Winches......
Discussion in 'Product Reviews' started by Waunderin Will, Dec 4, 2021.
  1. Dec 4, 2021 at 11:07 AM
    Waunderin Will
    Waunderin Will [OP] Active Member
    2017 White TRD Off Road
    So far just a tailgate light bar and replaced the backup lights with LEDsl Eventually I'd like to put a topper on it but not many options out there yet. I'm leaning towards a Hi-rise type just for the room. But then again it would be nice to keep the truck in the garage :)
  2. Dec 4, 2021 at 11:21 AM
    RadioTaco
    RadioTaco Well-Known Member
    SoCal
    2019 MGM TRD OR DCSB
    Go with the Harbor Freight winch in this price range. It works surprisingly well for HF quality. A lot of people run the Badlands series winches, and they hold up pretty damn well.
  3. Dec 5, 2021 at 8:08 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I don’t know anything about the Rugcel winch other than it’s cheap. Generally cheap is not good and good is not cheap. I’d say if you have little need for a winch and will seldom use it , it’s the winch for you. If a person wants a winch mostly to look cool, look at me I got a winch, it’s probably the perfect winch.
    But if a person is serious about a winch, and will really use it , then stay away from cheap and go with a Warn or similar product. When you need a winch you usually really need it, and failure just isn’t an option.
    The Harbor freight winch has mixed reviews. A couple years ago a 4wd magazine did a review on winches. The Badlands winch didn’t work right out of the box. They couldn’t even test it. I have a friend who has a Badlands who uses it frequently to to pull logs to a spot where he can cut them up for firewood. He’s used his hundreds of times without a problem.
  4. Dec 8, 2021 at 7:14 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I never really heard of them either. However, as @Sprig said, it probably depends on use. Probably perfectly fine if you just want the look of having a winch.
    I had considered the Badlands winch several times, and heard good things about them. Then I saw this video posted:
    https://www.youtube.com/watch?v=iWx8b923cRo&feature=emb_imp_woyt
    The guys assessment is spot on. The winch shouldn't fail like that. Harbor Freight may have phenomenal customer service and replace the winch, but failure is not an option if you plan to actually use a winch. Think of it this way, an offroad recovery/tow is not cheap. I don't have any first hand experience, but I've read of $1000 tow bills. I would not be happy with a $1k recovery bill when my $300 winch failed. I wouldn't even really care if they replaced it for me free of charge. Stuck is stuck.
    There are some decent sales right now. AutoZone seems to have the best deal on Warn...$734 for a VR EVO 10-S (MSRP $960, IIRC). Smittybilt is probably the cheapest I would go for a winch.
    MJTH and Sprig like this.
  5. Jan 18, 2022 at 5:01 PM
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    Don't buy that.
    If you're going to a place where getting stuck could become a life threatening issue(no service, far from help)... absolutely don't buy it.
    If you have to depend on it... Don't buy cheap crap.
    lower your 4x4 and Grossomotto like this.
  6. Jan 18, 2022 at 5:10 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    This video of the harbor freight winch failing leaves out some important info.. the dude has an F-250 chained to a tractor and is trying to pull out a tree stump. There's no info on whether or not this exceeded the rating of the winch. Also.. it appears the housing failed and the winch continued to work (gtfo with the 'total fail' hyperbole.) This just looks like another attention starved vlogging "expert" to me.
    lower your 4x4 likes this.
  7. Jan 18, 2022 at 5:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  8. Jan 18, 2022 at 5:15 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
  9. Jan 18, 2022 at 6:40 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Doesn't the saying go... buy once cry once.
  10. Feb 20, 2022 at 6:06 PM
    ancient
    ancient Active Member
    2020 White Tacoma TRD OR
    Buy once cry once is right. Some things you just don't want to cheap out on. Warn is an extremely reputable company.
    Key-Rei likes this.
  11. Feb 22, 2022 at 9:57 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    Not only can it just “not work” but would be extremely dangerous for those near it if it snaps or malfunctions.
    ancient[QUOTED] likes this.
  12. Feb 22, 2022 at 10:07 AM
    Gen3TacomaOBX
    S
    So people don't have to take safety precautions if they overpay for the top brand name winch? cool. :thumbsup:
  13. Feb 22, 2022 at 10:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you're not spending $1000 or more it's made in China regardless of whose name is on it. Harbor Freight is as good as any other. I watched the video. Looked like abuse to me.
  14. Feb 22, 2022 at 10:18 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    I didn’t say that
  15. Feb 22, 2022 at 10:19 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    I will not buy anything from Harbor Freight. I have learned my lesson on a generator, jack stands, Vacuum. It is all junk. Also, not even cheap if you shop around and can wait for sales.
  16. Feb 22, 2022 at 10:19 AM
    JKO1998
    Utah
    My 12k XPower Winch from cal ranch as been great, and it’s cheaper than harbor freight
  17. Feb 22, 2022 at 10:34 AM
    Gen3TacomaOBX
    S
    Any winch can be "extremely dangerous for those near it if it snaps or malfunctions" so I'm not sure what you did say.
    Are you saying that with proper use... harbor freight winches are more dangerous than brand names? If that is true then I feel like you just might be able to earn a salary heading up a class action lawsuit with your objective data. Can you link to that data for us?
    Forgive me for being an a**hole but I see a lot of Bro posts shaitting on tools that don't match their purchasing decision with zero data to back up their claims (and stories of someone's 2nd cousin and sister that dun blow'd up a hobo freight tool doesn't fly.) I bet those same Instagram Bros buy their panties and dresses at Nieman Marcus because Macy's is too everyday. :bananadead:
    NmapFE likes this.
  18. Dec 16, 2022 at 5:01 AM
    Jarradg1126
    Jarradg1126 New Member
    2017 inferno tacoma trd
    A little late to this party, but I have 2 of the rugcells, 1 on a jeep one on the tacoma. Have used the one on the jeep multiple times never had a issue. But I do not do a ton of off roading or extremely off roading
    CowboyTaco likes this.
