Will needle scaler remove factory undercoat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by KGN, Mar 10, 2017.
  1. Mar 10, 2017 at 8:41 AM
    KGN
    KGN [OP] Well-Known Member
    2011 Tacoma 2.7L
    Looking to put a better undercoating, seeing the posts about por90 or whatever. Wondering for those that have removed the crap Toyota puts on your frame if a needle scaler works best?
    Or what method you used.
  2. Mar 10, 2017 at 12:35 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends on the type of undercoating .
    Some is so soft a needle scaler will not do anything.
    I have tried several different ways
    Gasket stripper to make it soft scrap off with putty knife
    Oxy-fuel torch to heat and remove you need a fire watcher for this
    Air hammer with a very wide chisel blade .
    I have even tried sand blasting
    It comes down to the type of undercoating just which method works best
  3. Mar 10, 2017 at 2:38 PM
    Pumpman
    Pumpman Well-Known Member
    Bert
    98 tacoma sr5
    ^ hes right if its the soft undercoat neddle gun wont do it ,but i did see an air powered scraper at harbour freight that looked like it would be great for that ,i bought my mini needle gun from them i love it i did my entire frame with it before i did my repairs worked awesome also did a great job on the rearend cleaned it up like new then put a good coat of rustoleum on it i always brush it on you get a good coat that way ,spray cans never last on this stuff
  4. Mar 10, 2017 at 2:43 PM
    KGN
    2011 Tacoma 2.7L
    Okay thanks for the replies. I will poke around down there and see if the undercoat feels brittle enough for the needle scaler. And look into that other tool as well, never heard of that. I have access to air tool hookups at work so I'm hoping to do a bit of preventive work on the frame when it warms up.
  5. Mar 10, 2017 at 2:50 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I suggest paint remover.
  6. Mar 10, 2017 at 4:27 PM
    Pumpman
    Bert
    98 tacoma sr5
    Harbour frieght
