Will it launch my boat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hbranden94, Jul 26, 2019.
  1. Jul 26, 2019 at 8:59 PM
    Hbranden94
    Hbranden94 [OP] New Member
    Branden
    2015 2wd double cab 4.0 v6 prerunner trd off road
    I have a boat that waighs about 4500 pounds an I have never pulled anything that big with my 2015 Tacoma 2wd dub cab with the 4.0 v6 it dose have the towing package. I just want to know if it will be able to pull it out the water without a problem . If anyone has some info for me I would appreciate it thank.
  2. Jul 26, 2019 at 10:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you can get traction it probably will......
    If you can’t get traction, and the wheels spin, it’s not going to be fun.
    I’d personally prefer 4x4, and depending on ramp grade, maybe even low range?.
    06Tacooo likes this.
  3. Jul 26, 2019 at 11:24 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I wouldn't even try it unless there was a bigger truck there to pull you out in case of an emergency. Ramps are slick more often than not. I specifically wanted 4wd for that very reason
  4. Jul 26, 2019 at 11:30 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I had a 23 foot walk around. Weight was about 4200 dry, and the trailer was another 1000 pounds. Add that to the random stuff on the boat like fluids and gear, I estimate I was at 6,000. Had serious trouble pulling with my taco. I have the v6 with 4x4. I did it, but didn’t feel comfortable at all.
  5. Jul 26, 2019 at 11:41 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Im actually going to change my questions...
    PzTank likes this.
  6. Jul 27, 2019 at 12:20 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I bet it still turns on after that bath!!
  7. Jul 27, 2019 at 12:41 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Do you have the towing package first - if not forget it.
    If yes, going in will be easy but as stated the ramps get slippery so rear wheels may spin and traction control might not do you much good. Ocean ramps maybe impossible at lower tides. If always a 2 person launch you can use the boat motor to give the truck an initial push till the trailer comes out of the water (based on trailer height and motor as you don't want to trash the skeg and prop). On my 3500 boat/trailer on ocean ramps I always have it in 4 High when pulling up the ramp. Remember on lots of ramps the trucks rear wheels will be in the water due to ramp angle and trailer tongue length.
    Skyway likes this.
  8. Jul 27, 2019 at 12:46 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Tow starts at 7:20. Ouch!
    PzTank likes this.
  9. Jul 27, 2019 at 12:47 AM
    BalutTaco
    seaweed= no go
    Skyway likes this.
  10. Jul 27, 2019 at 4:21 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    When I had my ski boat I never needed 4wd. As long as I was easy on the pedal it pulled it right out. Hell,when I lived in Fl we launched our ski boat with a tiny 2wd Nissan. Sometimes it was spinning a tire coming up the ramp but it always made it !
  11. Jul 27, 2019 at 4:25 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I personally would not be using a Tacoma to launch a boat that big. You need a 4x4 hands down if you launch boats.
    You are right at the max towing capacity with a towing package, you are overweight without the tow package. I personally do not trust this truck enough to handle that type of boat. Get a full size.
  12. Jul 27, 2019 at 4:26 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Yeah, that’s a bit crazy. Dude/dudette must’ve done everything wrong for it to slide that deep. I guess once you lose it, gravity takes over but damn, not even the skewp could save ‘em..
  13. Jul 27, 2019 at 4:31 AM
    PackCon
    Connor
    Why in hell would they turn the truck on?
  14. Jul 27, 2019 at 8:38 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Saw a 3rd gen towing a 5th wheel through a mountain pass yesterday. I imagine you should be fine with the boat.
  15. Jul 27, 2019 at 10:34 AM
    Hbranden94
    Branden
    Thanks everyone for the advice. an would it help if I had the RR DIFF LOCK on an in low gear ? An my truck is a 2nd gen the 3rd gens are made a little more better for towing from what I have been told.
  16. Jul 27, 2019 at 11:10 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    The question is not, "Can you tow it?"
    The real question is, "Can you stop it?"
  17. Jul 27, 2019 at 11:15 AM
    Hbranden94
    Branden
    I can stop it I have electric bake assist on the boat trailer an I know it will pull it an stop it that's how I got it home just questioning if it will launch it an pull it out the water I have the (towing package with the RR DIFF LOCK an low gear) just don't know if that would be enough .
    Skyway likes this.
  18. Jul 27, 2019 at 11:18 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Just make sure you turn on the LSD. This will aid in traction and will also shut off that dreaded traction control....which will work against you in a situation like launching a boat on a slick surface
  19. Jul 27, 2019 at 11:37 AM
    Muddinfun
    Muddinfun Well-Known Member
    One way that I suspect that trucks end up in the water is 2WD truck in park, nobody in the cab, trailer not far enough into the water, boat puts pressure on rear of trailer, which lifts the tongue, which lifts the back tires of the truck off the ground, and truck goes in the water. This is just a suspicion. I've never read anywhere that this was actually the cause.
    KTM753 likes this.
  20. Jul 27, 2019 at 11:43 AM
    Hbranden94
    Branden
    It is a 2wd
