Why both Acc and On?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jul 1, 2021.
  1. Jul 1, 2021 at 9:18 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    Why not just have On? What does Acc accomplish that On doesn't, or can't be wired to accomplish?
  2. Jul 1, 2021 at 10:33 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    It allows you to have your radio and cigarette lighter outlet powered on without having the engine running or having all the engine sensors and ignition coils and engine computer powered without the engine running. They could have just had the radio powered all the time even with the key out, but then people might leave the radio on by accident and drain the battery.
    crackedmirror[OP] and turbodb like this.
  3. Jul 2, 2021 at 12:19 AM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    A simple way to think about it is ACC powers the body harness, while ON powers the engine harness and body harness.
    ACC is super convenient for diagnostic where you need ignition power but don't want the fuel pump and engine stuff going the whole time. As well as its intended purpose, of course, which is to run ACCessories without the need for starting the engine, but still requiring affirmative action to pull power from the battery, which can leave you stranded if you aren't careful.
    crackedmirror[OP] likes this.
  4. Jul 2, 2021 at 3:29 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    Legacy thing from when vehicles had points in a distributor, if the points were closed and you turned the key to on, you had power through the points and they would burn up.
    I don’t think new vehicles have an acc position, just on. My VW is that way with push button start.
  5. Jul 2, 2021 at 1:41 PM
    Strostkovy
    Alex
    White 98 Tacoma
    I know that at least new Toyotas and Jeeps have ACC. You just push the start button without pressing the brake and it goes to ACC. To turn on the ignition without starting the engine you press and hold the button without applying the brakes.
  6. Jul 2, 2021 at 1:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This has to be a troll thread...
    Wyoming09 likes this.
  7. Jul 2, 2021 at 1:45 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    it would be nice if all the OP`s threads where in one instead of 50
    Bishop84 and Kwikvette[QUOTED] like this.
  8. Jul 2, 2021 at 1:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I thought his username looked familiar.
    Some questions I understand, and other times I think "is this the OPs first time even sitting in the driver's seat of a vehicle?"
    Rastopher and Wyoming09[QUOTED] like this.
  9. Jul 2, 2021 at 1:57 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    OP took seats out to reduce weight.
    :rofl::rofl::rofl:
    Wyoming09 and Kwikvette[QUOTED] like this.
  10. Jul 2, 2021 at 3:10 PM
    crackedmirror
    i wasn't given an explanation of why vehicles have both acc and on when i started driving 15 years ago. wanting to simplify the wiring harness on my new tacoma has me asking these questions. standby for lots more.
  11. Jul 2, 2021 at 3:20 PM
    NSDON
    Don
    NS
    I wouldn’t worry about the acc issue, it’s just the way it worked when new. Doing away with that acc option isn’t worth bothering with.
    My 63 has no seatbelts, no airbags, no abs, no fuel injection, no sensors, no cel, no headrests, no collapsible steering column, no locking steering column, drum brakes all around, single master cylinder. It is what it is, as is your Tacoma.
  12. Jul 2, 2021 at 3:40 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Good opportunity to learn how to read a wiring diagram.
  13. Jul 2, 2021 at 3:47 PM
    604 Well-Known Member
    2002 Lincoln Navigator V8
    ..... I stopped scrolling as soon as I read "how to use this manual" seems a bit intense
  14. Jul 2, 2021 at 3:50 PM
    0xDEADBEEF
    Unfortunate; manuals are the best place to get answers.
    Unless you want to rely on internet randos :laughing:
    PhenixFord, 604[QUOTED] and NSDON like this.
  15. Jul 2, 2021 at 4:08 PM
    your right.
    so far majority of the folks on here with input seem competent, at least from what they type. I know at some point though gotta hit them books. regardless your right, if you want something done you better be willing to put some effort in
    0xDEADBEEF[QUOTED] and NSDON like this.
  16. Jul 2, 2021 at 4:11 PM
    NSDON
    Don
    NS
    If you don’t like manuals, you can get all kinds of advice on line, some of it good?:fingerscrossed:
  17. Jul 2, 2021 at 4:12 PM
    0xDEADBEEF
    For me its about 2 things - I may not always have access to a place like this and I hate relying on other peoples generosity to go dig through a book to answer some obscure question. If its opinions and off-the-top-of the head knowledge thats one thing, but I'm not going to expect someone to dig through a book for an hour to figure something out for me.
    DrZ and Wyoming09 like this.
  18. Jul 2, 2021 at 4:19 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Toyota EWD`s are some of the easiest to use I have every used.
    You want to see difficult look at schematics for a manufacturing line if your not used to them.
    0xDEADBEEF likes this.
  19. Jul 2, 2021 at 8:25 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Every single time with this guy
