Will 19" Venza Rims fit on a 2010 Std Cab 5 lug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jclous2000, Feb 20, 2019.
  1. Feb 20, 2019 at 3:12 PM
    jclous2000
    jclous2000 [OP] Member
    Jim
    2010 Tacoma Regular Cab White
    Newbie to the forum...I have done some research and the Toyota Venza rims have the same bolt pattern as my 2010 base 2WD Tacoma...Venza rims specs are as follows: 5 lug 4.5 inch or 114.3mm High Positive Offset. I also read the Venza rims are 35mm offset. Has anyone done this?
    Thanks in advance....
  2. Feb 21, 2019 at 12:28 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    It'll fit but unfortunately, you will spend more $$ for 19" tires along with less rubber/more rim look. If you plan on using your vehicle like a truck, that route is not ideal.
  3. Feb 21, 2019 at 1:31 PM
    jclous2000
    Jim
    your probably right...I will try locate some nice 17" 5 lug alloy rims from a Highlander, Rav4 or Camry...thanks
  4. Feb 21, 2019 at 1:42 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  5. Feb 22, 2019 at 11:07 AM
    Master Z
    Master Z Well-Known Member
    2010 Tacoma 4.0L AC SR5 Prerunner BSP
    Peachy Peach Little Tree Air Freshener
    Aren't the Venza wheels 20's? I think it would look good. They look great on alot of other Toyota vehicles.
    I'd imagine you'd want to run a spacer if you don't want a sunk in look, also to probably clear the caliper.
    You see alot of trucks here running 20's.
