Why Is My Tacoma So Slow and Gutless?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matt Starr, Mar 4, 2013.
  1. Jul 7, 2013 at 7:25 PM
    #101
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You have 6" of lift??
    Bye bye Aerodynamics..
    110k is timing belt time anyways.
    Still something is odd..
  2. Jul 8, 2013 at 4:57 AM
    #102
    andoskyy
    andoskyy Well-Known Member
    Have you tested the compression and timing?
    Maybe a bad injector?
  3. Jul 8, 2013 at 2:01 PM
    #103
    Matt Starr
    Matt Starr [OP] Active Member
    Lakewood, CO
    2003 3.4 5spd TRD Off Road
    6" Fabtech Lift
    The difference in drag coefficient between a stock taco and a 6" lifted taco is miniscule. Its not nearly enough to cause a drop in power and mpg. The only noticeable difference would be in the top end speed well above the tacos limited speed.
  4. Jul 8, 2013 at 3:28 PM
    #104
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Do a backpressure test already.
    A couple people have already mentioned clogged cat and the two main symptoms are lack of power and shitty gas mileage. It takes 10 minutes to diagnose clogged cats.
  5. Jul 8, 2013 at 9:33 PM
    #105
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Or a dented tailpipe.
  6. Jul 8, 2013 at 11:50 PM
    #106
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    :rolleyes: huh, seem like it's time for you to flush and drain your tranny for new oils.
  7. Jul 9, 2013 at 11:52 AM
    #107
    Matt Starr
    Lakewood, CO
    6" Fabtech Lift
    I'm still refusing to believe it has anything to do with the exhaust. I did do a visual inspection on the exhaust system when I first got it to make sure there weren't any dent or pinches from the previous owner taking it off road.
    I'll let you know if I end up putting my foot in my mouth. My stubborn arrogance often gets the better of me.
  8. Jul 9, 2013 at 5:18 PM
    #108
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Really?
    You stated earlier that your shotgun troubleshooting is getting ridiculous and yet you won't take 10 minutes to do a real diagnostics test to eliminate or confirm a problem? You'd rather just throw money and parts into it blindly to see if something else fixes it?
    You can't tell a cat is clogged by looking at it on the outside. Hell even if you don't have a BP test tool, just unbolt the 3 exhaust bolts before the first cat, slide it to the side and take it for a test drive. That's what I did with mine. It'll be loud as hell but my truck ran like a raped ape by comparison. A quick visual check with a flashlight afterwards confirmed the clogged cats.
  9. Jul 9, 2013 at 7:37 PM
    #109
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    A clogged cat kinda matches your symptoms, especially since you said it's gradually getting worse. I wouldn't expect that from a dent or pinch unless the pinch was near an angled piece of pipe and was bending and closing more over time.
  10. Jul 9, 2013 at 10:17 PM
    #110
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotta agree with this. What have you got to loose. Already tried everything else
  11. Jul 10, 2013 at 9:52 AM
    #111
    Matt Starr
    Lakewood, CO
    6" Fabtech Lift
    Ugh, ok, fine... I'll go get a back pressure test done :pout:
  12. Jul 10, 2013 at 2:29 PM
    #112
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    What would cause a clogged cat?
  13. Jul 10, 2013 at 2:33 PM
    #113
    otis24
    Mark
    California
    And the answer to my own question from Howstuffworks.com
    Causes of Catalytic Converter Failure
    There are two ways a converter can fail:
    • It can become clogged.
    • It can become poisoned.
    There really is no "inspection port" for the consumer or mechanic to see an actual clog in a converter. Often, the only way to tell if a catalytic converter is malfunctioning (plugged) is to remove it and check the change in engine performance. When a clogged converter is suspected, some mechanics temporarily remove the O2 sensor from the exhaust pipe ahead of the catalytic converter and look for a change in performance.
    A catalytic converter relies on receiving the proper mix of exhaust gases at the proper temperature. Any additives or malfunctions that cause the mixture or the temperature of the exhaust gases to change reduce the effectiveness and life of the catalytic converter. Leaded gasoline and the over-use of certain fuel additives can shorten the life of a catalytic converter.
    A catalytic converter can also fail because of:
    • Bad exhaust valves on the engine
    • Fouled plugs causing unburned fuel to overheat the converter
    *Sometimes you can tell that a converter is clogged because you don't go any faster when you push the gas pedal. Also, there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A partially clogged converter often acts like an engine governor, limiting the actual RPMs to a fast idle. A totally clogged converter causes the engine to quit after a few minutes because of all the increased exhaust back pressure.
    The catalytic converter, like the rest of the emissions system, typically has a warranty length that exceeds the term of the warranty for the rest of a typical U.S. automobile.
    Here is a safety reminder: Do not park your car over tall grass or piles of dry leaves. Your car's perfectly running catalytic converter gets very hot -- enough to start fires! You can keep it running well by keeping the ignition system in top shape, to prevent any unburnt fuel from entering the catalytic converter.
  14. Jul 10, 2013 at 2:48 PM
    #114
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    For a cheap check:
    If you are able to, disconnect the pipe before the cat, wiring it up to allow full flow, and run it till it gets warm. Then take it out to see if your power is 'back'. I had a bad cat on a VW yeas ago that would allow me to run for 20 minutes before it would shut down the motor completely.
  15. Jul 10, 2013 at 3:29 PM
    #115
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Wrong...all you need is one of these tools. Pull the forward o2 sensor out and replace it with the BP tool. Too much pressure and you've got a clogged cat. It's that simple.
