Wi-Fi camera for truck bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoPacific, Aug 24, 2021.
  1. Aug 24, 2021 at 4:15 PM
    TacoPacific
    TacoPacific [OP] Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    Anyone know if you can or of anyone who has rigged a Wi-Fi camera for monitoring cargo in the bed.
    for instance to watch dogs don’t chew on luggage or to see if things shift around etc?
    Is it even possible?
  2. Aug 24, 2021 at 4:19 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Yes there are ways of doing it, but it's a solution to problems you shouldn't have in the first place.
    Always secure your cargo.
    Put your dogs in travel safe kennels and then secure the kennels.
    ret42, grandpawmoses, HisDad and 2 others like this.
  3. Aug 24, 2021 at 4:20 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    2CH dash cam watches cargo in the bed, but you only get to see it after it's happened.
    Skydvrr likes this.
  4. Aug 24, 2021 at 4:21 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Wifi to the head unit would probably be impossible without some extra adapter converting to rca. Using your own monitor /receiver sure why not.
    But there are probably better solutions.
  5. Aug 24, 2021 at 4:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have a front dash cam and rear dash camera. Tapped into the fuse of the cigarette socket and installed 12v sockets underneath the dash.
    Rainoffire and TacoPacific[OP] like this.
  6. Aug 24, 2021 at 4:28 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Learn knot tying and strap use. Then you don't need a camera. Dogs should be inside or in a kennel if in back.
    Rock Lobster and Unchained 5150 like this.
  7. Aug 24, 2021 at 4:29 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    You could get the anytimebackupcamera kit and out the "front" camera somewhere in the back. Simple switch displays it in the head unit
    caribe makaira likes this.
  8. Aug 24, 2021 at 6:09 PM
    TacoPacific
    Vancouver BC
    That is an idea indeed! Good thought.
  9. Aug 24, 2021 at 6:11 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yep anytime cam or dash cam you can connect to through wifi
  10. Aug 24, 2021 at 6:47 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Yes its possible and its real easy. Purchase one of these camera controls along with a camera from Amazon or ebay and instead of mounting the camera in the front grille, like most of us are doing, mount the camera in the bed of the truck.
    Best thing about this setup is that you can watch the live video on your factory stereo display even while you're driving.
  11. Aug 24, 2021 at 10:09 PM
    TacoPacific
    Vancouver BC
    Perfectly En Pointe! Going to look into this.
  12. Aug 25, 2021 at 8:58 AM
    TRD2021SPORT
    Trust me you'll like, perhaps even love it. I'm running the Germes control and love how it operates with the factory steering wheel switches.
    There is an empty plug on the floor towards the rear of the passenger seat on the floorboard that you can use to run the camera wires to the bed. Well it should be empty unless you have the remote tailgate lock but even if you do have the tailgate lock you should be able to run the bed camera wiring through the same hole, then underneath the passenger side door sill, then up the passenger side kick panel, and finally behind the dash to the back of the radio.
  13. Aug 25, 2021 at 2:51 PM
    TacoPacific
    Vancouver BC
    Ok awesome! I do have the power tailgate lock… but that makes sense for routing.
