Will a bigger tire put more pressure on other components?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Mar 14, 2023.
  1. Mar 14, 2023 at 9:11 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    Hi, I own 2022 tacoma trd off road 4x4.
    My current stock tire is 265/70R16.
    I’m looking to upgrade to 265/75R16 or 265/70R17
    Which one is better?
    Also will bigger tire put more pressure on components and result in less reliable truck?
    Also, I daily drive my Tacoma. Does bigger tire effect on ride quality?
  2. Mar 14, 2023 at 9:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    265/75/16 will be more budget friendly.
    Unless you can get a set of 17” wheels for free?
    As far as pressure/wear on drive components, it will be negligible.
    Ride quality will depend on tire make, type, and psi.
    Junkhead and Shades_Of_Red like this.
  3. Mar 14, 2023 at 9:22 PM
    Sh56
    Shara
    I’m looking to buy new set of trd pro wheels anyways. So I can either get 16 inch wheel or 17 inch wheel.
    For the tire I plan to get BFGoodrich All-Terrain KO2s
  4. Mar 15, 2023 at 12:40 AM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the stock OR rims are lame looking to me and was the first thing i changed, went with these
    Junkhead and dleriche like this.
  5. Mar 15, 2023 at 4:18 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    265 75 16 More sidewall I think it looks better
  6. Mar 15, 2023 at 8:30 AM
    23TRD
    23TRD Active Member
    2023 Trd off road access cab auto
    What’s your driving style ? If you go off road a lot, I’d stick with the 16 in wheels .. more sidewall (distance between rim and road) equals not only a slightly more plush ride on rough terrain, but the added rubber also gives more sidewall flex for the tires to conform to the ground for added traction… especially if you air down a bit .
    But if you use your truck mostly on pavement with occasional light off-road use, then the 17 inch wheel will give you better handling with less sidewall to flex in the curves ..but also a harsher ride on bumps .
    This is why Toyota puts the 16’s on the off-road and 17’s on the sports .
    I personally think for a truck, that the taller sidewall looks better and more truck like …. But to each their own.
    MaverickT883 likes this.
  7. Mar 15, 2023 at 8:51 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    They're essentially the same; sure there are technical differences as others will be guaranteed to point out when I say they're the same; BUT, its a daily driver. You won't be using it in a capacity to notice a difference between more or less sidewall offroad, and by the time you add other mods, all the on road characteristics won't matter either. At the end of the day, go with what you want. For me and my reasoning, none of my choices had anything to do with handling/performance, and I went from 16's to 17's because:
    1. More tire choices in 17's (more size offerings in 17s vs 16s in some brands)
    2. More common in other vehicles, so finding used for cheap is easier.
    3. My impression is that more enthusiasts enjoy certain wheels offered in 17s/certain offsets vs 16" offerings, so resale is there.
  8. Mar 15, 2023 at 8:54 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    The 17" tire they were looking at was the 265/70R17. It has the same sidewall as the stock 16 tire they are running now, the overall diameter of the tire is bigger. The ride shouldn't be harsher unless going with a smaller sidewall. I went with the same size 17" tire on mine.
    YUKONSLY likes this.
  9. Mar 15, 2023 at 9:14 AM
    Off Topic Guy
    To answer the real questions you have though, going with a bigger tire can have an effect on other components, but its not anything remarkable until you start going much larger. A 32" tire (the tires you're looking at) likely won't have any major impact to your components or driving comfortability. What WILL impact those things are weight of the tire, load of the tire (SL vs E load for example), tread pattern, etc. I'd say your biggest concerns with a 32" tire are going to be potential for mpg loss (especially if you go aggressive tread), speedo/odo being slightly off, and potential for very minor rubbing depending on wheel offset/backspacing.
    YUKONSLY and ToyoTaco25 like this.
  10. Mar 15, 2023 at 10:03 AM
    Servingko
    Servingko Well-Known Member
    2022 DCSB OR MT
    Those tire sizes on OEM rims with the same offset and non LT will have limited to no impact or "stress" on suspension components. As you move from +25mm offset to negative offset you progressively add stress due to leverage. If its a heavier wheel, heavier tire, and larger diameter, you add stress due to increased leverage and weight.
    Will it significantly impact longevity, yes but will it be enough to see over the course of ownership? Another thing to consider is that to fit some of these tire/wheel combinations, you have to lift decreasing suspension down travel putting added stress on CV joints, shocks, drivetrain etc.
    Having said that, there are lot's of owners here running negative offset wheels with big LT tires and lifts driving for many miles without major issues.
    Certainly more than you wanted to know. Everything is a compromise but going to a 265/70r17 or 265/75r16 on OEM wheels which are +25mm for the 16" OR and most of the other OEM options for 17" are +10mm or +15mm, isn't an issue in a SL tire. My stock tires weighed 38lbs and most SL 265/75R16 are in the 39-47lb range.
  11. Mar 15, 2023 at 11:53 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    There is a little better tire selection with the 17s. Especially if later on u decide to move up to 285s.
  12. Mar 15, 2023 at 11:57 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    You are adding a bit of weight which will shorten the life of stuff like wheel bearings. I have had E rated 265/75/16s since 20k miles and am almost to 88k with no ill effects. My last 2012 Tacoma ran the same tires up to 200k and never needed suspension components replaced other than the shocks.
  13. Mar 15, 2023 at 1:29 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Depends more on the tires weight. Heavier tires from stock will hurt performance, and fuel economy, plus it'll cause your front end components to wear sooner. Higher tire pressures can also have an effect on the way your suspension acts.
  14. Mar 15, 2023 at 1:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Brakes, bearings and suspension all suffer from heavier tires.
    Nothing major but simple things like the shock dampers aren’t designed for anything above 40lb tires. So adding 60 lb e rated hurts shock performance and degradation is much faster.
