Will the Badlands Apex 12,000 lbs Winch fit in the Body Armor HiLine Bumper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by travisrtaylor, Apr 8, 2021.
  1. Apr 8, 2021 at 4:06 PM
    travisrtaylor
    travisrtaylor [OP] Member
    Texas
    2019 Off-Road
    The spec says it holds a 10,000 lbs winch with 1/4" winch mount. If the Apex fits, will the 1/4" winch mount be strong enough to hold it?
  2. Dec 7, 2021 at 7:00 PM
    TacoCop1125
    TacoCop1125 Member
    2018 LIMITED BR DCSB
    Did you ever get an answer or try it out?
  3. Jun 19, 2023 at 9:27 PM
    TerrapinOverland
    TerrapinOverland Well-Known Member
    Hillsborough, NC
    2015 Tacoma TRD Off Road Access Cab
    Dobinson's IMS with heavy duty leaf package Epoch house battery Renogy 40AMP DC to DC charger 100W Solar Panel Chrome delete: grill, etc... Tinted front headlights. A. R. E. fiberglass cap. Sits flush to top of cab w/DIY roof tracks w/modified 84" x 50" ebay roof rack ( I cut it to 72") sleeping platform and cabinets 32-in LED light bar behind the grill. Cats down under the star's bumper sticker Spock decal on dashboard passenger side. Viair 88p compressor mounted in stock truck bed storage box Rear bumper air chuck dash mount ultraguage dash mount 7"tablet
  4. Jun 20, 2023 at 5:44 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    The Apex 12K winch fits and the BA Hiline winch mount plate is strong enough to hold it. The frame horns are the weak point for the whole assembly however. BAMF brackets reinforce the frame horn mounts. I installed those as well when I added the Bumper and winch to my truck
    You do have to cut off and drill out the OEM frame horn bolts and install longer bolts so you have enough thread to install the BAMF frame reinforcement brackets though
    TerrapinOverland likes this.
  5. Jun 20, 2023 at 11:21 AM
    TerrapinOverland
    Hillsborough, NC
    Thanks.
  6. Mar 27, 2025 at 1:42 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Thanks! I just found this, should have used search before posting.
  7. Mar 27, 2025 at 7:23 PM
    TerrapinOverland
    Hillsborough, NC
    I can attest to my 12,000 lb. Lb. Winch from harbor freight fit in my highline bumper. I'm a second gen 2015. About a month ago I was stuck in South America in the stream bed. Part of the extraction process was hooking to a tree I'm one of the 10-ft high Banks. It lifted the whole front of the truck up. It was pretty cool.
    willtill, tacoma_ca and Spuds509 like this.
