why are window deflectors so expensive?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tarby04, Jul 13, 2019.
  1. Jul 13, 2019 at 10:16 PM
    tarby04
    tarby04 [OP] so much to do, so little time
    I just can't figure out why window deflectors so expensive.
    Looks like WeatherTech's the top shelf item and AutoVentShade (AVS) is #2.
    And this video really makes the AVS's look like #2 too - window won't even close after they're installed.
    https://www.youtube.com/watch?v=YGfq7QwNGg0
    A set for 1st gen double cab Tacomas are like $100 for the WeatherTechs and $60 for the AVS's.
    And both those prices seem so high for 4 strips of plastic with some adhesive included. I mean, you can get a new microwave oven for $60.
    Anyone 3-D printing or have some other hack for DIY window deflectors?
  2. Jul 13, 2019 at 10:30 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    If you get the ones that 3m tape to the paint they are much cheaper
  3. Jul 13, 2019 at 10:36 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I just put the AVS units on my Access Cab. $33 or so on Amazon. Work perfectly fine and the windows do completely close. Follow the instructions and leave the windows up overnight (at least) to fully seat the shades, done.
    After skimming though the vid, it appears that reading and following instructions are not required to make a comparison video. YMMV...:rolleyes:
  4. Jul 13, 2019 at 10:42 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    I don't have a 1st, but if you check Amazon under the Used and sold by Amazon Warehouse section, you can get them balls cheap.
    I paid $22 for a new set of AVS vent visors which were marked as used. Still had the same return policy as new from Amazon. I got them and they were just missing a small scotch brite pad and just taken out of the cardboard vacuum seal wrapping.
  5. Jul 14, 2019 at 4:50 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I had problems with my weathertech, different truck, but still a problem, they have good customer service but the engineering behind the expensive product didn't work for me. I'd avoid them, I am from now on.
  6. Jul 14, 2019 at 5:00 AM
    spentshells
    spentshells Well-Known Member
    Rob
    PA
    TRD off road
    I have avs for a dcor $40 bucks new no problems.
