whoop whoop noise going down the road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Mar 17, 2010.
  1. Mar 17, 2010 at 2:12 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Hey guys --
    I have an '07 Tacoma, 38k miles on it. Bigger tires. While driving, I here a whoop whoop noise that speeds up the faster I go. I thought it was my tires but apparently it's coming from the right side. One friend said it could be the hub going out. Is this accurate of a hub failing, and, should that be under warranty at 38k miles?
  2. Mar 17, 2010 at 2:17 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    that would be the police pulling you over!
    ThunderOne likes this.
  3. Mar 17, 2010 at 2:47 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    Is the noise constant or Does it come and go every min or so?
  4. Mar 17, 2010 at 3:19 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    das da sound of da policeeee
  5. Mar 17, 2010 at 3:19 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    or bill cosby??
  6. Mar 17, 2010 at 3:23 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Does it go away after you've been driving for awhile? My first thought is that the tires could be developing flat spots while parked, and those would go away after 10-20 minutes of driving when the tires warm up.
    Figure I'd start with the easy/free stuff first and then start considering possible doom and gloom. :)
    tacoshin likes this.
  7. Mar 17, 2010 at 3:27 PM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    If it speeds up as you speed up, check for rocks or something stuck in your tire. Also check the inside of your rims for mud.
  8. Mar 17, 2010 at 3:32 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
  9. Mar 17, 2010 at 3:41 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
  10. Mar 17, 2010 at 3:49 PM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Thats awsome. I want the whistle!!
  11. Mar 18, 2010 at 4:18 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
  12. Mar 18, 2010 at 5:36 AM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    I had the same sound but in the rear of my truck.... was the wheel bearing
    my front ones are about to go as well.
  13. Mar 18, 2010 at 5:56 AM
    n2advnture
    n2advnture Well-Known Member
    Mark
    New Market, MD
    2007 Double Cab 4x4 TRD Sport Longbed
    Front skid plate color matched to wheels, Weather Tech floor mats, Window visors, Bug deflector, Exhaust tip, Bed mat, EZ down tail gate, Redline hood struts, Cover Wet Okole custom seat covers w/ heaters, FJ Anthracite Special Edition Wheels, 265/75/R16 BFG All-Terrain KOs, Pioneer Avic Z110BT, Back up cam in Pop N Lock, XTang Solid Fold tonneau, Escort Xi45 hardwired radar detector, Scan Gauge II
    i think mine does a similar sound but it's more think a thump, thought it was limited to the front right but have also heard it from the front left
    happens several times during my 1 hour drive to work at highway speeds
  14. Mar 18, 2010 at 6:01 AM
    alpineski26
    alpineski26 Active Member
    Boston
    05 SR5 TRD
    Ill save you the trouble. Its the wheel bearings. Whats causing the noise is the wheel bearing seal broke, letting in some sand or whatever. They are now trapped and rubbing causing the bearing itself to shudder and breakdown.
    From the time you hear the noise, you have a several thousand miles to not worry. Then another few thousand to use the radio volume fix. Then get it fixed.
  15. Mar 18, 2010 at 8:43 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Is this a wear and tear item or a wtf warranty item?
  16. Mar 18, 2010 at 4:23 PM
    snorola
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    Mine was out of warranty, cost $1200 at Toyota Canada for just one rear to be done :mad: thats why I didn't get my fronts done even thought they recommended them.
    If your truck is still under power train warranty you should be fine.
  17. Mar 18, 2010 at 4:29 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    rape!!!!!!!!!!!!! Rape!!!!!!!!!!!!!!!!!!!
  18. Mar 18, 2010 at 5:04 PM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    sounds like a wheel bearing... i had both of mine go out i found the best way to tell if the bearings are bad is if you jack up the truck and shake the wheel vertically there shouldnt be any play in it... when mine when completely bad it messed up the abs sensor and i lost my brakes completely... i recommend fixing it asap... the dealer i went to fixed it under warranty i had probably 45000 miles on it and i have a 6 inch lift with 35s... its all about that powertrain warranty
  19. Mar 18, 2010 at 5:06 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    thats exactly what i thought of when i saw the thread title
  20. May 19, 2010 at 10:24 PM
    ywen
    ywen Well-Known Member
    does the whoop noise go away when you engage 4WD?
