Will a Thule camper shell rack support the weight of the shell for hoisting purposes?
Discussion in 'Tonneau Covers, Caps and Shells' started by bamma, Nov 8, 2010.
  1. Nov 8, 2010 at 8:35 AM
    bamma
    bamma [OP] Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    I have a Leer 100xr with a Thule rack with tracks installed by Leer. Has anyone hoisted their shell in their garage hanging by the thule bars? I don't know if they will support the weight of the shell...
  2. Nov 8, 2010 at 8:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You may want to call a local LEER distributer and see if they're rated for uplift like that. I'm sure they are because the amount of force on those racks from the wind catching a cargo box at highway speed is fairly substantial but never hurts to hear it from the people who made it.
  3. Nov 8, 2010 at 9:38 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I don't think I would. The weight capacity of the rack is about 150 lbs. That's downward force where the feet of the rack spread the weight out. The tracks are held down by screws, but the weight of anything put on the bars is spread out by the track (near the foot). If you were pulling up on it, the screws that hold the track down would be the only thing supporting the weight of the shell.
  4. Nov 8, 2010 at 10:31 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Evil Monkey is exactly right......I would not even consider it.
    But, let us know how you make out if you attempt this.:D
  5. Nov 8, 2010 at 10:36 AM
    nomad
    nomad Well-Known Member
    If you have something (an aluminum plate or something else with a large surface area) that can spread the load out across the inside of the cap, I'd say go for it. If the only thing on the inside of the cap where the bolts/ screws go through is a washer, then no.
  6. Nov 8, 2010 at 11:24 AM
    bamma
    Spokane, WA
    Yeah that's what I figured. I have moved the shell that way, but figured it wasn't the best idea for prolonged storage. It would have made it so much easier to hoist though.
    Thanks all.
  7. Nov 8, 2010 at 2:45 PM
    bagster
    bagster Well-Known Member
  8. Nov 8, 2010 at 3:53 PM
    Evil Monkey
    Robert
    Escondido, CA
    I still don't think I'd trust it. The screws that hold the track to the top of the cap aren't that big. You're still putting a lot of weight on the threads to hold that cap up even if you put an aluminum strip on the inside. It's not the same type of force on the screws.
    Pushing down on the cap, like a loaded rack might, the weight is resting on the wide foot packs and the tracks, not the screws. The screws just keep the track from moving side to side. They don't support the weight of anything put on the rack. Pulling it up, the strain is entirely on the screws.
  9. Nov 8, 2010 at 4:15 PM
    Evil Monkey
    Robert
    Escondido, CA
  10. Nov 8, 2010 at 4:49 PM
    Pugga
    Massachusetts
    A light load on the roof rack catching a lot of wind I would bet puts more than 100 lbs of uplift on those mounting points. Picture one of those large enclosed fiberglass cargo carriers. They catch a lot of wind. If you put an aluminum plate underneath as reinforcement it should hold the weight fine. Just my opinion but it's not like this thing is going to be swinging around and having people hanging from it, just a static load.
  11. Nov 8, 2010 at 5:03 PM
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    I have a pully system to take off my cap. at first I used the roof rack, no problem. Now I have 4 felt lined hooks 1 in each side window 2 in the rear slider. works well
  12. Nov 8, 2010 at 5:03 PM
    nomad
    I bet even those smaller screws have hellacious tensile strength. Like Pugga said, it's a static load. With proper backing (inside the cap), I don't see any issues.
  13. Nov 8, 2010 at 6:33 PM
    Evil Monkey
    Robert
    Escondido, CA
    I doubt it. Even if it were flat and square, the air would push around on all sides about evenly (some would go left, some right, some up and some down). It's going to take the path of least resistance. Most of the force would be pushing backwards. Plus, most cargo carriers are angled so that most of the wind goes up and over the carrier.
    That said, if most people think it's fine, then so be it. I prefer to err on the side of caution, especially if I'm giving advice to others.
  14. Nov 8, 2010 at 6:40 PM
    Evil Monkey
    Robert
    Escondido, CA
    This is kind of what I was thinking would be better.
  15. Nov 8, 2010 at 7:52 PM
    j83soldier
    joshua
    Colorado
    05 tacoma
    I mean both work fine roof rack or hooks, I do not store the topper suspended though. I back in hook up suspend the topper drive out and set it down on saw horses
  16. Nov 8, 2010 at 9:33 PM
    Evil Monkey
    Robert
    Escondido, CA
    I know that. I'm just saying I'd be more comfortable with the second idea. The rack itself is only recommended to hold 150 lbs. By suspending it from the rack, you're overloading it's stated carrying capacity by 50 lbs and doing it in a way it wasn't intended to be used.
  17. Jul 8, 2012 at 7:14 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I had an ARE that I always hung. Never any problems. And we use a pallet fork on the front end loader to remove both my friends Leer and my ARE toppers by the rack.
  18. Jan 21, 2015 at 4:48 PM
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    I have a 100XR coming in next week. My dad is getting one as well. I had the same question, and I think he came up with a good idea. We are going to set up two 2x4s that will slide under each side of the shell....then we will hoist it up by the 4 points on the wood.
