track. The window door panel will come off, and the window will need to be unbolted (should be two bolts) from the regulator. Pulled up and out most likely, then wedged back in the tracks properly.
  7. Mar 17, 2016 at 8:16 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    sounds like it came loose from the retension clip or the clip broke.
    there is a clip that is epoxy glued to the glass at the bottom to hold it and that holds it to the scissor mechanism.
    see what it looks like here:
    CowboyTaco likes this.
  8. Mar 17, 2016 at 8:42 AM
    Rubs01Taco
    Ruben
    Fullerton, CA
    01 PreRunner SR5
    Flow master,
    This is exactly what I needed to know thanks a lot guys, very much appreciated!!
  9. Nov 18, 2017 at 3:11 PM
    bushcrafterJ
    bushcrafterJ New Member
    J
    2005 2.7 5spd base access cab
    11' sport honeycomb grille 11' updated sport headlights. 15' taillights. 8 tie down cleats. OEM bedmat. 235 75 15 COOPER DISCOVERER LSX
    I have manual windows on my 05 base access 5spd. The driver side was weird a while back, would flop down about a inch after rolling it down a couple cranks. Then more recently it got crooked and I'd have to push it to the rear side as I cranked it up just to get it to close nicely. Today I took the door panel off *easy peazy wow I was surprised. When I got in there I found two 10mm bolts had completely come out lol. One fell on the floor as I pulled the clear plastic dust cover out of the way, the other was inside the door laying there. I rolled the window down all the way and sure enough two spots to bolt them into the crank mechanism lined up with two bolt holes in the door skeleton. Bolted them in tightly and boom perfect again. I went ahead and cleaned out both side tracks, first with armor all cleaning wipes, then with water / blue shop towels.
    When I put the door panel back on, the black piece that pops into place on where the mirror is, it was loose. I took two of the white squeeze tabs out, and placed them onto the black piece then pushed it all together. Had to super glue one of the black tabs that I put the white squeeze snap part on since it was cracked and loose. It's all tight and perfect now, window cranks perfect, smoothly and aligned perfect.
    Very happy with the results. Thanks for the thread guys!
    JFS likes this.
  10. Sep 9, 2022 at 1:00 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    This is my issue currently. New clip on order. Should be here monday. Now just gotta figure out adhering it to the window.
