winch cradle or front bumper mount?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Circledranch78, Jan 8, 2019.
  1. Jan 8, 2019 at 7:59 AM
    Circledranch78
    Circledranch78 [OP] Member
    Bradley
    2019 Tacoma TSS 4x4
    none yet
    I am trying to decide on winch mount options. Cradle with front 2" receiver or front bumper with winch?
    what winch do you prefer?
  2. Jan 9, 2019 at 7:08 AM
    Circledranch78
    Bradley
    2019 Tacoma TSS 4x4
    none yet
    Is this thread not allowed? I just wanted some feedback.
    mikestaco17 and Bushed like this.
  3. Jan 9, 2019 at 7:10 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    In you live in an area where they salt roads and you drive your truck in the winter, then I’d go receiver and cradle.
  4. Jan 9, 2019 at 7:15 AM
    Circledranch78
    Bradley
    2019 Tacoma TSS 4x4
    none yet
    I am in East Texas. Very little true Winter weather. However if we do get ice, stay at home. No one down here can drive in it.
  5. Jan 9, 2019 at 7:28 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I'd opt for some type of bumper with recovery points..... I either like the ARB or the Southern Style Offroad offerings.
    Circledranch78[OP] likes this.
  6. Jan 9, 2019 at 7:44 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  7. Jan 9, 2019 at 7:46 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    SSO
    /Thread
  8. Jan 9, 2019 at 7:48 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    I'm not a fan of receiver mounted winches if you offroad. By the time your wheel deep in a whole carrying a winch and aligning it with a reciever tube that may or may not be covered in mud, snow, rocks, water, whatever seems like a useless application of a winch. I want my winch ready, installed, and so I just need to pull rope before using. The receiver options also put the winch about a foot to 18" further out than a standard bumper with winch would too, increasing leverage on the frame and mounting points.
    If you want a winch for the 4 times you will take the truck offroad and want expo points, and you will rarely leave pavement so you can leave the winch at home I guess do that. (honestly if this is the case why do you need a winch?)
  9. Jan 9, 2019 at 8:11 AM
    Circledranch78
    Bradley
    2019 Tacoma TSS 4x4
    none yet
    Thanks guys, I appreciate the advice
  10. Jan 9, 2019 at 9:37 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    There are also a few companies that make the rarest seen option: a brush guard winch mount.
    Important questions to ask your self. 1.How often do you plan to use your winch? 2.Are you going to want to reach down your grill or into a hole to flip your winch into freewheel?Or are you going to get one that has an electric clutch?
  11. Jan 9, 2019 at 10:31 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    This isn't that big of a concern in my opinion, as long as you can still access the lever. The more the winch is covered the better UV protection the rope will have as well, so its a double edged sword.
  12. Jan 9, 2019 at 11:34 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Cradle with Warn winch mounted into a Mobtown Offroad recovery bar.
    I see no reason to permanently add over 100lbs to the front of my truck for the occasional off road trip.
  13. Jan 9, 2019 at 11:35 AM
    adk_tacoma
    Joe
    Waterford, NY
    Oh I forgot question 4. Steel or synthetic rope? Research the pros and cons of each
  14. Jan 9, 2019 at 11:47 AM
    MartinDWhite
    MartinDWhite Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    I have had both. The truck started with a receiver and winch in cradle on the front. I made the receiver so it was about 22" off the ground and clearance was not a problem. I never had a problem with bumping it on something (on a trail or a parking lot) even though it did seem to stick way out. I used the winch in the receiver a few times and it worked fine.
    I now have the same winch in the bumper. It is WAY better in the bumper. I end up needing the winch about once a month to pull my self, or someone else, out of where ever I, or they, are stuck. If you plan to use a winch I highly suggest putting it in a bumper.
    SnowroxKT and Circledranch78[OP] like this.
