Why do Americans still use slotted screws ?
Discussion in 'Garage / Workshop' started by OZ-T, Feb 17, 2012.
  1. Mar 3, 2023 at 12:57 PM
    #841
    OZ-T
    OZ-T [OP] You chose ... poorly
    Peter North
    British Columbia
    They are torx drive but their advantage is the R4 and RSS screws are structural
    T10-T40
    HondaGM likes this.
  2. Mar 3, 2023 at 1:32 PM
    #842
    OZ-T
    Peter North
    British Columbia
    I'll keep that in mind next time I'm running a 3/8" x 16" GRK RSS screw into old growth douglas fir without predrilling a hole
    HondaGM and Sig45 like this.
  3. Mar 4, 2023 at 4:48 AM
    #843
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    The best sheet metal screws are Robertson. Wood working, cabinet building use Robertson. They work the best in these situations. Giant lag bolts or other bridge building, skyscraper building fasteners are probably best as regular hex type bolts or rivets! :rofl: Torx bits strip, that is why they put a dozen or more of them in the bit kits. One Robertson will outlast many hundreds of Torx. The real Robertson will not strip even at an angle where Torx isn't even a consideration. In the states you guys get some lame squarish chinese knockoff of a Robertson. Robertson aren't used/sold there so you really can't form an opinion. :crapstorm:
    ralfnjan likes this.
  4. Jul 5, 2023 at 6:54 PM
    #844
    soggyBottom
    soggyBottom Well-Known Member
    Basically Torx wins in long term durability. This is because of the wider contact patch that torx has and that robertson is tapered causing it to cam out once worn. You can read more here: https://pedriana.wordpress.com/2021/02/03/robertson-vs-torx-screw-drives-fight/
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    Now that the Torx patent has ended, they give us Torx-Plus. I've never used them but All the complaints I hear about torx are seem to have been fixed.
    tinker_troy likes this.
  5. Jul 5, 2023 at 6:57 PM
    #845
    soggyBottom
    they put low quality bits in the box. At best, they are sintered steel. I've bought some screws that came with aluminum bits. The sintered ones never wear out on me, they just chip and crack.
  6. Jul 5, 2023 at 7:02 PM
    #846
    OZ-T
    Peter North
    British Columbia
    GRK R4 and GRK RSS FTW
    98tacoma27 likes this.
  7. Jul 5, 2023 at 7:19 PM
    #847
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  8. Jul 6, 2023 at 7:15 AM
    #848
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I thought about this thread when I was picking up hardware for a cabinet build. The specs called for M4x16 panhead bolts, because fuck our freedom inducing 8-32 x 5/8's. That would be too easy.
    So off to Ace I go, and I found what I needed in a nice looking hex head. $0.85 per. In the next drawer was the same bolt in Phillips, at $0.12 per.
    So when I bought a box of 100, guess which box I bought? Ol' ugly x-slots. :bananadead:
    davidstacoma and HondaGM like this.
  9. Jul 6, 2023 at 9:07 AM
    #849
    soggyBottom
    One of my guilty pleasure is having the right fasteners. I buy them off McMaster for almost every size of 316 socket head for m3, m4, m5, and m6
    Rock Lobster[QUOTED] and HondaGM like this.
  10. Jul 6, 2023 at 9:15 AM
    #850
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Slotted screws are good for historical restoration or scrape metal.
    HondaGM and chris4x4 like this.
  11. Jul 6, 2023 at 10:07 AM
    #851
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This thread is still a thing?
  12. Jul 6, 2023 at 10:11 AM
    #852
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Screwing is very popular..
  13. Jul 6, 2023 at 10:17 AM
    #853
    scocar
    scocar hypotenoper
    Like monkeys fucking a football.
  14. Jul 6, 2023 at 10:22 AM
    #854
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Post of the Day right there...
  15. Jul 6, 2023 at 10:22 AM
    #855
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The slotted screw was invented in the 1st century and used for literally centuries until a Canadian guy tried to use one, and, while befuddled by it having no concept of its designed usage, he cut his hand. He made a square drive screw, and as he was very full of himself, he named it after himself. Then sold Henry Ford on them. Shortly after, a guy realized they are weak sauce, and he made a stronger screw, and called it Phillip, named after the great Lord Phillip, Husband of QE 2. OZ-T, a young lad in his 20's at the time, was bothered, and felt his fellow Canadian was "screwed", began his journey to slander ALL screws except the beloved square drive.
    Some of these facts may or may not have been accurately researched before posting.
  16. Jul 6, 2023 at 10:27 AM
    #856
    scocar
    scocar hypotenoper
  17. Jul 7, 2023 at 4:10 AM
    #857
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I just checked Snopes, also confirmed true.
    -J
    chris4x4[QUOTED] likes this.
  18. Jul 7, 2023 at 4:19 AM
    #858
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Better be careful where you go posting that on the internet.. All that in 316? From McMaster Carr?? Thats worth its weight in gold to us salt belt folks :D
  19. Dec 18, 2023 at 11:08 AM
    #859
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Let’s keep it rolling!
    OP is definitely not a tuner!
    Holley 390 was me fave 4 stroke carb, and now a days it’s Husqvarna’s WG for the 3120, by far me fave 2 stroke carb to tune.
    I always carry a small red slotted one meself. Always looking to help a brother in need of a tune. No 2 stroke smoke unless you’re buzzing a competition saw or burning Alky!
  20. Dec 19, 2023 at 12:08 PM
    #860
    OZ-T
    Peter North
    British Columbia
    Old thread is old
