Will H10 bulbs work/fit into H3 Lamps?
Discussion in 'Lighting' started by wolftree, Nov 6, 2011.
  1. Nov 6, 2011 at 6:37 PM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Will H10 (9145) light bulbs fit and work in lamp housings designed for H3 bulbs, provided the correct harness (H10) is used?
  2. Nov 10, 2011 at 2:20 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Since nobody else has... no, not likely. H3 and H10 bulbs have totally different bases. The H10/9145/9005 is more of a weatherpack style bulb & plug, whereas the H3 (like H1) is a little metal tab--more like what our headlights are.
    You might be able to tape them in with duct tape, and they would illuminate the housing. :)
