Will rear block lift affect alignment?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 13, 2020.
  1. Oct 13, 2020 at 3:38 PM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    just recently lifted my front end 2 inches and had it realigned.. it crossed my mind if I lift the rear 1" inch with cast iron blocks does that affect the alignment I just did... in any way??
  2. Oct 13, 2020 at 3:40 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    No your good
    Jpalafox and LilTexan22 like this.
  3. Oct 13, 2020 at 3:40 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    How was your alignment numbers?
  4. Oct 13, 2020 at 3:41 PM
    kiki111
    Tacoma 2.7L SR
    back to factory I was told
  5. Oct 13, 2020 at 3:42 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Oh ok do you have print out?
  6. Oct 13, 2020 at 3:42 PM
    kiki111
    Tacoma 2.7L SR
    not sure they gave me some paperwork let me check... they didn't give me a printout but it says its included so I'll go by tomorrow and get one....
    71tattooguy likes this.
  7. Oct 13, 2020 at 3:49 PM
    kiki111
    Tacoma 2.7L SR
  8. Oct 13, 2020 at 4:15 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Lifting the rear won't mess up your alignment
  9. Oct 13, 2020 at 4:17 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    No, the rear suspension is a solid axle and also not involved in steering, so generally doesn’t need to be aligned after a modification like yours. However you might need to realign the draft shaft because it’s angle changes when you lift the rear. You might be safe with only 1”. I lifted mine 2” and added a carrier bearing drop kit to adjust the drive shaft angle.
  10. Oct 13, 2020 at 4:18 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Looks great bro
  11. Oct 13, 2020 at 4:25 PM
    kiki111
    Tacoma 2.7L SR
    bought an old man emu spacer...for the drive shaft drop....its about 3/8 i believe
  12. Oct 13, 2020 at 4:26 PM
    gudujarlson
    Minnesota
    That’s the same one I installed
  13. Oct 13, 2020 at 4:27 PM
    kiki111
    Tacoma 2.7L SR
    did that solve your vibration problems
  14. Oct 13, 2020 at 4:28 PM
    gudujarlson
    Minnesota
    I never had any vibration problems. I installed the spacer at the same time as the rest of the kit I bought from Headstrong.
  15. Oct 13, 2020 at 4:29 PM
    kiki111
    Tacoma 2.7L SR
    I was told with a 1-in rear block lift I wouldn't need it but I figured it won't hurt
  16. Dec 2, 2020 at 1:38 PM
    $ilverT@¢ō92
    $ilverT@¢ō92 Member
    Weston
    2017 Tacoma TRD Sport 2WD
    What’s the rule of thumb for needing a carrier bearing drop kit? I’m looking into installing the 1.5” AAL from HS.
    I saw where you said 1” might be safe, but you installed one for a 2” lift.
  17. Dec 2, 2020 at 1:48 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    My understanding is it varies from truck to truck and you wont know for sure until you drive it post lift. If you get vibes you can try carrier bearing drop (like $20 and 15 minutes) or axle shims (more work).
  18. Dec 2, 2020 at 6:25 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You don’t need to realign, but people telling you it won’t effect it are kinda incorrect. It WILL absolutely effect your caster angle. Now 1” in the back the effect will be minimal on caster, and it won’t effect any other parts of alignment specs, so nothing to really worry about. but caster is super important with tire size & width you may run over or under stock sizing.
    wolfman00, auskip07, reg0928 and 2 others like this.
  19. Dec 3, 2020 at 7:07 AM
    gudujarlson
    Minnesota
    I don’t know. My kit from headstrong came with one and I installed it. It was probably the easiest part of the install, albeit made harder because i did it late at night after a long day of wrenching.
  20. Dec 3, 2020 at 7:28 AM
    $ilverT@¢ō92
    $ilverT@¢ō92 Member
    Weston
    Have you had any vibration issues?
    If it comes with the kit, then I’ll probably just install it and see how it goes. Worse case I can always remove it later.
