Will Chevy Snowflake replicas fit my 96?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacobboone, Mar 12, 2020.
  1. Mar 12, 2020 at 11:32 PM
    jacobboone
    jacobboone [OP] New Member
    Jacob
    1996 Black Tacoma SR5
    2 inch lift - 16's and 31's Dick Cepeks
    I do not know very much when it comes to the literal performance of how vehicles work, just the basics and what things are called. I have a 96' tacoma and I am planning on getting some Chevy snowflake replicas, 22's, and can someone tell me will that new 6 lug wheel fit my 6 lug tacoma? Or will I need to do something to the wheel to get it to fit on my truck?
  2. Mar 13, 2020 at 3:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Never seeing the chevy wheels you might have a back spacing problem.
    The only way to know is to try them.
    Maybe you might get lucky and someone has done it
  3. Mar 13, 2020 at 4:55 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Most GM wheels have the same lug pattern, but a smaller hub bore. So no bueno.
  4. Mar 13, 2020 at 6:57 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Also 22"?
    License2Ill, coopcooper and Blue92 like this.
  5. Mar 13, 2020 at 2:00 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    GM hub bore is ~78mm I believe and Toyota is ~106mm (ish)
    would have to lathe out the centers to match. also the backspacing on GM wheels are usually more (we tried 09' rims on an '03 Taco) so will interfere with the calipers
  6. Mar 13, 2020 at 2:04 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    you would need adaptor spacers to compensate for the different hub size
  7. Mar 13, 2020 at 2:18 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    also due to the BS as mentioned above
  8. Mar 13, 2020 at 8:51 PM
    JC34X4
    JC34X4 Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    Not with manual locking hubs
