Winch Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deserttacoma84, Mar 29, 2020.
  1. Mar 29, 2020 at 3:04 PM
    deserttacoma84
    deserttacoma84 [OP] Well-Known Member
    Phoenix
    06 Tacoma SR5
    AirRaid Intake Fabtech 6" Coilover Lift 33" BFG All Terrains
    I've researched this quite a bit. Im not an overlander nor do I intend to get into it. I recreationally wheel. Just getting around to installing a winch bumper, warn vr10 and 30 inch baja designs onx6.
    Its been recommended to go with X2 deep cycle battery, but will be rare that night driving or winching is needed. Is there other recommendations that anyone has on batteries that can power said accessories? Or just go with X2 battery?
  2. Mar 29, 2020 at 3:20 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Your regular starting battery is fine for winching. No need to buy another. That said those X2 AGMs are not actually true deep cycle so they'd work fine, too. A true deep cycle wouldn't like being asked to source a ton of current for winching.
  3. Mar 29, 2020 at 3:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    North Star its not cheap. However, if you’re really want to prepare for the blackswan go for quality.
  4. Mar 29, 2020 at 4:26 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You might want to move up one step on CCA's with a new battery the next time you need one. But nothing special is needed.
    SR-71A likes this.
  5. Mar 29, 2020 at 4:30 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I ran the oem battery winched several times and have some lights never had a issue just kept the truck running when pulling.
    It finally died to heat I’ve got a agm now you can get a duarlast platinum 24f from auto zone for like 200 good little battery and sweet warranty.
  6. Mar 29, 2020 at 5:22 PM
    deserttacoma84
    Phoenix
    06 Tacoma SR5
    Is no one recommending Optima anymore? I know they moved plants out of country, but are they truly garbage now?
  7. Mar 29, 2020 at 5:46 PM
    mx07gt
    mx07gt Well-Known Member
    Last time I had an Optima, it was a Red top, and it took a dump on my in the middle of nowhere, I couldn't even jump start it. Turns out one of the internal cells or whatever they're called shorted out. I decided to never buy an optima again. I buy whatever has the best replacement/warranty and I have zero complaints.
  8. Mar 29, 2020 at 5:51 PM
    deserttacoma84
    Phoenix
    06 Tacoma SR5
    Seems like the 60 month warranty x2 or Northstar stuff is the way to go? But Autozone is available everywhere... thoughts?
  9. Mar 29, 2020 at 6:03 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    X2 is a great battery but I wouldn't swap out your stock battery until it craps out on you. LED's are not a large draw, I have seen people leave one rock lights, bed lights, and ditch lights on for hours at a time and the truck starts right up the next morning. As far as wrenching goes I have always made sure that the engine is running while I'm wenching.
  10. Mar 30, 2020 at 7:10 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Stock battery is fine. I always run the engine and shut down all non essential electrical loads (lights, heater blower, etc) while winching and I've never had any battery issues. FYI the LEDs draw very little.... 6-8A, maybe, for a full bar. That's like two cell phone chargers. You definitely don't need a upgraded battery for that, even if you ran it constantly..
  11. Mar 30, 2020 at 7:14 AM
    deserttacoma84
    Phoenix
    06 Tacoma SR5
    The light bar I am installing runs close to triple that? Baja Designs Onx6+ 30"
    Specifications:
    Lumens: (High) 31,910 (Low) 25,450 Utilizing 18 Cree LEDs
    Wattage/Amps: (High) 281W / 21.7A (Low) 225W / 17.1A
  12. Mar 30, 2020 at 7:16 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Hmm, that's more draw than I would have thought, but I stand by my statement. 20A is still nothing in the overall scheme.
  13. Mar 30, 2020 at 7:21 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Everyone with a toyota is born an overlander. Sorry bud
    Post34322 likes this.
  14. Mar 30, 2020 at 7:32 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Only thing I will add to the above, is if you do go for an AGM (Northstar or X2 Power are good common choices) you'll want to consider a voltage booster. The stock charging voltage from a Tacoma isnt high enough to keep AGMs fully topped off. This unit seems to be the most common choice on this forum, and Ive been running it for several months now without issue. I do keep the stock 7.5A Alt-S fuse in the glove box just in case.. Before that I would have to top my batteries off about once a month with my battery tender set to the AGM mode.
    https://www.ebay.com/itm/Alternator...Toyota-FJ-Cruiser-Tacoma-4runner/222611866643
    As a side note, Northstar and X2 Power are made in the same factory. And last time I looked the X2 carried a better warranty.
    ColoradoTJ likes this.
  15. Mar 30, 2020 at 7:45 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  16. Mar 30, 2020 at 3:10 PM
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    Costco sells Interstate batteries at great prices.
