Will my lug nuts work on my new rims?
Discussion in 'Wheels & Tires' started by nobescare, Jul 30, 2018.
  1. Jul 30, 2018 at 10:56 AM
    nobescare
    nobescare [OP] Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    I have an 05 tacoma prerunner with factory 16" steel rims. I just got a set of 16" OEM rims off a 2015 aluminum. Will the lug nuts I have work on the new rims. They're oem acorn style chrome with the washer
    Thx
  2. Jul 30, 2018 at 2:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you have the OEM Stock lugs for the steel wheels they will not work for the aluminum wheels.
    The proper lug nuts for the aluminum wheels look like this:
  3. Jul 30, 2018 at 3:06 PM
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    Not true particularly.. (Maybe)
    nobescare[OP] likes this.
  4. Jul 30, 2018 at 3:08 PM
    Slamuel
    Sam
    Tacoma
    I am not a million percent sure but I do believe that this is proper. My experience is with aftermarket wheels. Maybe OEM takes shanks. I just have seen people attempt to use them interchangeably and that’s not a good idea
    If OEM wheels take shanks then I’ll go ahead and excuse myself:rofl:
  5. Jul 30, 2018 at 6:15 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Where’s the best place to buy lugs like that?
  6. Jul 30, 2018 at 6:17 PM
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    I got my set from Discount Tire.
  7. Jul 30, 2018 at 7:43 PM
    Slamuel
    Sam
    Tacoma
    Whatever you do, make sure to get a micrometer, calipers, a measuring straw I don’t care, and figure out for sure that the lug nut isn’t going to bottom out. If it does it’ll ruin every stud in which that occurs.
  8. Jul 30, 2018 at 8:43 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I think dorman makes the one piece lugs without the chrome caps that don’t swell up over time and turn a 21mm into a 22.5 mm
    drillbit and cruxofthebisquit like this.
  9. Jul 31, 2018 at 2:02 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Best bet is going with high quality lug nuts like McGard or Gorilla. IMHO it's an area that one shouldn't cheap out....
    nobescare[OP] and Slamuel like this.
  10. Jul 31, 2018 at 2:05 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    These (Or the extended shank) go on aftermarket aluminum. These go on the factory alloys.
  11. Jul 31, 2018 at 7:28 AM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    Yup...... Most of the cheap replacements are just a hair short... Trust me I know :mad:
  12. Jul 31, 2018 at 8:13 AM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I just ordered some steel wheels [​IMG]will my factory lug nuts for alloy wheels work with these?
  13. Jul 31, 2018 at 8:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The factory lug for alloy wheels should work just fine with a steel wheel like your spare is on a steel wheel.
  14. Jul 31, 2018 at 8:38 AM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    Perfect, thanks :thumbsup:
    Will these also work, looking to get rid of the chrome.
  15. Jul 31, 2018 at 11:06 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    These steel wheels take acorn style. My factory OR alum. wheels take mag/shank style.
  16. Jul 31, 2018 at 11:11 AM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    So these should work.
  17. Jul 31, 2018 at 1:59 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I believe the second link is the incorrect size. Should be 12mmx 1.5
  18. Jul 31, 2018 at 2:01 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Nope...Not with an aluminum wheel.....
  19. Jul 31, 2018 at 2:06 PM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I just ordered some old style steel so they should work correct?
  20. Jul 31, 2018 at 2:08 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I believe this style is what you need. I would verify the length. They have another set that is a wee bit shorter.
