Will a 4wd lift kit fit a 2wd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZtrkbabe, Mar 25, 2020.
  1. Mar 25, 2020 at 9:16 PM
    AZtrkbabe
    AZtrkbabe [OP] Member
    2019 Tacoma Off Road
    I have a 2019 2wd trd off-road Tacoma. Been looking at lift kits (no suspension). Looking at either 2.5 or 3” supremes. Notice that a lot of them say they are 4wd specific. Do these work on a 2wd drive? Thanks
  2. Mar 25, 2020 at 9:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, all 2016+ tacomas share the same suspension.
    The reason it says 4WD as many kits come with front diff drops, which should be ignored on 2WD and 4WD models.
  3. Mar 25, 2020 at 9:21 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    There is a difference between 5 lug 2wd and a 6 lug 2wd (PreRunner)
    andrewtheadventurer likes this.
  4. Mar 25, 2020 at 9:25 PM
    Bishop84
    No such thing as a 5 lug 2016+
    JoeCOVA and HBMurphy[QUOTED] like this.
  5. Mar 25, 2020 at 9:27 PM
    HBMurphy
    Paul
    So California Coast
    None
    Oh nice.
  6. Mar 25, 2020 at 9:32 PM
    AZtrkbabe
    Still learning and just curious...can you please explain front diff drops? Thanks for the good info!
  7. Mar 25, 2020 at 11:05 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    very bad thing. Drops the front differential to “correct” cv angles, but permanently altered the frame and is not necessary
  8. Mar 26, 2020 at 8:35 AM
    AZtrkbabe
    Last question here. Can I run 33” tires with a 2.5” lift. Or is that 1/2” critical to prevent rubbing? Thank you
  9. Mar 26, 2020 at 9:01 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Nope, you've combined a drop bracket lift and a diff-drop. A diff drop is just about $50 worth of hardware that adds some spacers between the diff and the frame to drop the diff however much. A drop bracket lift is a lift that requires removing a cross member and adding a bracket to lift the truck.
    Drop bracket lift: https://www.roughcountry.com/toyota-suspension-lift-kit-74130.html
    Diff drop:
  10. Mar 26, 2020 at 9:04 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    It depends on what you want to do with your truck. Theoretically you can only run what you can fit without the lift if you want/need full articulation. The rubbing mainly occurs on the cab mount in the back of the wheel well and the pinch weld above it. With the right tires you can fit 33"s without a lift.
  11. Mar 26, 2020 at 9:19 AM
    karatescotty
    karatescotty Well-Known Member
    Beaverton, OR
    2019 TRD Pro
    I have a 2.5" lift in the front and 1.5" lift in the rear and have 33" tires.
    I rubbed because of my wheel backspacing which is -25, but with a less aggressive backspace you should be fine.
  12. Mar 26, 2020 at 12:20 PM
    AZtrkbabe
    Thanks for the great info everyone! Much appreciated!
  13. Mar 26, 2020 at 1:06 PM
    jmauvais
    NorCal
    ...stuff
    thank you, I typically don’t go near those so I didn’t realize there was a difference. Good catch
  14. Mar 26, 2020 at 1:09 PM
    tcjacado
    tcjacado Well-Known Member
    That -25 is the offset, not the backspace
  15. Mar 26, 2020 at 1:10 PM
    bigmace
    bigmace Well-Known Member
    Salem, OR
    2020 DCLB SR5 4x4
    There are no 5 lug 3rd gens...
  16. Mar 26, 2020 at 1:26 PM
    karatescotty
    Beaverton, OR
    2019 TRD Pro
    Whoops you are correct
    tcjacado[QUOTED] likes this.
  17. Mar 26, 2020 at 1:30 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Yes it does, But is not necessary for a 2wd. The only thing a drop bracted kit does is drops the front diff down to help with the CV angles. Just buy some 4 inch lift spindles and some 5100 and set it to the 2 inch lift setting and you'll have the same amount of lift without all the added components or cutting your frame.
    Sorry just read that you are looking for 2.5 to 3inch. As long as you have a non 5 lug it will fit
  18. Mar 27, 2020 at 3:16 PM
    HBMurphy
    Paul
    So California Coast
    None
    copy
