Wilco Hitchgate Solo vs. Rigd Supply UltraSwing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 508Tacoma, Feb 4, 2020.
Wilco or Rigd?
  1. Wilco Hitchgate Solo
    8 vote(s)
    23.5%
  2. Rigd Supply UltraSwing
    26 vote(s)
    76.5%
  1. Feb 4, 2020 at 8:23 AM
    508Tacoma
    508Tacoma [OP] Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    I've been looking for a solution to get my spare out from under the spare tire location and onto my hitch. It seems the best two options for a hitch mounted spare tire carrier are either the Wilco Hitchgate Solo or the Rigd Supply UltraSwing. If you own either of these would you be able to leave a little review or pro/con of your setup. Much appreciated.
    Wilco Hitchgate courtesy of @Unchained 5150 from the Wilco website
  2. Feb 4, 2020 at 8:36 AM
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    Personally, if I was going to purchase I'd go with the rigd since it maintains better ground clearance and departure angle.
  3. Feb 4, 2020 at 8:36 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I love mine never had an issue and that picture was the older version. I have the High Clearance Version now. And soon they will be sending me their offset version to test with all new locking mechanism etc. Powdercoating is immaculate even after 4 years in the Salt Belt.
    508Tacoma[OP] likes this.
  4. Feb 4, 2020 at 8:38 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  5. Feb 4, 2020 at 8:38 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  6. Feb 4, 2020 at 10:25 AM
    cloudr1pper
    cloudr1pper Well-Known Member
    I was going back and forth between the two as well. When that Rig'd Holiday deal popped up I jumped on that.
    They're probably both fine though. Rig'd touts the zero wobble and I can attest to that. If you ride, the bike rack mount on the swingout is nice as well.
  7. Feb 4, 2020 at 10:30 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I've installed a few of the Rigd on various platforms and can say that we've beat the hell out of it and it doesn't make a sound.
  8. Feb 4, 2020 at 10:30 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Curiously, what is the intention of using this? If not for four wheeling, what is gained? And if for four wheeling, it looks like the gains would minimal if theyre even are any. Is this just so that the spare is more accessible in the event of a flat?
  9. Feb 4, 2020 at 10:39 AM
    seelyartacus
    San Diego
    in our cases it was to be able to carry a spare at all. upgraded tire sizes didn't allow a spare to be carried in the stock location. It also allowed for additional components to be carried e.g. tables, hi-lifts, etc. It also provided the ability to remove it all when the vehicle is just visiting the mall.
    Requital and johntoyota[QUOTED] like this.
  10. Feb 4, 2020 at 10:41 AM
    johntoyota
    Down yonder in TN
    16 truck
    Makes sense to me. I am one size away from not being able to carry one underneath so next set of tires Ill be doing HC with a swing out. Just wasnt sure outside of four wheeling. Cheers :cheers:
  11. Feb 4, 2020 at 10:41 AM
    Yooperchap
    Yooperchap Active Member
    2017 Tacoma TRD Off Road
    Where did you get that bedside bike mount? How does it do at freeway speeds?
  12. Feb 4, 2020 at 10:47 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not made anymore and it's fine at any speed
  13. Feb 4, 2020 at 10:54 AM
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
  14. Feb 4, 2020 at 10:56 AM
    cloudr1pper
    Mainly storage and ease of daily use. I camp in the bed and didn't want to toss traction mat's, gas tanks, shovel, and ruck sack back there then pull everything out and relocate before calling it a night. Also wanted to keep the ability to take everything off when not in use. The only trails I do are desert washboards, forest service roads, and mild rocky terrain. Nothing gnarly so don't need high clearance and no point having the weight of a full bumper on the truck everyday.
  15. Feb 4, 2020 at 11:05 AM
    Tsinajinii
    Jamin
    AZ
  16. Feb 19, 2020 at 3:58 PM
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    Ordered a Rigd ultraswing over a month ago. Not a single response from the company in any way.
    Today I called them to see why I haven't heard anything and they didn't answer the phone.
    I just canceled my order, as that's wildly unprofessional.
  17. Feb 19, 2020 at 5:45 PM
    drewkillsit
    drewkillsit Well-Known Member
    Drew
    Colorado
    2018 Tacoma TRD Off-Road
    Bummer. I asked Prinsu for some help a while back numerous times and never heard back. Love my rack, but it changed my opinion of them.
  18. Feb 19, 2020 at 6:48 PM
    Sclarpepplar
    Corey
    2016 TRD sport
    I was lucky enough to buy my prinsu rack through a local company, so I wouldn't ever have to deal directly with them. Like you, I too love the product though.
    Chasing manufacturers is the worst. I'm sure I would have enjoyed the swing out, but I gave them over $1000 for a month, and recieved no word. Website says two weeks for shipping though!
  19. Feb 19, 2020 at 7:16 PM
    RisingWithoutWings
    RisingWithoutWings Well-Known Member
    SoCal
    2016 Tacoma TRD Off-Road
    I called them today and got an answer. They said they have a enormous amount of back orders that they're currently filling. I asked about local pickup but they said it's still 2 or more weeks out. I'd really like to order one too but need something sooner.
  20. Feb 20, 2020 at 5:01 PM
    FishN'Taco
    FishN'Taco Well-Known Member
    lucas
    San Diego, CA
    18 TRD OR DCSB
    Fox 2.5 Ext Travel w/ Adj Reserviors (3") ACCUTUNED Camburg Uniball UCA Deaver u402 stage 1 Leer 100XQ Front Runner Slimline II Rack Baja Designs Onx6+, SQ-Pro, SQ-Sport Switchpros 9100 285/70/17 Falken AT3W on 17 Method 305 NV RIGd Ultraswing Powertank 10lb
    That's very surprising, did you try emailing or using their website contact?. i've always had a response from someone within 1 day, normally a few hours whenever i have questions about product or order updates. great customer service in my opinion but thats speaking from my experience with them. from the last update i got a few days ago they are back from powdercoat and are now shipping.
