Window master switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by d0ugh0ck, Feb 7, 2022.
  1. Feb 7, 2022 at 3:05 PM
    d0ugh0ck
    d0ugh0ck [OP] Well-Known Member
    NJ
    Any reason why switching the master switch on my SR5 to a TDR pro wouldn't work? Wanted both front windows auto up and down. Plugged it in and nothing.
    Bought on ebay so a bad part is possible.
  2. Feb 7, 2022 at 3:10 PM
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    I don’t believe the switch controls the auto up/down feature, that may be controlled by the body control module as in programming.
    shakerhood likes this.
  3. Feb 7, 2022 at 3:19 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I'm also not sure if it's a direct swap, requires some tinkering in Techstream, or something else, but did you try the "programming" steps?
    Turn the ignition on, but don't start the truck.
    All of the windows should be fully closed.
    Depress the driver's side window switch to roll it down, and hold the switch for about five seconds after it is down all of the way.
    Pull the switch up to raise the window and hold it for about five seconds after it is all of the way up.
    If that works, repeat the steps for the passenger side window. If not, more research is required.
    9TRDTCO likes this.
  4. Feb 7, 2022 at 3:22 PM
    d0ugh0ck
    NJ
    I will give this a try
  5. Feb 7, 2022 at 9:30 PM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I get this description for the part number on the left:
    • Description:
      Without full auto. Tacoma. Left. Double cab. With one touch up/down. Highlander. Without limited.
    and this for the one on the right:
    • Description:
      Tacoma. Left. Double cab. Without one touch up/down.
    my guess is that the "one touch" is a two part system. one the switch has to be able to "click in" for the one touch (also so that it is labeled on the face properly), and the other is the body control module needs to know how to interpret that signal. Are you getting zero movement at all from the new switch or just missing the one touch function still?
  6. Feb 7, 2022 at 9:42 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    I have the same suggestion. When I replaced my battery I had to do the “programming” steps and the auto function wouldn’t work. I strongly believe the switch activates the auto up/down because it has a second step to it when pushing. Best of luck op!
  7. Feb 8, 2022 at 4:26 AM
    d0ugh0ck
    NJ
    Getting zero movement. Even from the back windows. So I don't know if I just got a bad switch.
  8. Feb 9, 2022 at 1:00 AM
    Absolut_Boost
    Cincinnati, OH
    @caribe makaira had a wire diagram in here earlier that is gone now. maybe he can give you some insights on what you can test with a multimeter to see if the panel is good or not.
  9. Feb 9, 2022 at 8:27 AM
    tacomalex1949
    tacomalex1949 Well-Known Member
    Alex
    2021 Tacoma DCSB
    Is this just a cheap sell to get people to buy the higher trim? My wife’s Volvo costs about the same comparatively and she has all four windows auto up/down. Seems like that could very easily be standard in cars…
    batcat420 likes this.
  10. Feb 9, 2022 at 11:26 AM
    caribe makaira
    Caribbean, Puerto Rico
    OP ignored it.
    Wiring to switch is different from his model to the model that has the feature. Better off selling switch module
    Absolut_Boost[QUOTED] likes this.
  11. Feb 10, 2022 at 8:10 AM
    Absolut_Boost
    Cincinnati, OH
    There is your answer OP, sorry. Thanks for the reply caribe.
  12. Feb 10, 2022 at 8:14 AM
    caribe makaira
    :hattip:
  13. Feb 21, 2022 at 2:56 PM
    batcat420
    batcat420 I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    Seriously. Our base-model Prius also has auto on all four windows.
  14. Feb 22, 2022 at 7:26 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  15. Feb 22, 2022 at 8:49 AM
    batcat420
    Scott
    Atlanta
  16. Oct 21, 2022 at 12:23 PM
    batcat420
    Scott
    Atlanta
  17. Oct 21, 2022 at 12:32 PM
    twtaco$
    twtaco$ Well-Known Member
    I just want my drivers window to power up, powers down but not up. ugh My basic kia even does this.
  18. Oct 21, 2022 at 1:16 PM
    batcat420
    Scott
    Atlanta
    I hear ya. KTJO4x4 is working on a product for that, too.
  19. Oct 21, 2022 at 1:32 PM
    twtaco$
    Oh man can’t wait for that. Just think I used to roll windows up down by hand lol
  20. Oct 21, 2022 at 1:45 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Let me reach out to the company that has one for 2nd gen auto up/down. They may have one i the works for 3rd gens. Im waiting on the unlock/lock lightup for the passenger on 2nd gen which does not light up.
