Wind noise from in channel window visors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thedude, Jul 21, 2011.
  1. Jul 21, 2011 at 2:26 PM
    thedude
    thedude [OP] Well-Known Member
    Lucas
    Little Rock, AR
    I installed Stampede brand in channel window visors last week. The reason I chose Stampede is because they were the only ones I could find that came in clear. I paint matched them super white to match my truck. The only problem I have is I'm getting a lot of wind noise now. Anybody had this problem or know how to fix it. The main disadvantage I've noticed with these over the EGR/Weathertechs is the front visors use 3M tape instead of "snapping" in. So if I want to replace them it's going to be a pita now getting them out. Any suggestions? Thanks.
  2. Jul 21, 2011 at 8:03 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    They come right off even with the 3M tape.My AVS visors were already on when I had my windows tinted.Dude took them right off,tinted the windows.When the tint was set and I could roll the windows down I put them back on with the same tape.The heat from the sun made the tape stick as good as new.No wind noise.What difference did it make if they were clear or not if you were painting them?
  3. Jul 22, 2011 at 5:16 AM
    thedude
    Lucas
    Little Rock, AR
    I painted the inside of them so I wouldn't have to worry about chips. I painted my bug deflector as well. They turned out great except for the wind noise. You notice any noise from yours?
  4. Jul 22, 2011 at 5:29 AM
    Norcan
    Norcan What we don't have we make.
    Jerry
    Elora, ON Canada
    11 Tacoma Double Cab TRD
    Bakflip F1, BakBox, Sportwing Colour matched door mouldings, Weathertech floor liners, Toyota running boards,Toyota Hood Deflector,Pop N Lock power tailgate lock, Custom Otterbox defender mount for IPhone 4, Blu Logic Large button kit, BonGiovi DPS, fog light on with parking light low beam and high beam mod, TRD Exhaust, Muth heated signal mirrors, Liquid Metal Rhino Wheels in Black!, Redline Elite hoodlifts, EZ down tailgate,
    I had the weathertech's on mine. The fit was good but there was some wind noise on the fronts. But the rear ones made a fair bit of noise. I took them off yesterday. I think if the tape was along the entire edge it would help. I also found it was a pain to was and dry the top of the windows. I don't think I will put them back on. Just my 2 cents worth.
  5. Jul 22, 2011 at 6:04 AM
    thedude
    Lucas
    Little Rock, AR
    I'm debating taking mine off too. If it was real minor wind noise I might live with it, but it's noticeable. I heard good things about the EGR visors, wonder if wind noise is ok with them.
  6. Jul 22, 2011 at 6:50 AM
    Dred777
    Dred777 Well-Known Member
    Ed
    Delaware, OH
    '11 TRD Off Road
    Nerf Bars, Color Matched UndercoverSE Tonneau Cover
    I have the Trail FX visors and was getting quite a bit of wind noise as well and was considering taking the back ones out. Unfortunately the decision was made for me when I went through one of those touchless car washes with the blowers. Blew it right off and broke it.:eek:
    Less wind noise but still get a little from the front ones.
  7. Jul 22, 2011 at 9:36 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Mine are Weathertech.
    I notice very minor wind noise from the driver door visor, but usually can't hear it unless I have the radio off.
    If I am driving through very strong crosswinds it sometimes is a little louder.
  8. Jul 22, 2011 at 9:45 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've had the EGR in-channel visors for a few years now and never noticed any wind noise.
  9. Jul 22, 2011 at 10:00 AM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
    I have EGR in-channel on my Taco and on my Ram 2500.......no noise. It's great driving with the windows down about 1". Plenty of clean air without disturbing the hair on the Minister of Finance
  10. Jul 22, 2011 at 2:06 PM
    OffroadToy
    The noise you get during a crosswind might be caused by the windshield seal...it happens with my truck doing around 70mph and is well documented here on TW. I believe there's a TSB fix for it.
  11. Jul 22, 2011 at 2:10 PM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    Ah, good tip... thanks.
    I'll prob just live with it. I am used to dealing with a lot of wind (I build windfarms).
    My bigger concern is usually watching how I park so I don't slam my hinges.
  12. Jul 22, 2011 at 7:41 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    egr in channels here and no wind noise...i had avs in channels on another truck(not a toyota) and the passenger one made noise unless window was rolled up just right
  13. Jul 22, 2011 at 8:07 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    X2
  14. Jul 26, 2011 at 11:05 AM
    thedude
    Lucas
    Little Rock, AR
    Thanks guys. I decided today I'm taking mine off. Pisses me off I spent the money and time to paint them, but o well. Not sure If I'll get EGR or just go without.
  15. Jul 26, 2011 at 3:07 PM
    pinktaco808
    pinktaco808 Hot Steppa
    lol very noisey
  16. Aug 2, 2011 at 12:27 PM
    thedude
    Lucas
    Little Rock, AR
    Man I tried getting these off a couple of days ago. They are stuck on pretty damn good. I didn't try very long but I couldn't get them off. I'll re attack when the temp falls below 105 :) But mine sure didn't come right off. Maybe because the tape is new and not older? Might try a blow dryer to loosen it up or WD-40
  17. Aug 2, 2011 at 1:02 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I have some from EBAY and they work great. I actually believe my truck is a little quieter with them on. And its nice to be able to leave windows cracked a bit. Nad best of all I onle paid $31.00 for them.
  18. Aug 2, 2011 at 1:50 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I have the AVS brand and they are very well made, the only thing I can say bad about them is, there must have been a small piece of plastic sticking off from production because the first time I rolled the passenger window down (after the 24 hour period) the window snagged the shade on the way up causing it to crack. I just snipped off the part the cracked and its all good but that is the only negative I can give about them. I paid like $65 for them and the work very well and I have not noticed any wind noise for better or worse after installing them.
