Why do I keep blowing pinion seals?
Discussion in '1st Gen. Tacomas (1995-2004)' started by FailRated, May 26, 2012.
  1. May 26, 2012 at 11:16 AM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    5100's w/ Eibachs, Front sway bar in trash mod, Diff drop, 265/75-16 Duratracs or 33x10.50 KM2's on 15x8 wheelers steels, ARB front bumper, Warn VR8000 winch, Trailgear sliders, Allpro rear bumper, Sky Offroad E-Locker guard, Sky Offroad weld on differential guard, Savage skid plates w/ Budbuilt cross member, e-locker rear, ARB air locker front, 4.56 gears, bought it from my mom who bought it new :-D
    Since I put 4.56 gears in my truck a month ago I have gone through two rear pinion seals. The first one was the dust shield on the new pinion yoke contacting the seal. So I pulled the 3rd member and took it back to my diff guy. He took it back apart checked everything, removed the dust sheild and now a week later with no dust sheild on the yoke, I'm leaking from the pinion seal again.:pout: WTF do I do now?
  2. May 26, 2012 at 11:22 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Breather plugged?
    Lube overfilled?
    Pinion shaft has a crack/chip/scratch?
  3. May 26, 2012 at 11:25 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pinion bearings set up correctly?
  4. May 26, 2012 at 11:30 AM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    How would I check the breather?
    Oil level is correct as far as I know. It took a little over 2 qts before it started pouring out the fill hole.
    I'll inspect the pinion where it contacts the seal the best I can.
  5. May 26, 2012 at 11:32 AM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    As far as I can tell. There is no movement when I grab/shake the drive shaft by the pinion flange.
  6. May 26, 2012 at 11:40 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Spin the breather by hand to see if its free. If it's clogged the pressure will force the oil out when it heats up. Then again, it would've leaked before the gear change, and would probably leak into the rear brakes too.
    There could be a groove in the tailshaft where the seal is. Could be a bad seal too. There's many things to guess at, but an inspection is in order.
  7. May 26, 2012 at 11:41 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    The breather sits on top of the housing, little silver cap, make sure it moves around loose. You could always re-route it higher with a filter on top if you like to drive through water.
    Just wondering if they set the right pre-load on the bearings.
  8. May 26, 2012 at 11:52 AM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    I know where the breather is. I'll spin it to make sure it's free. As far as correct bearing preload, I have to trust my diff guy. He is reputable, very straight forward and I know him personally(not just a random mechanic I found in the yellow pages)
    This is just getting frustrating. The 3rd member is to freaking heavy to keep pulling it out.:p Although I've done it enough times recently that it only takes me an hour to remove and an hour to install.
  9. May 26, 2012 at 11:54 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yet his "solution" to your problem was to remove the dust cover that is on every other diff on the road and not causing problems?
  10. May 26, 2012 at 12:09 PM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    The new yoke is an aftermarket unit and he did show me where it was contacting the seal. I see your point though. Why would the dust sheild contact the seal?
  11. Jul 7, 2012 at 8:55 AM
    allian04
    allian04 Well-Known Member
    Folly beach, sc
    03 trd tacoma 4x4
    arb bull bar, B.A.M.F. rock sliders w/kickout, 265/75r16 Wild peak, 3" ome 881 coils, dakars 5150s, deck plate, snugtop, viair on-board air,Simpson 3 rtt
    did you ever figure out the issue? i just installed 4.56s and mine is leaking also, i just cleaned my breather out it was rusted shut yesterday so I'm gonna see what happens today
  12. Jul 9, 2012 at 6:56 PM
    FailRated
    FailRated [OP] RTO
    Evan
    Maryland
    03 Double Cab TRD
    Nope. Still barely leaking. I check the fluid and it's still full so I'll deal with it when work slows down.
  13. Jul 10, 2012 at 2:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    Am I the only one who read the title and thought to tell him to leave those seals alone....lmao
