Will a K&N air filter void my warranty?
Discussion in 'Performance and Tuning' started by tacoma805, Apr 10, 2017.
  1. Apr 10, 2017 at 4:01 PM
    tacoma805
    tacoma805 [OP] Member
    Will a K&N air filter void my warranty on my 2017 DCLB? I'd like to replace my current (stock) filter with a K&N. Lots of stuff comes up on Google when I search, but no clear answers.
    Any experience with this?
    See K&N's statement here: https://goo.gl/kvqxWj
  2. Apr 10, 2017 at 4:03 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    No, it won't. If something goes wrong, the dealer has to prove that the filter caused the problem.........plus, K&N has a guarantee that they will stand behind their product.
  3. Apr 10, 2017 at 4:06 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    No, shouldnt. (At one time, Ford wouldnt warranty engines running anything other than factory in dusty states; Arizona, Nevada etc.) But its no real gain, if anything just get the TRD filter and have no worries at all.
    Rob Daman likes this.
  4. Apr 10, 2017 at 4:10 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
  5. Apr 10, 2017 at 4:14 PM
    Taco16LB
    Taco16LB Well-Known Member
    If you have a problem , change it back before you take it in .
    SocalOC, CusterFan and warrior411 like this.
  6. Apr 10, 2017 at 4:14 PM
    warrior411
    warrior411 New Member
    2017 toyota tacoma trd sport
    upgraded sound system with jl audio amp,10 inch kicker sub,lci audio control,afe momentum gt cai with the air scoop,trd pro grille, go rhino bull bar trasher 6.5 inch running boards ,under cover flex tonneau cover. next week levelling kit,bf goodrich ko2 tires and fuel assault rims.
    i put a afe gt momentum on my truck with the air scoop,sounds good and not as loud as the k&n very easy install and can feel difference when i press the pedal down
  7. Apr 10, 2017 at 4:20 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Thats a whole intake, not just a filter.
  8. Apr 10, 2017 at 4:39 PM
    warrior411
    no its just a filter
  9. Apr 10, 2017 at 4:41 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Lol.
    Razgriz likes this.
  10. Apr 11, 2017 at 5:21 AM
    nailersniper
    nailersniper Well-Known Member
    2017 Limited double cab
    I was told an oiled filter voids the warranty. I don't know if that's true. Just sayin.....
  11. Apr 11, 2017 at 5:28 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Problems caused by the filter will not be covered by warranty. e.g. if you oiled the filter too much and the MAF sensor gets fouled, the cleaning will be chargeable.
    The other problem with the K&N filter - letting too much dust through and causing engine wear, typically won't show symptoms until after the powertrain warranty expires.
    vssman and CusterFan like this.
  12. Apr 11, 2017 at 5:41 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    This is the correct answer.
    It won't void the entire vehicle warranty. It CAN void something that goes wrong that can be associated with the modification.
    If your Mass Air Flow Sensor fails after installing I can promise you the dealer will tell you to pound sand. If the dealer tells you to fuck off you really have no recourse except to hire lawyers. People saying the dealer has to prove it are technically/legally correct but do you really think a dealer is going to fuck around if he thinks your mod caused the problem? No he will just tell you to hit the road they won't work on your truck unless you pay. So what will you do when they say that? Hope you have a lot of time and money to get a lawyer if that happens.
    cliffyk likes this.
  13. Apr 11, 2017 at 6:27 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    So what's the advantage of an aftermarket filter?
  14. Apr 11, 2017 at 6:33 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    None. Person that buys those are making the rich, richer. :crapstorm:
    smitty99 likes this.
  15. Apr 11, 2017 at 6:35 AM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I have one on my 2015 and the dealershirp tried to sell me a replacement because their tech said my air filter was due for a change. I just asked if he even looked because i have the K&N in the truck. He just walked away feeling like an idiot. They never looked just wanted to screw me over
  16. Apr 11, 2017 at 7:22 AM
    KenLyns
    Belly of the Beast
    The "performance" filters from K&N, AFE, AEM, etc. are washable and reusable. Over some 10 years you might break even on cost compared to replacing the OEM filter each year. That's about it. The stock engine can't use more airflow, and sound is unchanged because you are keeping the stock intake.
    smitty99 and CusterFan like this.
  17. Apr 11, 2017 at 8:59 AM
    nailersniper
    I was then told that a dry one is OK.
  18. Apr 11, 2017 at 9:07 AM
    smitty99
    Scottsdale
    Bottom line: Waste your money however you wish but there maybe better ways to waste it than a K&N air filter.
  19. Apr 11, 2017 at 9:09 AM
    SocalOC
    2015 Sport
    I have steel skids and a king lift yet my truck only ever sees sand :anonymous: ... ya i think me spemding 50$ on a filter was the least of my worries haha
  20. Apr 11, 2017 at 9:22 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    "Will a K&N air filter void my warranty?"
    No, within limits as explained above; nor will it do anything else except maybe make intake noise a bit louder ("better" according to some), which provides a powerful placebo effect making some think there has been some performance boost.
    I have never seen--though I often asked to see--any back-to-back dyno runs comparing a new OEM filter to any aftermarket filter, snake oiled or otherwise; where ONLY the air filters were changed and there was any measurable difference in engine power other then what would be expected between back-to-back runs.
    We did some years ago in Daytona dyno a 1992 Miata with a Purolator paper filter, some green foam thing, and no filter at all--there was no difference. FWIW we also did the same Miata with a "high-flow" aftermarket cat and a "test pipe" (no cat)--again there was no measurable difference...
