Winch wiring. Fuse, breaker, or straight to battery?
Discussion in 'Recovery' started by Caddychris, Oct 8, 2019.
  1. Oct 8, 2019 at 2:32 PM
    Caddychris
    Caddychris [OP] Well-Known Member
    2019 TRD OR DCSB
    OME lift w/ SPC's Method 701's w/Toyo at2 265/70r17 Prinsu rack CBI skids and sliders SSO slimline bull bumper Smittybuilt 9500 winch. Swing out tool boxes
    Well, the title says it all.
    What do you guys with winches use in line, if anything, for your winch?
    I'm using a smittybilt 9500lb.
    Not sure what the max amperage draw would be. I'm assuming if I fuse/breaker it would be for what the cable is rated for?
    Any assistance is greatly appreciated!
  2. Oct 8, 2019 at 2:35 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    I run straight to the battery.
    Less things to go wrong and less voltage resistance.
    although it it’s a good idea to have it protected from shorting out
    whatstcp and Caddychris[OP] like this.
  3. Oct 8, 2019 at 2:35 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Fused as close to the battery as possible.....
  4. Oct 8, 2019 at 2:38 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    Looks like max pull can be just over 400 amps C763A497-9D93-4C6F-8434-15DAB32AD605.jpg
    Caddychris[OP] likes this.
  5. Oct 8, 2019 at 5:42 PM
    Caddychris
    2019 TRD OR DCSB
    Wow!!! That's crazy!
  6. Oct 8, 2019 at 5:50 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Breaker or fuse with disconnect close to the battery.
    TacoEspecial likes this.
  7. Oct 11, 2019 at 2:58 AM
    Justwandering
    Justwandering Well-Known Member
    1996 Land Cruiser, 2008 GX470
  8. Oct 28, 2019 at 8:51 AM
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
    Anderson connector close to battery.
  9. Oct 28, 2019 at 9:25 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What do the instructions on your winch say? Warn says to go direct to the battery.
    The winch itself should have internal circuit protection, and as long as you use the proper size wire based on max load of the winch, (bigger is better), then it's essentially impossible to "overload" the circuit.
    If you are concerned about it being hot all the time, use a power interrupt kit (switch and solenoid).
    Grossomotto likes this.
  10. Feb 14, 2020 at 11:37 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Anyone use one of these with a winch? The Warn EVO VR8 is rated at 295 amps so falls within the 300 amp rating of this circuit breaker. I see it as a combined fuse and disconnect switch in one package.
  11. Feb 15, 2020 at 2:20 PM
    HMM
    HMM Well-Known Member
    2020 TRD Pro
    I’m planning to run mine through a blue sea heavy duty on-off battery switch. I 3D printed a mount for the switch, just need to wire it up now. Currently it’s wired to the battery but I don’t like it being powered up all the time. I’d rather be able to pop the hood and turn it on once I pull off pavement and then be able to kill the power once I’m back on pavement.
  12. Feb 17, 2020 at 10:30 PM
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    Would you be interested in printing and selling another one of those mounts if it works? o_O
  13. Feb 18, 2020 at 9:09 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    A buddy @Gilmorec61 also makes these types of mounts I believe. Maybe he can help you out.
    HappyGilmore likes this.
  14. Feb 18, 2020 at 9:39 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
  15. Feb 18, 2020 at 9:45 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I use a 600A disconnect, it's off when winch is not being used. Seems like you might be asking for trouble if there is a short and you have no way to cut power.
    ohcaltexscar and HappyGilmore like this.
  16. Feb 18, 2020 at 5:32 PM
    Gat_
    Bay Area, CA
  17. Feb 19, 2020 at 9:32 PM
    HMM
    2020 TRD Pro
    I'll be happy to send you the file, the 3D printer is a buddy's and he did it at work so he can't do things for hire.
    The mount needs to be a little bigger and we didn't bring the holes, I drilled them afterwards.
    sbl23, frenchee and HappyGilmore like this.
  18. Oct 22, 2020 at 12:20 PM
    JVL1985
    JVL1985 Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    What are the risks if I follow the installation instructions in the manual and wire directly to the battery? I ran a Warn this way for many years in my previous Jeep and never had any issue.
  19. Oct 22, 2020 at 1:57 PM
    HappyGilmore
    Huntsville, AL
    Yes
    A potential fire risk in the event of a front end impact or if the wire insulation somehow wears off the wire. A 2 gauge wire grounding out can cause some gnarly sparks and heat!
    Installing a switch in-line can also mitigate parasitic draw on the battery in the case there was some kind of fault in the winch control box.
    I’ve developed a neat product for this specific application, check it out if you’d like!
    https://www.tacomaworld.com/threads/winch-switch-bracket-protect-your-investment.619464/
  20. Oct 22, 2020 at 2:18 PM
    JVL1985
    Thanks for your input. I wonder why companies like Warn and Smittybilt don't mention any of this in their manuals. Also, I would think they would be all over selling a product like yours as an accessory or just including a solution with the winch for competitive advantage.
    HappyGilmore[QUOTED] likes this.
