Will these rims and tires work on my 2021 Toyota Tacoma TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Falcon32, Jun 16, 2022.
  1. Jun 16, 2022 at 10:19 PM
    Falcon32
    Falcon32 [OP] New Member
    2021 Toyota Tacoma TRD Sport (Army Green)
    TRD Sport Package
    Currently own a 2021 Toyota Tacoma TRD sport and looking to upgrade my rims and tires. Don't know these will work. They are from a Chevy Silverado and I want to make sure before I buy. Any quick help is appreciated!
    6 bolt/18", 4 all terrain tires with extreme fuel wheels (description)
    Tires: LT285/65R18 125/122R
    See pictures attached of what I would purchase.
  2. Jun 17, 2022 at 4:54 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Not sure. Hub bore might be different but the lug pattern should be the same. You will rub like a SOB with that setup though.
    https://wheelssize.com/
  3. Jun 17, 2022 at 4:56 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    On what type of suspension? Certainly not stock...
  4. Jun 17, 2022 at 5:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm confused. You say you are upgrading your rims and tires? Where are you getting rims? I don't think those fuel wheels are 2 piece wheels so how are getting just rims? You do realize that those bolts are for decoration only and you can not separate the bolt face from the rim. They are 1 piece wheels. You might be able to use those wheels if they have the correct bolt pattern which they look like they are drilled for multi bolt patterns, but you need to measure them first. Then you need to check the center bore to make sure it is big enough and lastly back spacing. Personally I am no fan of those multi hole wheels because the extra holes weaken the wheel and are susceptible to cracking. There are a lot wheels out there that are the correct fitment. No need to buy junk.
  5. Jun 17, 2022 at 5:39 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    No. Tacoma wheels need to be hub centric (the center needs to precisely fit around the hub).
    Im not sure if those fuels will do that - and its a moot point to even look it up - since the tire dimensions are way too large anyway.
