Will 4Runner seats fit Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaBanjo, Sep 21, 2018.
  1. Sep 21, 2018 at 7:47 PM
    ToyotaBanjo
    ToyotaBanjo [OP] Well-Known Member
    Outer banks
    2006 DC 4x4 Sport
    None
    i have 60/40 bench in my 2002 manual 4x4. Want to go to bucket...
    Have found a set out of a similar year 4 runner. Will they fit?
    Any issues I should know of?
  2. Sep 21, 2018 at 7:51 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You will need to modify the bracket a little but it will bolt it
  3. Sep 21, 2018 at 8:23 PM
    tony2018
    tony2018 Well-Known Member
    some custom work is required.
  4. Sep 21, 2018 at 10:49 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    3 out of 4 will bolt right up, last one needs some love
  5. Sep 21, 2018 at 11:36 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    I just did this. Swapped some 4runner cloth seats w/ bottom tilt adjust and lumbar. Only the two brackets on the passenger side seem to work. Once you line up and smash in the front driver bracket so it is 90 degree like on the stock taco ones it will mess up the integrity of the bracket and the rear driver will be sitting way too high to even stack washers or some other janky setup. I opted to cut off both driver side brackets and use some 1/4" plate and gusset those so they're stronger than factory. Better safe than sorry in an accident imo.
    Bleedgreen likes this.
  6. Sep 22, 2018 at 4:32 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Thanks burro. So I understand- are you saying this applies only to drivers side seat? Does the passenger side seat fit OK or do you have to modify both seats?
    Also, is there any way I can personal message a member on here?
  7. Sep 22, 2018 at 5:03 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    "Also, is there any way I can personal message a member on here?"
    Click "start a conversation" under their avatar
  8. Sep 22, 2018 at 6:27 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I installed 4runner seats in my 98 and had no problems, 2 of the attachment locations had to be massaged and forced a bit but the seats fit just fine and much more comfortable than the stock ones.
  9. Sep 22, 2018 at 6:44 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    But mine is an 02...would anyone know if 02 and 98 seats bolt patterns are the same?
