Winch mount in the bed of the truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seang, Mar 11, 2022.
  1. Mar 11, 2022 at 11:03 AM
    seang
    seang [OP] Eternal Noob
    TX
    17 White Off Road
    I am considering mounting a winch in the bed of the truck. Possibly on the top of the wheel well.
    Reason for this is to assist with pulling my kayak into the bed of the truck. I am going to have an ankle replacement surgery and the doc doesnt want my dragging or pulling too much. Loading the yak isnt that hard normally, but pulling it up a hill can get rough on my ankle, and probably not much better after the surgery.
    thinking about using a pulley center mounted on the bed, maybe on the rail and having the winch mounted sideways with the line running through the pulley.
    Also considering building a ramp out of something to have it slide right up in the bed.
    I was looking at one of the more inexpensive harbor freight jobs because this wont be for pulling anything more than about 150 pounds into the bed of the truck.
    Any thoughts on the stresses applied to these areas of the truck bed?
  2. Mar 11, 2022 at 11:06 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The truck bed is fiberglass. Suggest tying the winch into the frame.
    ConantTaco likes this.
  3. Mar 11, 2022 at 11:10 AM
    seang
    TX
    17 White Off Road
    stripped down, about 80 lbs.
    with the seat, and some gear it can be as much as 120- 150.
    Not really wanting the expense of a trailer. Still would need to drag the kayak to the trailer also.
    Takemehome678 likes this.
  4. Mar 11, 2022 at 11:13 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Sorry. I deleted my post when I realized you said it was 150 lbs in the original post, but you beat me to the punch.
    Is 80 lbs too much to lift?
    Won’t you need to drag or carry it to the truck?
    Are also going employee a ramp for the winch to pull the kayak in?
    How will you get it out of the truck?
    None of this is adding up for me.
    SR-71A likes this.
  5. Mar 11, 2022 at 11:16 AM
    seang
    TX
    17 White Off Road
    Considering a ramp, yes.
    its not that 80# is too much to lift. its the dragging it up a hill. the angle of the force is not good on the ankle joint.
  6. Mar 11, 2022 at 11:22 AM
    gudujarlson
    Minnesota
    Ah I think I understand now. You want park the truck on top of a bank and then winch the kayak out of the water and up the bank to the truck. We do something similar with the boat hoist each fall.
  7. Mar 11, 2022 at 11:24 AM
    gudujarlson
    Minnesota
    You can buy hitch receiver thingies that you can mount a winch to.
  8. Mar 11, 2022 at 11:25 AM
    gudujarlson
    Minnesota
  9. Mar 11, 2022 at 11:30 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How about just using a pulley block in the nose of the bed with a long length of nice rope, then pull the kayak up by hand? Not sure if that would work for your situation, but would certainly makes things a lot simpler. Not having to run electrical to the winch just for starters.
  10. Mar 11, 2022 at 11:32 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    A hitch mounted winch won't help much getting it in the bed. Maybe attach a pully near the cab thru the bed attached to the frame.
  11. Mar 11, 2022 at 11:33 AM
    gudujarlson
    Minnesota
    The existing mounts in the bed or the hitch receiver could probably be used as well.
  12. Mar 11, 2022 at 11:34 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
  13. Mar 11, 2022 at 11:35 AM
    gudujarlson
    Minnesota
    He said lifting it into the bed wasn’t the primary issue.
    SR-71A and Matic[QUOTED] like this.
  14. Mar 11, 2022 at 11:35 AM
    Matic
    Tricky Dick
    Easley, SC
    How bout just a hand crank up near the cab on a piece of plate steel?
    mquibble and ConantTaco like this.
  15. Mar 11, 2022 at 11:36 AM
    seang
    TX
    17 White Off Road
    Running wires isn't a big deal, but they also make some wires you can temporarily attach to the battery like jumper cables.
    I like projects, and working on stuff, so all of this isnt to big of a deal.
    It would be kind of cool to have it just slide it into the bed, if im going to winch it anyway.
    Not ever seeing the underside of the wheel well, How hard would it be to put some reinforcement in there?
    Something to run some bolts though, then through the bed and use that as a winch mount?
  16. Mar 11, 2022 at 11:36 AM
    Matic
    Tricky Dick
    Easley, SC
    ahhh....Then I would just get a crank pully tyoe and attach it to the reciever.
  17. Mar 11, 2022 at 11:37 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  18. Mar 11, 2022 at 11:38 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So I am in a similar situation as you. I have spine damage and lifting my ice fishing sled or kayak is not a fun adventure.
    So, how we need to do this is start by making a PVC ramp for the kayak to go up, I will leave that part to you, but as for the winch mount there are 2 ways I have seen people mount them.
    1: Using 1x1 box steel you make a frame that bolts to the header rail and to the side rails. Then mount your winch to that. This would result in a winch line that is higher up.
    2: Using 1x1 box steel make a frame that bolts to the frame bolts at the front of the bed. Mounting your winch here would have the disadvantage of the winch taking up space that your kayaks front needs.
    3: You can use a pulley mounted to a chain that goes between your front tie downs, then from this pulley you put the winch near the tailgate. with this method you can use a small hand winch bolted right to the bed mount bolt. You can use a drill to turn a hand winch, or use your hand.
    1 is the best, but the hardest
    2 is the strongest but the most intrusive
    3 is the most hacky but the cheapest
    All 3 options will get the same result in the end, it just comes down to how much money, time, and effort you want to put into this.
    And as many will point out "the bed isnt strong enough to hold a winch" they are right, but they are also wrong since your dragging a 150lbs of plastic against more plastic that is slick or mud that is slick, or grass that is slick. Very little pressure will actually be put on the winch.
    Now since you are going to use it to pull up a hill, I would go with option 1 as it will help in loading and dragging it up the hill.
    Here are some examples (not 3rd gen tacomas, but ideas)
    andthen, mquibble, soundman98 and 7 others like this.
  19. Mar 11, 2022 at 11:39 AM
    gudujarlson
    Minnesota
    I personally would not modify my truck for this. This is just temporary until your ankle heals, yes?
    SR-71A likes this.
  20. Mar 11, 2022 at 11:49 AM
    SR-71A
    Zack
    Southern Maine
    I tend to agree with this. If its a temporary-ish situation, a boat trailer crank (like mentioned above) mounted to the front might be a good way to go. You could even modify it and power it by a cordless drill :D
    If you are set on mounting a small winch to the bed, probably would want to cut a piece of plate steel that goes under the bed. Mimic the bolt pattern and it sandwiches the composite to spread the load out a bit.
