Who uses E15 fuel???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinchetaco, Mar 1, 2016.
  1. Mar 1, 2016 at 8:58 AM
    pinchetaco
    pinchetaco [OP] Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    Who out there uses E15 in their truck? I happened to see it at the gas station where I usually fill up. I saw it was 10 cents cheaper that regular. Pros/cons? Benefits?
  2. Mar 1, 2016 at 9:01 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Ethanol is no bueno for us.
  3. Mar 1, 2016 at 9:04 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Was about to say you need a special engine for E-15.
    Glad to see you didn't use it lol.
  4. Mar 1, 2016 at 9:16 AM
    pinchetaco
    Winston Salem, NC
    Yeah I was skeptical about it. Just seems like bs to me. On the pump it says "for vehicles 2001 and up" Its right next to an E85 pump also
  5. Mar 1, 2016 at 9:24 AM
    pinchetaco
    Winston Salem, NC
    Oh absolutely. I know a few guys that use E85 in there "racecars" I had never heard of E15 tho
    NeedmoreTaco likes this.
  6. Mar 1, 2016 at 9:26 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I wanna say that even my gas cap is marked not to use anything more than E10.
    syswalla likes this.
  7. Mar 1, 2016 at 9:26 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    tacoma can handle e10 right ? no more ?
  8. Mar 1, 2016 at 9:27 AM
    pinchetaco
    Winston Salem, NC
    I will definitely have to look at mine to see what it says
  9. Mar 1, 2016 at 9:29 AM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    I've read that anything after 2012 could run e15 but I wouldn't run it in anything that's not specifically flex fuel even though it's not a huge difference from regular gas with up to 10%. As for a performance increase i don't believe e15 is going to make a difference. Tuning a boosted vehicle for e85 on the other hand will definitely make a difference for several reasons.
  10. Mar 1, 2016 at 9:30 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    There are several websites that have listings of gas stations that sell non-corn fuel nationwide. www.pure-gas.org is one.
  11. Mar 1, 2016 at 9:33 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the tacoma is rated for E10... dont run anything more than that in it.
    FYI cali gas is a max of E10.
    DustStorm4x4 likes this.
  12. Mar 1, 2016 at 9:41 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Isn't California gas some sort of "Oxygenated" gas ?
  13. Mar 1, 2016 at 9:42 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Isn't ALL gas oxygenated? o_O
  14. Mar 1, 2016 at 9:47 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
  15. Mar 1, 2016 at 9:55 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    I just remember something about it when I was driving a semi and had to go to Cali. My company didn't like us getting much Diesel in Cali. because of the reformulated fuel, and I kinda remember hearing that the gas there was a different formulation then most of the rest of the country as well. But, I could be wrong about that. it's been about 7 years since I was out there...
  16. Mar 1, 2016 at 10:33 AM
    nd4spdbh
    SoCal
    Lets just say... cali gas sucks.... dont leave it in a carb for more than a week otherwise you are gonna be cleaning that carb. There is a reason all of my motorcycles now are fuel injected. I replaced the carb'd dirtbike with a WR450F, and the 125cc CT70 chinese clone i use for camp trips with a Honda Grom 125 as the grom n WR are both fuel injected, and the big street bike is a honda 919 which is fuel injected as well. My old dirbike (CRF250X) had its carb out and cleaned so many damn times cus the cali gas sucks asssssss!
    127.0.0.1 and Rock Lobster like this.
  17. Mar 1, 2016 at 10:56 AM
    shakerhood
    Southern Ohio
    I checked the cap and it says no E20 thru E85 but says E15 is acceptable, but i still don't like the idea of it.
  18. Mar 1, 2016 at 11:42 AM
    pinchetaco
    Winston Salem, NC
    I don't think I'll be using it. If there were clear benefits of using it, then I'd consider it. Maybe there's people out there who use it and see a difference
  19. Mar 1, 2016 at 11:46 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    CA gas also has about a 27 cents per gallon excise tax. So If I was running a trucking company I would definitely try to push my drivers to fill up in other states if possible.
  20. Mar 1, 2016 at 1:05 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    frickin alcohol
    no benefit except emissions
    unless you are high compression. then, alcohol has higher octane won't knock at pressures which
    would knock straight gasoline. so the only benefit is if you have a motor that operates in a way that high
    octane/low energy fuel is a good thing. these tacomas can run on 87, a clear indicator they will
    not benefit much in performance from e(anything) except reduce knock
    for these regular motors, e(anything) blows goats
