Why is one wheel always at low psi even after new tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Apr 27, 2022.
  1. Apr 27, 2022 at 11:41 AM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Just before I got new tires I noticed my back left tire would be low a few times at 17 psi where all the other would be around 32 psi where I want them. I figured that one must have a small leak and that my new tires would fix that. Just got these kendas on a few weeks ago and I noticed the same back left wheel was at 8 psi this morning! Suppose to be at 38ish. So I’m a little confused since it can’t be the tires. Do the valve stems go bad over time? What else am I missing. Hoping it’s just a silly fix. Thanks gentlemen.
  2. Apr 27, 2022 at 11:57 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    it could be a crack or deformation in the wheel or the valve stem. The tire shop should diagnose it for free if you tell them it has a slow leak.
    JudoJohn likes this.
  3. Apr 27, 2022 at 11:57 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You should get new valve stems with new tires. The problem may be the wheel, not the tires.
  4. Apr 27, 2022 at 11:58 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    New tires should get new valve stems.
    Ask to have the bead seatings deburred, cleaned and polished as well.
    treyus30, Abeyancer and Wulf like this.
  5. Apr 27, 2022 at 11:59 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Do the tires need to be removed for this or is this something I can do myself
  6. Apr 27, 2022 at 12:07 PM
    Black DOG Lila
    Virginia
    Tires have to come off rims to replace valve stems and clean bead surfaces
    Abeyancer likes this.
  7. Apr 27, 2022 at 12:11 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    New tires on old wheels, and the problem persists, even worse, I'd say wheels.
  8. Apr 27, 2022 at 12:15 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Lovely. Now I have to find a shop that won’t mind working with wheel spacers. Thanks for the info.
  9. Apr 27, 2022 at 12:27 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Discount tire said they can do all 4 for $20. That sound right? I was expecting more.
  10. Apr 27, 2022 at 12:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Spray some soapy water on the valve core and look for bubbles. The little core can be easily swapped out
    Also the rubber seal at the base of the stem can leak. Parts stores should have a "TPMS service kit" that comes with the nut, washer, rubber grommet and new valve core.. usually just a few bucks
    Wulf and LOLLY like this.
  11. Apr 27, 2022 at 12:30 PM
    Wulf
    rock raisin
    before you throw parts at it, tell them you have a slow leak and let them dunk it in their tank to identify the actual problem. They shouldn't charge you to diagnose it.
    but $5 ea sounds good for parts and labor
    treyus30 likes this.
  12. Apr 27, 2022 at 12:32 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    What @b_r_o said! I sprayed Windex on my valve and instantly saw bubbles when I had this issue
    Wulf likes this.
  13. Apr 27, 2022 at 12:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oops just realized I'm in the 1st gen section.. no tpms seals to replace. If the valve stem is leaking just replace it.
    Tire shop shouldn't even have to re-balance the tire, just pop the bead and sneak a new stem in there
    Clearwater Bill and Wulf like this.
  14. Apr 27, 2022 at 2:08 PM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    Logans2001[OP] likes this.
  15. Apr 27, 2022 at 2:54 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Just had discount tire do them for $20 and the mechanic said they did look pretty old so that’s a relief. My buddy’s shop was suppose to replace them when the tires went on but I guess they forgot. Will update if the problem persists. Thanks gents.
    jammer likes this.
  16. Apr 30, 2022 at 9:13 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Got back home yesterday to find my front right tire at 10 psi but the back left is holding fine now as well as the other two. They weren’t supposed to rotate them.
    The mystery continues…..
  17. Apr 30, 2022 at 9:17 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You might want to install a ring camera to catch the valve stem gnomes that are pranking you at night.
    Logans2001[OP] and Wulf like this.
  18. Apr 30, 2022 at 9:17 AM
    Wulf
    rock raisin
    Did you get the premium air?
    b_r_o likes this.
  19. Apr 30, 2022 at 9:23 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Well of course. Only the best.
  20. Apr 30, 2022 at 10:19 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Pretty sure 01’s did t have TPMS.
