winch kit
Discussion in 'Recovery' started by eddyizm, Mar 20, 2022.
  1. Mar 20, 2022 at 10:50 AM
    eddyizm
    eddyizm [OP] Well-Known Member
    2018 TRD OR DCSB 4x4 Cement
  2. Mar 21, 2022 at 5:09 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I assume you have wire rope?
  3. Mar 21, 2022 at 8:06 AM
    eddyizm
    Synthetic. Since posting this, I found some snatch rings made for synthetic rope which seem really cool.
  4. Mar 21, 2022 at 9:19 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Ok well you don’t really need the damper for synthetic rope and make sure the snatch block is made for synthetic rope I do believe there is a difference between the two
    Mark77 and eddyizm[QUOTED][OP] like this.
  5. Mar 21, 2022 at 9:56 AM
    eddyizm
    Thanks, really appreciate the information!
    Grey 2015[QUOTED] likes this.
  6. Mar 23, 2022 at 8:26 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I’d go name brand opposed to Amazon for load bearing recovery gear. I’m all for saving money but when a load rating is involved it’s hard to trust off brands.
    I’m running ARB for my tree saver, snatch strap, and damper (admittedly could go cheaper on the damper), and smittybilt for my snatch block. I have a few Crosby and arb shackles and a bubba rope soft shackle.
    E.J. likes this.
  7. Mar 23, 2022 at 8:57 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    Sort of yes and sort of no. At least not for the reason that you may be alluding to. Synthetic lines do recoil. See the video below. The reason that you likely don't need one is that it would pull through the damper before it starts to fall to the ground. Fast forward to the 15:30 minute mark. The rest of the video is also fun to watch. I don't know why anyone would still use a steel rope after watching this video. Also, really makes you want to get rid of any metal winching accessory.
    https://youtu.be/97XqNX3yFTk
    sbl23 likes this.
  8. Mar 24, 2022 at 6:13 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Correct me if I'm wrong, but it looks like they are use a Dozer to pull the cable beyond it's capacity causing it to snap. I would think a winch would stall out before that would happen. Now some idiot using damaged cable? Well that's another story and just plain stupid.
  9. Mar 24, 2022 at 2:47 PM
    eddyizm
    Fair enough and am I just wanted to bring this up to get feedback and input. I definitely agree - Are those ARB meant for steel /synthentic? I really like the snatch ring/shackle combo.
  10. Mar 24, 2022 at 2:48 PM
    eddyizm
    I was going to get a damper since it seems pretty damn cheap to not have one even on a synthetic. All this stuff is peace of mind and insurance anyways.
  11. Mar 24, 2022 at 2:52 PM
    plurpimpin
    PDX
    ARB what? Tree saver strap? You should always use a tree strap regardless of steel or synthetic line. I have a steel line so I don't have any experience with the recovery rings but they seem like a great option for synthetic line.
    I agree with you on the damper. Even with synthetic line that might not "need" it the damper is cheap insurance and also serves as a great flag on the line to make it more noticeable when in use.
    Key-Rei and eddyizm[QUOTED][OP] like this.
  12. Mar 24, 2022 at 4:34 PM
    eddyizm
    Sorry for the missing context. ARB snatch block but it seems like you answered my question unless it is compatible with both. I do more research on the snatch ring situation as those definitely seem newer with less info around.
  13. Mar 24, 2022 at 9:12 PM
    plurpimpin
    PDX
    I wouldn’t let the newness deter you. If I had a synthetic line I totally would have got a recovery ring instead of snatch block. They make perfect sense.
    I also would’ve got a synthetic line if I bought my winch new but I scored mine off Craigslist “broken” for $40 with a steel cable. I fixed it’s bad ground to make it work good as new so beggars can’t be choosers.
    eddyizm[QUOTED][OP] likes this.
  14. Mar 25, 2022 at 3:48 PM
    eddyizm
    haha that's awesome!
    I actually didn't mean the newness was going to deter me from getting a snatch ring, the newness just makes it more challenging to get feedback on a tried and true product. Do you have one that you would get if you did have a synthetic line?
  15. May 29, 2023 at 4:15 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Saw these at my local HF
  16. May 30, 2023 at 6:30 AM
    Vegvisir Overland
    Vegvisir Overland Well-Known Member
    Central OK
    2020 Tacoma TRD Pro Army Green
    Took the bed mat from 2nd Gen to 3rd Gen
    My understanding is that you can use just about any normal recovery gear with synthetic *as long as it was not used by steel cable first*. Steel cable can abrade contact surfaces which can then go on to fray synthetic line.
    I picked up a couple of those Harbor Freight winch dampeners. Cheap insurance for $11 each and they are fairly substantial. I have an old tool bag for the winch stuff, they sit nicely in the bottom of it.
    Grey 2015 likes this.
