why NOT an ARB bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Nov 2, 2020.
  1. Nov 2, 2020 at 7:19 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Are there any reasons NOT to get an ARB bumper?
    Why do people get other brands?
    I hear ARB is the best.
    Just noticed Coastal Offroad's is cheaper. $600. Originally assumed all steel bumpers are about the same ~$1k price.
    I can't tell if the ARB worsens approach angle
  2. Nov 2, 2020 at 7:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Because they weigh a ridiculous amount and there are lighter options. ARBs do look good though and are one of the only ones actually crash tested.
    tacoman45, photogr4x4, DaleRS and 4 others like this.
  3. Nov 2, 2020 at 7:23 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    I love the ARB. The only con is that it looks funny on a 2.5 gen, and it weighs a good bit.
  4. Nov 2, 2020 at 7:24 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    I'm not a fan of the way it looks. Its very "boxy" and square which imo doesn't look good on the 05+ trucks since the lines are more rounded than a 1st gen. They're good bumpers but I prefer my 1/1 custom made one that ended up being cheaper than any one bought from a name brand. It's also very heavy and unless you're going full broverland, its unnecessary weight compared to lighter ones.
  5. Nov 2, 2020 at 7:27 PM
    TacoTuesday1
    FL
    oh man. That review video said they designed it to be as light as possible
    but it's the only time I've heard that and they look heavy
  6. Nov 2, 2020 at 7:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Check the weight specs. I believe it is well over 100lbs.
  7. Nov 2, 2020 at 7:32 PM
    DanaPtTaco
    Thomas
    Orange County, CA
    They can try and make it lighter, but at the end of the day, its a full steel bumper that they need to keep their safety standards with so no cutting corners in the name of weight reduction.
    Bridge4, Biscuits and SR-71A like this.
  8. Nov 2, 2020 at 7:32 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Key word is they crash test which most aussie brands do because of the very strict vehicle modification laws there. Still it isn't "US DOT approved" since it didn't go through the crash test standards that are set by DOT. But I mean does that really matter since many other things alter the crash ratings that we don't typically think of.
    Approach angle is worse. You can get lighter options. No recovery points you add those to the underside of the truck where they get smashed. Expensive compared to competitors. The coastal is not welded you have to weld it up or pay them to weld it up.
    Why do people get other brands; looks, approach angle, strength, lighter weight, aluminum option, recovery points, hoop design is better, can run choice of pods for fogs compared to stuck with ARB brand, can paint or PC whatever color they want (bare steel). Want something american made.
  9. Nov 2, 2020 at 7:35 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Try close to 200(with winch) :D I'm sure there are better bumpers, but I wanted an ARB just for the Aussie look. And until I get sponsored or some person that wants to pay for my shit………………….that's what I got :rofl:
    JKU3000, Biscuits, drewnali and 7 others like this.
  10. Nov 2, 2020 at 7:38 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^^^ FTMFW OP!
  11. Nov 2, 2020 at 7:47 PM
    TeXanTRD
    TeXanTRD Well-Known Member
    2013 TX TRD
    I believe you’d want to beef your suspension up for one of those as well. It’s one of those things with a lot of hidden costs beyond just the bumper.
  12. Nov 2, 2020 at 7:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^^ too OP!
  13. Nov 2, 2020 at 7:55 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    also no front recovery points
    BassAckwards and RobP62 like this.
  14. Nov 2, 2020 at 8:02 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^^ three OP!
  15. Nov 2, 2020 at 8:13 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Why NOT to get one?
    They're heavy.
    They reduce your approach angle unless you've got a stupid tall lift, and even then they still reduce your approach angle.
    They require ARB's foglights unless you want to mess around with trying to modify the plastic fog light surround to work with the stock Tacoma fog lights
    The included turn signals are super chintzy and prone to filling with water
    The electrical connections are cheap and not water resistant. Plus they include Skotchloks, so you can be guaranteed electrical issues down the road.
    The black powdercoat that they use will fade over time
    The newer gen bumpers make your truck look like it has a serious case of underbite.
    No front recovery points (though in fairness even their early Tacoma bumpers didn't have "recovery" points, they were meant for connecting a hi-lift with a shackle...also, they have a great explanation for why they don't do that and it largely comes down to people are morons)
    And, they're heavy.
    Oh, and the hardware used for mounting the skid plate is mild steel
    So... why TF would you get one?
    Well, they're designed for hitting stuff. By "designed", I'm not talking about looks. There are tons of little things that they do that all add up to a bumper that is designed to be a protective barrier between you and whatever you're about to hit. The hoops, for example, pass through the top part of the bumper and tie into the bottom, increasing the strength and the ability for the hoops to absorb energy. The mounting brackets are designed to spread the load down the frame rails, making the bumper more likely to stay put and not flex up or down in an impact. I'm not talking about the little kisses and love taps that you deal with on a trail. They're designed to clobber a kangaroo at 70mph while giving you a chance to drive your truck home. Yeah, I know, I've never seen a kangaroo on any of the trails that I explore. Hell, I rarely see deer on the forest roads. They know better. The deer in my neighborhood on the other hand are morons. What I do see on the forest roads are lots of f'n Subarus driven by people who think that forest roads are their own personal closed off WRC course while they haul ass to get to their Sierra Club group hike. Nothing against them really, but I'd personally rather use up an asshat's crumplezone before mine starts coming into play.
    If I were building a rock crawler or trail rig then I would not go ARB. My truck is a family hauler. For me, the ability to get home is more important than being able to see if I can get my wheel onto a rock taller than my children. For what I do, I feel that ARB is the best tool for the job. I've got one on my 1st gen, got one on my 2nd gen.
  16. Nov 2, 2020 at 8:14 PM
    ekliptiko
    ekliptiko Well-Known Member
    Portland, OR
    Coastal offroad is a diy weld-it-yourself kit, BTW. Hardly apples to apples comparison with ARB.
    Dye22 likes this.
  17. Nov 2, 2020 at 8:57 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    FYI, you arnt stuck running their fog lights :D we make a bracket to run aftermarket lights.
    i went with arb as it was crash tested and i do like the looks. next choice is a cbi alu bumper :D
    llamasmurf and crashnburn80 like this.
  18. Nov 3, 2020 at 2:38 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    Fair question. ARB bumpers weigh a sh!t ton, require you to beef up your suspension, don't improve your approach angle, and stick out really far. Why did I get one? Read here:
    https://www.tacomaworld.com/threads/a-non-enthusiasts-tacoma-build.667560/page-3#post-24169871
    You can get front recovery points, if you like. ARB P/N 2823010 or similar from another manufacturer.
  19. Nov 3, 2020 at 2:45 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Yup. Gonna order those. I have your fuse panel :D
  20. Nov 3, 2020 at 2:51 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    ARB was at the top of my list....until I saw it in person. It's just so oversized! It's like when you're a kid and you want to put your GI Joe in your cool Lego car. The proportions just don't match up. The 2.5 Gen also requires you to cut up your original bumper if you want it to look closer to right.
    They are BEEF though. And I always turn to look when I see one. They're well engineered and purpose-built. But not for me.
    I hunted for a Pelfreybilt aluminum bumper for almost 2 years before I was lucky enough to find one a few hours from home.
