Why are hoses and pipes and clamps not covered under warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PanzerDivisionBlack, Jun 3, 2023.
  1. Jun 3, 2023 at 3:29 PM
    PanzerDivisionBlack
    PanzerDivisionBlack [OP] Well-Known Member
    I have a 2022 SR with 10k miles on it, I have a coolant leak where I am losing a quarter inch of coolant every 2-3 days, cannot find the leak ANYWHERE, no coolant on the ground, none on my skidplate, cant see on any pipes or hoses, I have an appointment with the dealer on monday, they prefaced they were about to say after i told them about the leak that "hoses, clamps and pipes are not covered under any of the warranty even the initial 36k" well why not? I am being quoted $1200 if it is the hose that usually leaks on 3rd gens thats behind the engine(coolant bypass i think), i called a couple other shops and got quotes for $800-900. I gave you almost $40k a year ago and now I need to drop another $1200 on something that is not my fault? Is there anyway to fight this or any other alternatives? It blows my mind thats not covered under a bumper to bumper warranty.
  2. Jun 3, 2023 at 3:34 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Go to a different dealer. Most likely its the coolant pipe/bypass behind the engine.
  3. Jun 3, 2023 at 3:36 PM
    PanzerDivisionBlack
    Yeah thats what they said on the phone its most likely, so why would that not be covered under warranty? also i am having a hard time locating it when under the truck to see if there is coolant there. any pics for reference so i can locate it?
  4. Jun 3, 2023 at 3:37 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Liar's.
    Call Toyota USA, be polite, mention the dealer and their refusal to cover the warranty that is still in effect.
    Tell them it's losing a significant amount of coolant and you're worried that the engine may overheat.
  5. Jun 3, 2023 at 3:37 PM
    Anchovy
    TRD Ferguson
    There have been a few threads. You won't find any puddles, the coolant usually evaporates and leaves pink crystals on the pipe. Its a difficult spot to see, might need a mirror
  6. Jun 3, 2023 at 3:38 PM
    PanzerDivisionBlack
    says it right here on toyotas website...
    Normal Wear and Tear Is Not Included
    Components of your car that have to be repaired or replaced because they are worn out from use are not covered under the warranty. This includes items like brake pads, brake rotors, batteries, windshield wiper blades, hoses, air filters, oil filters, lightbulbs, and fluids. Additionally, the warranty does not cover any repairs that are the result of a collision, vandalism, or neglect. As such, it is important to have your car maintained by the dealership according to manufacturer recommendations.
  7. Jun 3, 2023 at 3:49 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    It’s not a “hose” nor is it a typical wear part that wears with use. It should be covered and has been covered quite a few times by dealers when in warranty period.
  8. Jun 3, 2023 at 3:49 PM
    PanzerDivisionBlack
    Okay good to hear that i will fight it then appreciate you
    BLtheP[QUOTED] likes this.
  9. Jun 3, 2023 at 3:55 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    try a new radiator cap . that my solve your problem , an inexpensive fix
  10. Jun 3, 2023 at 4:02 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I think it's arguable that while yes one expects to replace hoses and clamps in time, it's not within a year and 10K.
    Even if this was considered a hose..
  11. Jun 3, 2023 at 4:03 PM
    Anchovy
    TRD Ferguson
    Yeah, its an actual pipe. Not a hose.
  12. Jun 3, 2023 at 4:04 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a generalization. There's a real warranty manual that clarifies this.
    Every item on the car is covered under warranty.
    Don't let the internet freak you out and talk to a human at a dealer about this.
    The coolant crossover is covered for 5yr 60,000 miles for future reference.
    shady 74, Mikeh80, Soonr1 and 4 others like this.
  13. Jun 3, 2023 at 4:07 PM
    PanzerDivisionBlack
    Bad ass thank you so much
  14. Jun 3, 2023 at 4:19 PM
    fxntime
    It's not ''worn from use'' it's a known issue and I believe there is even a missive on it. Belts I understand, a hose doesn't ''wear out'' in a year and neither do clamps unless they are defective.
  15. Jun 3, 2023 at 5:19 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’m not sure exactly what info you gave them, I’d look for another dealer. They don’t sound too helpful, between knowing it’s not covered and assuming it’s the pipe on the back of the engine.
  16. Jun 3, 2023 at 6:13 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There is a difference between a hose and a pipe.
  17. Jun 4, 2023 at 1:28 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    A hose is soft and flexible while a pipe is metal and not flexible.
    FRE1809 likes this.
  18. Jun 4, 2023 at 4:58 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    No drips on ground so did you check your oil "just in case" to make sure it isn't frothy white?
  19. Jun 4, 2023 at 5:06 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    That sucks....
  20. Jun 4, 2023 at 5:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    while a pipe is metal, plastic or composite and not flexible
    FTFY
