Why does Diff. Locker button not always flash?
Discussion in 'Technical Chat' started by TacoNumber6, Jan 11, 2016.
  1. Jan 11, 2016 at 11:35 AM
    TacoNumber6
    TacoNumber6 [OP] 6 TIMES A CHARM
    I posted a similar thread earlier, and i was wondering. I got into my truck on lunch (it was sitting for 6 hours) and the differential locker button flashed but stopped quickly, then i tried it a few mins after driving, and it didnt even flash, just stayed on right away. This morning when it was really cold it flashed a lot longer but it was really cold, Is this due to something not getting warmed up or should i take it to the dealer?
  2. Jan 11, 2016 at 11:42 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    The splines just need to line up, sometimes they are lined up so it locks right away, sometime one rear wheel needs to rotate a bit to line up both sides. Also, you do know it will only lock in 4Low right? And you are not doing this on asphalt are you?
  3. Jan 11, 2016 at 11:45 AM
    Bannerman
    Johnson
    Charlotte, NC
  4. Jan 11, 2016 at 11:48 AM
    TacoNumber6
    It is on asphalt, i only have a "4D" option. This morning i accidently turned it on and drove on regular roads for about 3-4 miles and I'm afraid i damaged something
  5. Jan 11, 2016 at 11:50 AM
    TacoNumber6
    i was concerned because the owner's manual says not to go faster than 5mph
  6. Jan 11, 2016 at 11:50 AM
    Bannerman
    Johnson
    Charlotte, NC
    Oh, Are you in a PreRunner then?
  7. Jan 11, 2016 at 11:52 AM
    TacoNumber6
    yes, preRunner
  8. Jan 11, 2016 at 11:54 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Stopped flashing and remained on or stopped flashing and went out?
    Flashing means you pushed the button but it is not (yet) locked. This should be performed while stopped and then move slowly (under 5 mph). If still blinking, turn the steering wheel to ONE direction (not back and forth) and creep ahead to lock the diff. You didn't say if you are 2wd or 4wd... The 4wd only locks while in Low Range (unless you do a locker anytime mod).
    There should be this sticker on the driver's door:
  9. Jan 11, 2016 at 11:54 AM
    Bannerman
    Johnson
    Charlotte, NC
    Yeah you don't want to run 4x4 on the asphalt but you don't have to worry about that. Don't use your lock on Asphalt either though. I don't think you probably damaged anything driving 3-4 miles but you will wear your tires out quickly in turns as the inner tire will be forced to turn at the same rate as the outer tire.
  10. Jan 11, 2016 at 12:01 PM
    Bannerman
    Johnson
    Charlotte, NC
  11. Jan 11, 2016 at 12:04 PM
    TacoNumber6
    When i went to lunch and cranked it up, and then pushed the button, it didnt flash, it just came on and stayed on. I was in park the whole time
  12. Jan 11, 2016 at 12:07 PM
    Bannerman
    Johnson
    Charlotte, NC
    Your good to go man. Go Heels!
  13. Jan 11, 2016 at 12:08 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    if it's flashing, that means you've requested the diff to lock but it hasn't completed the action yet. if it goes solid, the diff is locked. you want it to flash as little as possible and go solid quickly. that means the internal teeth have lined up correctly quickly and your diff is locked. like others have said, if it's flashing, rolling forward or backward while slightly turning to one side or the other will usually resolve a flashing diff lock light.
    you can go faster than 5 mph with the differential locked, but it is recommended to be stopped or going < 5mph in order to engage the diff locker.
  14. Jan 11, 2016 at 12:09 PM
    TacoNumber6
    my biggest concern was whether or not i f*cked something up or not
  15. Jan 14, 2016 at 4:21 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Is the grey wire mod the one that creates the option of having the rear locker work in 4Hi?
  16. Jan 14, 2016 at 5:20 PM
    David K
  17. Jan 14, 2016 at 6:06 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Oh ok. I'm a 1st gen
  18. Jan 14, 2016 at 8:00 PM
    David K
    ... and I am on my second 2nd Gen now. I had a 1st Gen first! Never needed the Grey Wire mod, just go into 4WD and keep on truckin'
    Anyway, hope you can find the Grey Wire Mod for 1st Gen Tacos. Use Search!
    Sicyota04[QUOTED] likes this.
  19. Jan 15, 2016 at 11:01 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    This is what I was talking about. You could use your E locker even in 2 hi.
  20. Jan 15, 2016 at 11:02 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
