Why is the serpentine belt tensioner pulley bolt reverse thread?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Oct 4, 2019.
  1. Oct 4, 2019 at 10:25 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m am always the one to question things.
    Is the reason that the the pulley is reverse thread because,
    You have to use the pulley bolt to release tension on the belt.
    Which requires you to turn the bolt Counter-Clockwise.
    And doing this to a Standard Thread bolt cause it to potentially loosen the bolt?
    My Older Pre-Runner had 2.7 had a separate spot on the tensioner you used.
    Not the actual pulley.
    Dm93 likes this.
  2. Oct 4, 2019 at 10:28 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    It is L/H threaded so the rotation of the belt and pulley will not cause the bolt to loosen and come out.
  3. Oct 5, 2019 at 12:40 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
    Dm93 and TomTwo[QUOTED] like this.
  4. Oct 5, 2019 at 1:22 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    New 2.7 does have serp belts. The motor is still used up to 2020 just “advanced”
  5. Oct 5, 2019 at 1:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Old cars used to have reverse thread lug nuts on one side of the car to prevent loosening as well.
    PzTank, 6 gearT444E, Dm93 and 3 others like this.
  6. Oct 7, 2019 at 4:57 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    As said, some old cars and trucks had reverse thread lugs on the LH side. IIRC, Chrysler did this in the 60s-70s. The logic is that the tire rotation when going forward "tightens" the nuts. Unnecessary, but...
    Dm93 likes this.
  7. Oct 7, 2019 at 5:28 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    o_Ouhh Same logic as the belt pulley.
  8. Oct 7, 2019 at 5:42 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Cars have had some type of reverse thread bolts/nuts for many decades British wire wheel cars have left and right hand wheel nuts as do some race cars. I can tell you this I have seen wheels come off British cars if they are towed backwards for any real distance it's all about rotation.
    Dm93 likes this.
  9. Dec 17, 2021 at 4:49 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    How do you torque the pulley bolt (reverse thread) to spec when turning it counterclockwise moves the tensioner?
  10. Dec 17, 2021 at 4:55 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Had a 70 Chrysler Belvedere with reverse threads on one side. Think it was the driver's side. There was a notch in the lug nuts so you didn't mix them up.
    b_r_o likes this.
  11. Dec 17, 2021 at 5:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You got it, the ones that pivot in the other direction have right hand thread.
    Yep I have an 84 F-250, the left side lugnuts are left hand (reverse) thread and the right side are right hand (standard) thread.
  12. Dec 17, 2021 at 5:44 PM
    Sharky
    Sharky Well-Known Member
    Jon
    Utah
    White '12 DCSB TX Pro (also retired)
    Handicap Parking Permit
    Yeah, that was ChryCo vehicles. I had to rotate my own tires because the idiots would spin them off at the tire shop. A lot of us would switch the bolts on the passenger side on our Mopars to just be done with shops reverse threading them and ruining the lugs and having wheels fall off.
  13. Dec 17, 2021 at 7:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Chrysler Vehicles were like this.
  14. Dec 17, 2021 at 7:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I have never seen this "feature" on a Ford...
    wilcam47 likes this.
  15. Dec 17, 2021 at 8:07 PM
    Sharky
    Jon
    Utah
    Could have been a fleet vehicle. Randomly…. Fleets would have all sorts of random options or things they would add at delivery. Especially government vehicles, so they could keep service consistent. My dad used to do all of the negotiating and purchasing on vehicles for the federal government on the west coast. Some of the stories he had about negotiations and requirements were absolutely hilarious.
  16. Dec 17, 2021 at 9:13 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That would annoy the shit out of me lol
    wilcam47 and TnShooter[OP] like this.
  17. Dec 17, 2021 at 9:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just turn it until it stops and torque the bolt. You're not going to hurt it
    TnShooter[OP] likes this.
  18. Dec 17, 2021 at 9:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve run across the occasional reverse thread fastener. Usually accidentally. Accidentally snapped it off. Accidentally discovered, it’s stuck, shoot some penetrant, try going back and forth loosen tighten, oh it’s turning. You’d think they’d somehow identify it with some piss yellow paint, or a R stamped into it, something. When you snap it off, extracting it is a pain. Drill with a regular instead of reverse bit hoping it grabs and backs out. Only choice is a straight flute extractor.
    Dm93 likes this.
  19. Dec 17, 2021 at 9:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's not a fleet truck, my Grandpa bought it new in 84 I have it now it currently has 313k miles on it.
    It's not quite as shiny anymore but this is what it looked like in 2010 when I got it.
  20. Dec 17, 2021 at 10:49 PM
    TnShooter
    Deogee
    STOCK
    FWIW, I asked the question over 2 years ago.
    I forgot I even asked it. :rofl:
    Dm93 likes this.
