Why are 7442NA bulbs so hard to find?
Discussion in 'Lighting' started by Tullie D, Apr 19, 2019.
  1. Apr 19, 2019 at 12:16 PM
    Tullie D
    Tullie D [OP] Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    My SR5 uses 7442NA bulbs for the DRL & Turn & Parking lights. (One dual filament bulb per side)
    I like to keep spare bulbs on hand, so I've looked around, and can not find 7442NA bulbs. There's plenty of LED replacements, but that's not what I'm looking for.
    The 7442NA is an Amber 28W/8W dual filament bulb. I've found cross references to lower wattage bulbs, like 7440, 7443, and 7444, but no 7442NA. Does anyone know what's up with this?
  2. Apr 25, 2019 at 5:10 AM
    Tullie D
    Tullie
    Wilson, NC
    The owner's manual says my truck uses 7442NA bulbs. What's actually in the truck are 7442NALL. The LL is supposed to mean long life. (I knew that)
    I finally found some on Ebay, listed like this:
    Toshiba Electrical Turn Signal Lamp Bulb 7442NALL
    They were $8 each, including shipping, which is less than the $12 each ones that I found elsewhere. And they are indeed dark amber 28w/8w bulbs, unlike the lighter colored 7444NA 21w/5w bulbs that my O'reilly's called "same thing". Would they work? Sure. But they are NOT the same thing.
  3. Apr 25, 2019 at 9:10 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    If shopping over the counter Pep Boys, Auto Zone, etc. You will look for 7443A bulbs.
  4. Apr 25, 2019 at 9:33 AM
    Tullie D
    Tullie
    Wilson, NC
    7443A is not a 28w/8w bulb either. It is also a lower wattage 21w/5w bulb.
  5. Apr 25, 2019 at 9:38 AM
    Siblue
    So Cal
    25 Tundra TRD pro
    You're right, the dealer would be the best bet. I'm running 7443A on my Off-Road because didn't want to pay dealer prices.
  6. Apr 25, 2019 at 9:45 AM
    Siblue
    So Cal
    25 Tundra TRD pro
    P/N for OEM is 90981-15030
    PoweredBySoy likes this.
  7. Apr 25, 2019 at 9:53 AM
    Tullie D
    Tullie
    Wilson, NC
    Thanks
  8. Apr 28, 2019 at 6:32 AM
    Pat3002t
    Pat3002t Well-Known Member
    3rd gen SR 2.7 5MT
    Any Good quality Led replacement for the 7442 na LL? Long life, dual function and amber but brighter?
  9. Apr 28, 2019 at 6:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you go LED you risk hyper flashing.
  10. May 18, 2019 at 8:10 AM
    KY.Creeker
    KY.Creeker Member
    2017 Tacoma SR 4x4 V6
    Putco makes a 7443 resistor for LED conversion. 32 bucks + s&h. Im gonna give it a shot on my SR
  11. Jun 10, 2020 at 7:16 PM
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    Then you remove the blinker relay, crack it open, and replace the flat bar with the appropriate diode and it stops doing that.
  12. Jun 10, 2020 at 7:23 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Any more info on this? Wiring diagram, pictures, explanation of changes, etc?
  13. Jun 10, 2020 at 9:03 PM
    Tullie D
    Tullie
    Wilson, NC
    The only thing that seems to work well for a gen 3 SR or SR5 is to use 7442NALL bulbs.
    I'm perfectly OK with that. I have spares on hand and now I know where to get more. :)
  14. Jun 11, 2020 at 3:49 AM
    willconltd
    Orlando, Florida
    I've done it on several different cars, I have yet to try on the Taco. There is a bias metal piece in the blinker relay that makes the blinking happen when the voltage doesn't match up. Its old tech and easy to bypass. I'm going to try it next week if the LEDs fast flash.
  15. Jun 11, 2020 at 7:58 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Cool. If you don't mind, could you snap a pic if you end up digging into the flasher module?
    Tullie D[OP] likes this.
  16. Jun 11, 2020 at 8:06 AM
    Tullie D
    Tullie
    Wilson, NC
    That'll be kinda hard to do on a 3rd gen Tacoma.
    :popcorn::popcorn::popcorn:
    There isn't a flasher module.
  17. Jun 15, 2020 at 11:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    To clarify, 7442A and 7442NA are the same bulb, provide the exact same function and are interchangeable. Every auto-parts store should carry 7442A. The difference between 7442A and 7442NA is 7442A is an 'amber coated bulb', 7442NA is a 'natural amber' bulb, in otherwords the single A designation means the bulb uses an amber coating on the glass, the NA means the bulb uses amber glass. An amber coating will eventually peal off, amber glass (NA) will not flake or peal and amber glass will be more of a deeper amber color than a coated bulb. OEM uses NA as it is a higher quality product. The LL designation after that just stands for Long Life.
    monoman and Tullie D[OP] like this.
  18. Feb 2, 2021 at 3:19 PM
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    I can confirm 7443’s will work just fine. After removing my amber oem bulb (and breaking it at the same time) I went to the auto parts store to only see 7443 bulbs. I wanted clear/white bulbs. That’s why I removed the amber bulbs. So I’m googling and run across this thread while standing in the bulb section at autozone and end up purchasing the 7443 bulbs. They work fine. Now I have white daytime running lights and white front turn signals like I wanted
    KingsofPop likes this.
  19. Sep 3, 2022 at 8:22 PM
    My4thTacoma
    St Petersburg, FL
    and now ive changed them back to amber because white turn signals look terrible IMO
  20. Sep 3, 2022 at 8:24 PM
    My4thTacoma
    St Petersburg, FL
    i put amber LEDs in mine and there is no hyper flash. no resistors needed
