Will 06 Tundra wheels fit my Taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by raghorn, Feb 8, 2013.
  1. Feb 8, 2013 at 7:52 PM
    raghorn
    raghorn [OP] Member
    ms
    2003 taco
    Can I run 2006 17" Tundra wheels with 265-70-17's on my 2004 double cab TRD Taco 4wd with factory suspension?.............................
  2. Feb 8, 2013 at 7:58 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
  3. Feb 8, 2013 at 8:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Factory backspacing on the tacomas is 4.5"
    Backspacing on the tundra 17" wheels are 5"
    That means the tire will be 1/2" closer to the UCA/frame than whit stock wheels. And by stepping up to 265's, you might be cutting it close.
    But yes...bolt pattern is the same.
  4. Feb 9, 2013 at 4:10 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    I thought the Taco came with 265's?
  5. Feb 9, 2013 at 7:09 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    265/70/17's is what the 1st gen tundra, second gen taco, and 4th gen runners came with stock.
    First gen tacos either came with 225/75/15 or 265/70/16.
  6. Feb 9, 2013 at 10:41 AM
    kryten
    Canada
    Not sure about the 4runner or Tundra, but 2nd gen Tacos come with 265/70/16 or 265/65/17 stock in TRD trim not 265/70/17. SR5 or base 6 lugs come with 245/75/16. [​IMG] ...But that again it is probably irrelevant in a 1st gen forum...:eek:
  7. Feb 9, 2013 at 11:41 AM
    Devout
    Seattle
    03 TRD 4X4
    None yet
    Thanks for the clarification.
  8. Feb 9, 2013 at 1:50 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Whoopsie. You are correct. I meant 265/65/17 for all 3.
  9. Feb 11, 2013 at 3:29 PM
    raghorn
    raghorn [OP] Member
    ms
    2003 taco
    Anybody running GMC/Chevy wheels on their Taco?...................
    Thanks for the information guys.
  10. Feb 12, 2013 at 4:28 AM
    toys4ever
    toys4ever Well-Known Member
    PA
    01 4x4 4-banger stick
    GM wheels will not fit a Toyota, the center of the wheel is not bored big enough for the hubs. With that being said a Toyota wheel does fit a GM, not sure about back spacing spec though.
