Why is it recommended to change differential and transfer case fluid every 30k miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, May 15, 2024.
  1. May 15, 2024 at 12:36 PM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    Trying to wrap my head around this . Why is it recommended to change differential and transfer case fluid every 30k miles … are the parts this delicate that needs changing this often ? I don’t off road just normal day to day driving … what is the benefit to this besides making the dealer wealthier ? I understand components moving …but this seems like a overkill … I have run other vehicles to 100k without ever touching differential fluids …
  2. May 15, 2024 at 12:42 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Does the manual say 30K for those gear boxes?
  3. May 15, 2024 at 12:43 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Front differential service is not needed for a while if not used much.
    Transfer and rear differential can be stretched if only light 4WD use. But use it 10 miles a month offroad to keep the parts lubricated.
    Dealer can be avoided for this work and only "parts" is the cost. The main warning I have heard is to ensure the "fill" port opens before opening the "drain" port ... yeah, common sense, but at least it is stated.
    usmc2msu likes this.
  4. May 15, 2024 at 12:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    30k is the best suggestion when you don't know how the truck will be used.
    There isn't much fluid in the differentials and transfer case. Towing, stop and go, and short trips are hard on fluid.
    Condensation can introduce water into the differentials as well.
    Plus the fact there is no filtration system.
    Therefor, it's best to recommend a shorter interval when operating conditions are unknow.
    And the fact that they are fairly easy to service is also a reason.
    They are NOT however, Easy to rebuild.
    So it's best to change them more often.
    02Duck, rolled93slc, Inyo_man and 8 others like this.
  5. May 15, 2024 at 12:43 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I thought that was only suggested for severe use or whatever it's called. regular towing or whatever?
    Junkhead and MR E30 like this.
  6. May 15, 2024 at 12:45 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Lube is cheap
    Gears and transfer case internals aren’t.
  7. May 15, 2024 at 12:50 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :fistbump:
    Yep...I always heard grease and oil is cheaper than Machinery
    02Duck likes this.
  8. May 15, 2024 at 12:56 PM
    Mallcrawler20
    What gear oil do u guys recommend or should I should I pick some up at the dealer ? And Ty for the information about it .
  9. May 15, 2024 at 12:57 PM
    TnShooter
    Deogee
    STOCK
    It says check and replace if needed.
    Or to change it under "Special Operating Conditions"
    This is one of those, It will make it through warranty. Then it's the owners problem.
    Diffs and Trans cases are done "when needed" not and a set interval.
    Some guys can go 100k (bad idea), where other guys need it at 15k.
  10. May 15, 2024 at 1:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not sure which recommendations you are referring to, but Toyota recommends 30k on diffs and 60k on transfer case. Why, I don’t know. You would need to talk to many engineers, documenters, lawyers, etc. at Toyota to get a good answer. Ultimately, I don’t think it matters that much. Do what you feel and keep both feet on the wheel.
    https://www.tacomaworld.com/threads/3rd-gen-maintenance-intervals-simplified.766505/
    brigsby99 and Chew like this.
  11. May 15, 2024 at 1:02 PM
    onekickkawi
    onekickkawi Member
    I am at 40k and need to service the fluids too. I have always been a big fan of Amsoil. I will be doing F&R and Transfer this weekend.
    Still pondering doing the transmission, I talked to a few shops and they all seem to train the pan and refill. This mixes old and new fluids (not a huge fan of this method). I havent found any shops that use an evacuator and do all the fluid in one go.
  12. May 15, 2024 at 1:08 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Toyota gets you either way, 95 dollars for a liter of 75w oil for the transfer case.
    In my experience the first one or two changes are most important if you don’t tow or off-road. I had a Subaru that spec’d diffs and trans every 30k. By 90,000 miles the oil I drained out was as clean as what I was putting in.
  13. May 15, 2024 at 1:15 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    It’s a relatively straightforward service that will extend the life of your differentials and transfer case. I change mine every 30k because I frequently use my truck off-road. I’m sure you could extend those intervals if you don’t tow or off-road. Just like engine oil, those fluids will deteriorate with use.
    02Duck and 69 Jim like this.
  14. May 15, 2024 at 1:18 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Two reasons:
    To empty your wallet
    It's part of the "gotcha" clause to deny warranty work even though it had nothing at all to do with parts failure.
    My 07 has 246,000 miles on it. I had the diffs and transfer case fluid changed at 170,000 miles in 2016. The transmission still has the factory fluid in it. It's really more cost effective to never change the AT fluid. If you change it every 30,000 miles you'll spend more on servicing the transmission that it costs to have it rebuilt. And I've never seen any proof that they last any longer if you change it.
    I tow quite often. I'm not shy about taking it off road, but I don't beat the crap out of it either.
  15. May 15, 2024 at 1:29 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    If you read your manual, severe use applies to off-road use, winter driving, 4WD, towing, hauling. Essentially everything but driving to and from the grocery store in sunny Florida will qualify as severe use.
    BMH and DRAWN like this.
  16. May 15, 2024 at 1:31 PM
    DRAWN
    This is why I don’t buy used vehicles. Changing your diff and transfer case fluid at 170k is not recommended. I wouldn’t buy your truck used if you sold it, that’s clear indication it hasn’t been taken care of. If anything it’s a testament to Toyota’s quality that they can put up with that an abuse and not fail. That fluid breaks down with heat and mechanical wear, eventually is stops lubricating as effectively causing damage over time.
    BumfukKansas, Plus20DB, 661 and 4 others like this.
  17. May 15, 2024 at 1:41 PM
    JoshC
    JoshC Well-Known Member
    2023 TRD Off-Road M/T Celestial Silver
    1999 SC 2.4L 2WD 5m/t (RIP)
    I do all the gear oil changes at the same time: front and rear diff, transfer case, and manual trani. I aim for 30k or 2 years, whichever comes first. Like others have said (including Car Care Nut) oil is cheap, new trani diff whatever, is not.
    Full disclosure: I'm also one of those OCD people who change my engine oil at 4k miles.
    OZ TRD likes this.
  18. May 15, 2024 at 1:44 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    It’s not a bad idea to do all of them at the same time, because then you forget which ones you did and didn’t do.
    Especially if you have multiple vehicles.
  19. May 15, 2024 at 1:51 PM
    JoshC
    Your post about buying used vehicles reminded me of a funny story that happened to me.
    My girlfriend (now wife) bought a used 99 Taco in 2004 with 65K miles and a 5m/t from a used car lot. It was a good deal and was a great little truck for us back then. Several months after we bought it, we decided to go on a roadtrip from SoCal to Utah. I checked all the fluids before the trip. I went to check the trani fluid but since it was manual never happened to have the right wrench to crack it open and check the fluid level. "It's fine. If not I think I'd know by now" I thought. So we made it to Vegas and we're exiting the freeway and the shifter wouldn't come out of gear. On top of this, the truck was also making some high pitched whining noises about now. I was able to get it out of gear and pulled into a Quicky Lube place that just happened to be there. They pulled the drain plug on the trani and it was bone dry. They also checked the rear diff and there was just enough oil in there that prevented us from frying that. Long story short (too late!) we drove what we started calling our UFO the rest of the way to Utah.
    I felt really bad that my lackadaisical attitude killed that trani. Our parents gave us the money to get a rebuilt trani but it never shifted the same after that. Stock (good) vs rebuilt trani (just ok).
    Junkhead, BMH, SGJarrod and 1 other person like this.
  20. May 15, 2024 at 1:56 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    i thought the same thing until i did the front diff at 25k, i've never seen an oil that dirty or that much shavings.
    69 Jim, JoshC and DRAWN like this.
