Winch mount in the bed of the truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seang, Mar 11, 2022.
  1. Mar 13, 2022 at 9:11 AM
    #41
    seang
    seang [OP] Eternal Noob
    TX
    17 White Off Road
    True. Ive done that before, but where is the fun in that? lol
    Im getting old. After a day of fishing in the heat, casting and paddling... well, ive already got my exercise in. haha
  2. Mar 13, 2022 at 10:30 AM
    #42
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I have one of these. I agree that their rope is too short for most uses, including the use that the OP wants however I have used mine a couple of times to pull a non-running VW Dune Buggy onto my trailer. The Dune Buggy weighs 1,500 LBS and the Warn Winch pulled it up with no problems, although I'm not sure the Inverter in our Tacoma's have enough output to power it; each time I've used mine I've either powered it off of a generator or ran an extension cord out to it.
    It's one of those things that I often forget that I have, but the few times I've needed it I've been glad that I did.
  3. Mar 13, 2022 at 5:03 PM
    #43
    fisherick
    fisherick Well-Known Member
    Rick
    Ma
    2016 Tacoma TRD OFF Road, AC, AT, Super White
    20" LED Bar, 265x75x16 S/T Maxx none
    Warn makes a 1000# portable winch powered by a cordless drill. Run a chain between your forward D bed rings to attach hook or pulley. If winch line too short remove the line and use a longer rope wrapped 2-3 times around winch spool and apply pressure to pull the load into truck with ramp.
    seang[OP] likes this.
  4. Mar 26, 2022 at 10:20 AM
    #44
    seang
    TX
    17 White Off Road
    Well, I done did it...
    I mounted a winch in the truck bed.
    Still need to route the wires, and do a little fine tuning.
    Here's the video the wife took on my 2nd test run.
    Tried a few more off camera and it gets easier.
    https://www.youtube.com/watch?v=gzLq4NUYuLI
  5. Mar 27, 2022 at 1:50 PM
    #45
    seang
    TX
    17 White Off Road
    MSN88longbed and Gettin Lost like this.
  6. Jan 7, 2023 at 8:24 AM
    #46
    fezdel
    fezdel New Member
  7. Jan 7, 2023 at 8:49 AM
    #47
    seang
    TX
    17 White Off Road
    Yep, pretty much made that for about 1/4 the price. Not sure if i would winch up an ATV with mine, but i wasnt trying to do that either.
    soundman98 likes this.
  8. Mar 7, 2023 at 10:24 AM
    #48
    scoostraw
    scoostraw Well-Known Member
    Ken
    Wisconsin
    1995 Tacoma 4x4 Ext Cab 6cyl 5-Speed
    I thought I would share what I did. Keep in mind though that this would be for light duty use only. In my case, I used it to winch up a non-running snowblower into the bed.
    No drilling. Took all of 5 minutes to mount.
  9. Mar 8, 2023 at 5:25 PM
    #49
    seang
    TX
    17 White Off Road
    Amazing idea.
  10. Mar 8, 2023 at 5:34 PM
    #50
    lbhsbz
    lbhsbz Well-Known Member
    Get one of these or another cheap portable winch. I would simply make a bridle (chain/rope/or strap running between 2 of the tie down rail things slid up near the cab) ... tether the portable winch to that chain/rope/strap, and you're in business....no drilling holes or permanently mounting anything.
    and yes, those little plastic hooks are plenty strong for this.
  11. Mar 8, 2023 at 5:36 PM
    #51
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Forgot to update mine into this thread. I have since swapped the winch to the bottom of the bars so it fits under my tonnaeu cover. Still need to wire up a plug in the bed, right now its runs on my trolling motor battery.
    Mounting is these bed rail mounts, there are 4 of them, 2 on the side rails and 2 on the header rail
  12. Mar 8, 2023 at 5:59 PM
    #52
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Block and tackle will suffice for doing it- an electric winch is overkill. We just tied in good webbing across the two tie points in the front of the bed and attached a pulley to it on a carabiner in the center to pull large decorative rocks weighing a couple hundred pounds each up a ramp and into the bed. I also have two Greenland II’s that I use the same system to pull them in after they’re rolled up.
  13. Mar 20, 2023 at 9:08 AM
    #53
    seang
    TX
    17 White Off Road
    This weekend i got to use my contraption for the 1st time since surgery.
    worked great.
    Pulled the fully loaded kayak straight from the water to the bed of the truck. Made for easy unloading of the kayak as well.
    MSN88longbed likes this.
  14. Mar 20, 2023 at 10:08 AM
    #54
    scoostraw
    Ken
    Wisconsin
    Good going seang!!
