Who uses their tacoma for landscaping? Photos?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTacoma2013, May 2, 2013.
  1. May 2, 2013 at 5:44 PM
    VTacoma2013
    VTacoma2013 [OP] Member
    Kevin
    Rutland, Vermont
    2013 Silver Streak Mica TRD Off-Road
    Weathertech Floor Liners
    I plan on using the new truck to pull a 6x12 enclosed trailer with a zero turn and push mowers. Who on here uses their Tacoma for Landscaping/Handyman work? Do you have photos of your truck and equipment?
  2. May 2, 2013 at 6:25 PM
    calebm12
    calebm12 Well-Known Member
    MD
    2011 trd tx
    Weathertech, hand turned wood shift knob, rear view mirror mod, grillecraft MX, hella 500s
    Does pulling bushes count as using it for landscaping :) te9eryby_690f00f0c00f5b2dc5d7112d2d76c5847b87e1c0.jpg
  3. May 2, 2013 at 6:27 PM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Put a light on that flag.
  4. May 2, 2013 at 6:38 PM
    calebm12
    MD
    2011 trd tx
    Got one. Redoing all the beds then will be shining bright
  5. May 2, 2013 at 7:51 PM
    Harry Hood
    Harry Hood Active Member
    Montrose Colorado
    nothing yet
    I will take some pictures tomorrow. I own a landscaping company in colorado and use my '13 double cab as a work / play truck. I I usually pull my 12x6 with 2 walker riders. Pulls it just fine. Was pulling my trailer with a dura max but was a bit over kill so that truck is used for pulling our 14' dump trailer
  6. May 2, 2013 at 7:58 PM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    The 4x2 base Tacomas seem really popular with landscaping and pest control companies in the southwest.
  7. May 2, 2013 at 8:13 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Lots of gardeners in my area have tacomas.
  8. May 2, 2013 at 8:19 PM
    vtdog
    vtdog Well-Known Member
    NH
    I put a full yard of compost or soil in the bed every spring and have loaded it with 1200 pounds of lime in 50lb bags. All trips without any problems, but I have had the leaf spring TSB done
  9. May 2, 2013 at 8:22 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I do this kind of landscaping
  10. May 2, 2013 at 8:26 PM
    acdronin
    acdronin Well-Known Member
    jobsite lights
    2400lbs of concrete
    pouring a wall, finish at 9pm
    my irrigation set up
    total weight: about 3700lbs
    any questions?:D
  11. May 2, 2013 at 8:44 PM
    Harry Hood
    Montrose Colorado
    nothing yet
    Great pictures. Looks like mine
  12. May 2, 2013 at 9:02 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I do my own landscaping. A few weeks ago I accidentally had a ton of dirt dumped into the bed of my truck. I was only going to have him dump half in but he dumped it all before I could say anything. Oops! Had about an inch between my bump stops and the frame. I only had a few miles to drive, but I felt bad about it.
  13. May 2, 2013 at 9:08 PM
    acdronin
    Thanks! Yeah, I have airbags, and I wouldn't suggest loading it like i do:D
  14. May 2, 2013 at 9:12 PM
    acdronin
    Fun with 45's today
    This landscape is about 6 months old now
  15. May 2, 2013 at 10:56 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Not sure if this counts, but am posting it anyway. I only do this in the fall for picking up leaves. We have a 2 acre yard and it has 7 gigantic cottonwood trees in it, all are over 100 years old so you can imagine the leaf output! It took an entire weekend to do it all this year. I use the lawnmower with the bagger to drive laps around the yard picking up leaves. This time, due to a snowstorm a couple weeks in advance it took longer because it had packed the leaves all down really bad. As you can see, my dog is my lil helper, her job was to pack the leaves down in the bed so I could get the most out of the loads. I've found this is the best method since the bags on the mower fill up so fast, sometimes they are jammed full in 20 yards of mowing. Before, I had to make thousands of trips back and forth to the much pile and it was not only time consuming, but burned up a bunch of gas in the mower. Using the truck method is way better. This load pictured was the last of the day, and it was also the worst because all those leaves were the wettest, they were up against the house in the shade so the sun couldn't dry them out like the others. Pulled a muscle in my back trying to wrestle them out. Good thing it was the last load because I couldn't have done any more for a few days. I also use it to haul firewood up to the house in the winter, but haven't got any pictures of that. Maybe next winter, but woodstove season is over. I only burn firewood in the dead of winter when it's bitterly cold, otherwise the natural gas heater does fine.
    381848_165311826944158_133621208_n_zpsf8_23ee49e5e5e3f8b3ab4e986a552cc5d13cd3d3fb.jpg
    599779_165312000277474_1181526996_n_zps1_fc77942c37ddc1e1b27c3f7142ca081d5b4c33b0.jpg
    Williston likes this.
  16. May 12, 2013 at 7:42 PM
    VTacoma2013
    Kevin
    Rutland, Vermont
  17. May 12, 2013 at 8:58 PM
    acdronin
    Is you dog the Super on this job?:p
  18. May 16, 2013 at 8:22 PM
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    how many yards of mulch did you guys fit in a 6.5ft bed? 1yrd?
  19. May 16, 2013 at 10:58 PM
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    I hauled home 1 yard of mulch a few days ago.. filled it right to the brim but not over. I was about 1.5" above the bump stops. Like moondeath said above.. felt a bit bad, but it rode fine the whole way home.
  20. May 17, 2013 at 8:07 AM
    huntndog
    huntndog Member
    Surfin' USA
    2011 DCSB TRD Sport
    I do landscaping on a couple of rental houses and haul quite a bit of crap (cut back branches, bushes, whatever) to the dump regularly, and I stack it pretty high....
    My old 1985 Toyota had a bunch of scratches around the bed from doing this... especially around the back window, along the bed sides and tailgate.
    I'm thinking about getting some bulk rolls of 3M Paint Protection Film, maybe 4" or 6" wide and installing it myself around the window and bed...
    Has anyone done this? Pain in the arse to install?? Results??
