Wife ran into garage door - help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, May 5, 2023.
  1. May 5, 2023 at 6:41 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    So… my wife ran the top of truck into the garage door (it was closing), got the shark fin snagged, which pushed down on the roof and it dented the roof pretty bad and also damaged the antenna. Also, and you cannot see it that well in the pictures, but there’s a large gap of maybe an 1/8” now between the antenna and the roof (the antenna cover) but the base seems to still be secured to the roof.
    Body shop started talking about bondo and respraying and I said no way. Not because of the money but because that kind of work always has issues.
    My other option is to take it to my ceramic guy who has a good PDR guy and he said they can drop the headliner, push the dent out, put a new antenna on flush (hopefully), put the headliner back, then the ceramic guy will paint correct. (I am meeting with them both tomorrow AM.)
    The one thing that stresses me out the most is the messing around with the headliner. I’m OCD as fuck and have been told multiple times that once you remove it it will “never be the same” whatever that means. Will it rattle? Will there be gaps? Who knows. **shudder**
    So … question… can you access the underside of the roof through the third brake light to swap antenna and do PDR? Why not do it that way? It appears to be right there.
    I also thought to just leave it alone. Do nothing. If so, is there much risk that it’ll leak under the antenna? I know it’s bolted down but I don’t know if it got moved or if a gasket was dislodged (even though the base looks secure). I will always wonder if it is leaking. I hate that feeling.
    Maybe try to take off the antenna cover and work with the sheetmetal then put on a new cover? The antenna is two pieces … but I have no idea how the top piece secures to the bottom piece (parts in the mail).
    There seem to be no good options. I don’t mind spending money but I see no good path forward.
    Any helpful advice welcome.
    See dimple behind the shark fin.
    this shows the whole roof is pushed down.
    Gap under shark fin
  2. May 5, 2023 at 6:43 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Sorry OP!!
  3. May 5, 2023 at 6:43 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Insurance.
    Sdswingr, 2016Tacoman, Chew and 4 others like this.
  4. May 5, 2023 at 6:50 PM
    TacoRancher
    Houston
    Yeah. I’m pretty sad. I spent a lot of effort getting this truck and making it how I wanted it. A lot of my enthusiasm around it now feels deflated. I’m not really interested in making an insurance claim. It’s not a financial issue it’s more that I don’t like the options to fixing it.
    TwinTaco31719[QUOTED] likes this.
  5. May 5, 2023 at 6:51 PM
    TacoRancher
    Houston
    Looking for best methods of repair. Not asking about insurance.
  6. May 5, 2023 at 6:56 PM
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    Hard to say from pics but, I *think* a good PDR tech could work that back to mint.
  7. May 5, 2023 at 6:59 PM
    TacoRancher
    Houston
    Thanks bro hoping so. Is the headliner process less of a big deal than I’ve been told?
  8. May 5, 2023 at 6:59 PM
    AustinNative
    ATX
    PDR Techs fear no headliner.
    50Buck, specter208, ALI3N_123 and 4 others like this.
  9. May 5, 2023 at 7:02 PM
    tstad9i
    tstad9i Well-Known Member
    2022 Blue Tacoma Off Road
    I would wonder about future leaks as well if you left as is. Not sure how else you would test other than to add water and see what happens. Me, I would intentionally hunt down a body shop or two that have a reputation of being expensive. Might be because they would fix correctly with minimal filler, and know how to put that headliner back on correctly if needed.
    PDR sounds good as well but then again, will they smooth out the sheet metal well enough for that fin to sit flush enough to prevent ingress.
  10. May 5, 2023 at 7:05 PM
    TwinTaco31719
    Eric
    Glenbrook, NV
    I’m always shocked at what PDR guys can do. I’d guess they may even have a suction method with heating up the sheet metal where you wouldn’t have to mess with the headliner. If at least ask about options not involving headliner
    AustinNative likes this.
  11. May 5, 2023 at 7:09 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    I wouldn't sweat about them dropping the headliner. It's really not that big of a deal. Mine was removed to PDR some hail damage and you'd never know it.
    50Buck and AustinNative like this.
  12. May 5, 2023 at 7:15 PM
    TacoRancher
    Houston
    All helpful comments thanks guys
  13. May 5, 2023 at 7:17 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’d drop the headliner for sure. PDR next. Then sound deadening after. Then reinstall the headliner. Seats will be out during the repair. Do it yourself if you feel confident (except the PDR part) or hire it out.
    wife owes you so treat yourself to some coilovers or wheels or something.
  14. May 5, 2023 at 7:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dood I can tell you won't be satisfied with whatever fix anyone does. Breathe.
    Accept. Move on.
  15. May 5, 2023 at 7:24 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    New wife, current model can't drive.
  16. May 5, 2023 at 7:25 PM
    TwinTaco31719
    Eric
    Glenbrook, NV
    Haha coil overs for sure!!
    Malvolio likes this.
  17. May 5, 2023 at 7:27 PM
    Whitetac0
    Whitetac0 Active Member
    David
    2021 Tacoma trd off road 4x4
    Put Some clear silicon under the shark fin and call it a day .
  18. May 5, 2023 at 7:27 PM
    chiffonade
    chiffonade Well-Known Member
    a good PDR guy or body shop will fix that just fine. good body shops do not use bondo, they fix it to OEM spec with no exceptions - if they can't do it, they'll tell you. find one that does a LOT of insurance work and ask for their out of pocket price. just like a doctor's office.
    Chew and TacoRancher[OP] like this.
  19. May 5, 2023 at 7:32 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    A good PDR guy can get that out 110%
  20. May 5, 2023 at 7:34 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    PDR as best can be done and then learn to love any remaining battle scars. And don't be too tough on the old lady over this. It'll make a great story with the grandkids every year at Christmas dinner
    specter208 and Thatbassguy like this.
