Why is my white Tacoma different shades of white?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tarbaby, Feb 21, 2014.
  1. Feb 21, 2014 at 5:54 PM
    Tarbaby
    Tarbaby [OP] Member
    Prerunner SR5
    Stock
    New 2014 Tacoma. 500 miles on it and I am looking at it and I notice the doors are two different shades of white. The fender flares are different than the body.. Common or should I do something about it? Live with it?
  2. Feb 21, 2014 at 5:56 PM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    I cant tell
  3. Feb 21, 2014 at 5:58 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    I kinda see the rear doors a bit darker than the front...maybe just the lighting?
  4. Feb 21, 2014 at 5:59 PM
    Tarbaby
    Tarbaby [OP] Member
    Prerunner SR5
    Stock
    The drivers door and the flares seem to be one shade of white and the rear door and the bed seem to be another shade of white... A little more grey looking. Almost like grey primer bleeding through.....
    If its a fuck up on Toyotas part at least they were symmetrical about it. Its the same on both sides!
  5. Feb 21, 2014 at 5:59 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    It's a Monday truck. The painter wasn't recovered yet.
  6. Feb 21, 2014 at 6:00 PM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    The flares are probably sprayed at another time off the truck my 2013 super white is the same thing with the flares.
  7. Feb 21, 2014 at 6:00 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The flares and other plastic pieces can sometimes look a bit different than the metal pieces in different lighting conditions but that shouldn't apply to a difference between the two doors
  8. Feb 21, 2014 at 6:03 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Is the front quarter panel the same as the back door and bed side? and just the door a different color?
  9. Feb 21, 2014 at 6:07 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    It is possible and has happened, but hopefully not to your truck...
    Cosmetic body damage could have happened at the dealership and they had it repaired. If so, I wouldn't count on a Carfax report for it.
    If it bugs you too much, ask the dealer about the color difference and if they can do something about it.
  10. Feb 21, 2014 at 6:09 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    This. My wifes super white T4R is the same way. Plastic pieces are slightly different color than the metal body pieces.
  11. Feb 21, 2014 at 6:13 PM
    Tarbaby
    Tarbaby [OP] Member
    Prerunner SR5
    Stock
    You know when you see a car with a bad paint job and you can tell it was in an accident and the paint doesn't match the new fender? That's what it looks like. Did Toyota use Earl Scheib on my truck? Hesitant to talk with the dealer cause we all know how that goes....
  12. Feb 21, 2014 at 6:15 PM
    Tarbaby
    Tarbaby [OP] Member
    Prerunner SR5
    Stock
    Yes, Both front doors seem as white as the flares but the body seems grey-er if that makes sense.
  13. Feb 21, 2014 at 6:20 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    The paint adheres to metal and plastic differently, and I think the flex additive changes the color just a hair. It's more noticeable on metallic colors though.
    Again, your case is different since the doors should both be metal. Front half built in San Antonio, back half built in Baja? (kidding)
  14. Feb 21, 2014 at 6:23 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    It's ruined....jk. I honestly can't see a difference.
  15. Feb 21, 2014 at 6:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This is actually true. Tijuana builds beds for all Tacomas and a portion of Double Cab front bodies. All non-Double Cab front bodies are built in SA. However, I believe the beds and front bodies are painted together in one facility.
    Take it to three independent collision shops and ask them to assess if the truck has been repainted. Hell, ask them if there's any collision repair...
  16. Feb 21, 2014 at 6:34 PM
    Coldfire
    Coldfire Well-Known Member
    All toyota plastic pieces are sub contracted out and painted separate from the vehicle
  17. Feb 21, 2014 at 10:05 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    It's hard to tell from pictures to be honest. Taking it to a auto body shop like KenLyns says will probably be the best bet imo. They will know what tell tale signs to look for if something has been repainted from damage on the lot.
    This actually happens soooooo much it's unreal. We get cars all the time that a lot jockey has scratched or dented and then they sell it as new. Kinda messed up.
  18. Feb 21, 2014 at 10:16 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    Your vin should tell you... second to last character I believe. :D
  19. Feb 21, 2014 at 11:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would take that shit back to the dealer and have them fix it. I am suprised that it was noticed during the delivery.
  20. Feb 22, 2014 at 4:24 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I have a Porsche and the doors look like a different color than the fenders, but it is the way light reflects off the car that causes this effect. May be the same on the truck. Take it to a independent body shop and have them look at it.
