Will jeep rims fit on my taco?
Discussion in '5 Lug' started by Tnguyen, May 18, 2012.
  1. May 18, 2012 at 10:42 AM
    Tnguyen
    Tnguyen [OP] Member
    I'm a noob so bare with me I'm goin to get a ready lift for my 5 lug 06 taco was looking on eBay for 31" tires n rims package found one that says "fits jeep" so does that mean it'll fit on my taco?? Want to make sure before I purchase it thanks
  2. May 18, 2012 at 10:45 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
  3. May 18, 2012 at 10:49 AM
    cgs2k2
    cgs2k2 old man
    you should look up the bolt pattern for your truck and then buy wheels based on that.
    you'd be bummed, and would have wasted your time by buying something you "think" fits. aka, not all 5-lug wheels have the same bolt pattern.
    good luck!
  4. May 18, 2012 at 10:51 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    yes they will fit...
    however the bolt pattern is different, you have to buy spacer/adapters to put them on your taco
    actually i just checked your bolt pattern and it is the same (5 x 4.5) as the older jeeps
    the newer jeeps have 5x5 pattern
  5. May 19, 2012 at 3:59 PM
    Blackcat10
    Blackcat10 Well-Known Member
    Yes Jeep wheels will fit.I run them on my 5 lug. Bolt pattern 5x4.5. Had to do a little grinding on the caliper mount. If you are not comfortable grinding install 1/4 inch spacers.
    If you run the taller tires you will have to remove the black boxes. They are located under the back of the inner fender cover. Cut the cover and remove 3 bolts.
  6. May 19, 2012 at 4:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Interesting! My dad is selling his after market wheels off his wrangler (5 on 4.5)
    Hmmmmm
  7. Aug 2, 2012 at 7:32 PM
    wahvtec
    wahvtec Member
    Statesboro, Ga
    96 tacoma
    Plate front bumper 3 inch lift Usual stereo stuff
    the jeeps before the current body style fit for sure bolt pattern wise. But something i didnt see mentioned on here is the back space is usually somewhat large for large tires on our tacos so if your running large tires u may want a smaller backspace which is what drove me away from them
  8. Aug 2, 2012 at 7:38 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Why do you want jeep wheels on your taco? WTF
  9. Aug 2, 2012 at 7:47 PM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    Disregard i didnt read you were 5 lug
  10. Aug 2, 2012 at 7:49 PM
    wahvtec
    wahvtec Member
    Statesboro, Ga
    96 tacoma
    the 5 lugs tacos are 5x4.5 just like the 90s early 2000s jeeps is what i was referring to sorry for confusion
  11. Aug 5, 2012 at 11:19 PM
    vincentek9
    vincentek9 Member
    Vincent
    Orange County, CA
    96 2WD taco
    roundeyes, visors, wink mirror, level kit
    i've also been looking at jeep rims (mainly because they are cheap) and the bolt pattern on the older jeeps are fine. a big issue i'm worried about is the center bore of the tacos are big compared to most rims... and i'm not sure if the jeep rims would accommodate that big ass bore size.
  12. Dec 26, 2019 at 12:27 PM
    smegma11
    smegma11 New Member
    Jim
    2011 Tacoma access
    None
    This is why you should ask a professional. Dependeding on the year, yes they will.
    pwrslide2 likes this.
  13. Jan 7, 2020 at 2:35 PM
    Tacodad22
    Tacodad22 Member
    Nashville, TN
    Reg cab stepside red 01 Tacoma SR5 2wd
    Rebuilt motor. Not much else but it needs quite a bit of work
    I have Jeep rims on my daughters 01. The center's fit by about 1/32 all the way around. But I don't know about 2000 and below. Here's a pic of the back ram Jeep logo and all.IMG_20200107_154531.jpg
  14. Jan 7, 2020 at 2:38 PM
    Tacodad22
    Tacodad22 Member
    Nashville, TN
    Sorry autocorrect, back rim
  15. Jan 7, 2020 at 2:53 PM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    My neighbor got a "fix it ticket" because his 35's stuck out too far on his jeep. I let him borrow the wheels and tires off my 5 lug taco so he could show a cop and have the ticket written off. They fit fine (5 lug). This was 20 years ago, things my have changed.
  16. Jan 7, 2020 at 2:54 PM
    Tacodad22
    Tacodad22 Member
    Nashville, TN
    Had a bent rim and I had those in the garage with newish tires. I knew that would upset somebody but they actually look okay on the truckIMG_20200107_154617.jpg
  17. Jan 7, 2020 at 3:19 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Lol there's trolls amongst us everywhere here on TW. Wouldn't take what he said to heart. IMO when I go bigger tires I might get some used ones on a set of Jeep rims if they're available. Most economically wise choice in that regard
    Beeman1 likes this.
  18. Jan 7, 2020 at 4:10 PM
    Tacodad22
    Tacodad22 Member
    Nashville, TN
    No big deal, I thought it might upset the purists. Actually I was wondering when someone would notice on the site. Around here the step bed draws them in as they get closer they notice the Jeep logo and start ranting about why it's sacrilegious. So I've gotten used to it. I'm about to start working on it and getting it ready to give to my daughter for her first car. The rims are temporary she wants to put aftermarkets on it anyway after it's painted.
  19. May 31, 2020 at 1:32 PM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    I put 5x5 265/70 r17 tires and wheels from a jeep using 5x4.5 to 5x5 1 inch spacers and the tires line up perfectly with the lines of the truck, but the black box had to come out.thumbnail.jpg
  20. May 31, 2020 at 2:09 PM
    Tacodad22
    Tacodad22 Member
    Nashville, TN
    It looks really good man. Just curious what size wheel and tire combo did it have on it before?
