will an s10 cap fit my 99 Tacoma limited
Discussion in '1st Gen. Tacomas (1995-2004)' started by JohnHassle, Oct 28, 2019.
  1. Oct 28, 2019 at 5:44 AM
    JohnHassle
    JohnHassle [OP] New Member
    1999 tacoma 4wd limited, white
    the s10 cap is 60 wide by 74 long
  2. Oct 28, 2019 at 7:03 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Most likely it won't sit right.
  3. Oct 28, 2019 at 7:34 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    That Taco will immediately quit running if you put a chebby part on it, even if it is just a camper.
    J/K I have no idea if it'll fit
    ThunderOne likes this.
  4. Oct 28, 2019 at 7:53 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Looks like its too wide.
    https://raybuck.com/pickup-truck-bed-size-dimensions/
    I have a ranger cap on mine, but its one of the big ARE aluminum ones so they're a little more forgiving, and even then it took some modification to make me happy with the fit. Get one specifically for a tacoma if you can find one. Also beware that regular cab caps are different than access/double cab caps due to the slope of the back of the cab.
  5. Oct 28, 2019 at 12:04 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Ranger had a really wide bed rail so it's cap has a lot of leeway. If all you want is a cop for occasional use, these work.
